SIKG70 SIKG70 is offline
Car: G70 3.3 RWD
Default G70 RWD MAP 2 - 1ST LOG - 01-28-2022, 08:33 AM
MAP 2
12 GALLON CA 91+ 4 GALLON E85
Hopefully I got the log correct, if someone could check it over that would be great.
Cheers.
AWDGT2's Avatar
AWDGT2 AWDGT2 is offline
Car: 2019 AWDGT2
Default 01-28-2022, 08:53 AM
Looks normal, HPFP held so your E mix was good, timing is clean, trims and AFR are all normal. You could go Map3 no issues.
My only recommendation is to learn how to paddle shift. Notice the huge dips in the orange line? That's your throttle closing at higher RPM's and you will notice how your blue line (boost) dips hard. If you paddle before 6k you will have a flatter boost curve and could pick up as much as a 10th.
Darrin S.
2019 AWD GT2, Sxth, JB4, Meth, MBRP, HFC's, Agency intakes, Agency FMIC, HKS Plugs 11.01 @ 124 mph
