Garrett.hull's Avatar
Garrett.hull Garrett.hull is offline
Car: 435 Xi
Default Dorch HPFP added and PR coils - 11-08-2021, 09:56 AM
Hi-
I am working to get the most out of the stock turbo still. Added Dorch stg 1 for my e50 fueling and PR ignition coils (active in MHD). I have the e85 BEF flashed with MHD. Please review and let me know how things are looking. I am running map 6 with a fairly flat boost of 19.5 tapering above 5000 rpms. I know I am probably asking too much of the stock turbo and that's why I'm here.
'14 435xi - FMIC- BMS intake - JB4 + FF + WG plug - MHD, Dorch stg1 HPFP, PR Coils
Car: 435 Xi
Default 11-08-2021, 11:19 AM
Log didn't post 1st time, corrected.
Car: Evo VIII
Default 11-08-2021, 11:46 AM
Timing is looks great! Overall the log looks really solid. WGDC is still fairly low, meaning there is still a bit more room to work with for the stock turbo. To reach over 20.9 PSI you HAVE TO HAVE 3.5 BAR TMAP. Until then, you are limited. I have linked you the 3.5 TMAP below.
https://burgertuning.com/products/jb...=2104148885528
(IF you end up getting 3.5 BAR TMAP) I have uploaded an image of new settings you should try and see how it looks. Please upload another log as soon as you make those changes so we can see how it looks. Thanks!
https://imagizer.imageshack.com/img922/5813/TcEM7E.jpg
Car: 435 Xi
Default 11-09-2021, 09:18 AM
Awesome! It feels great right now and definitely putting the TMAP on the list
Any suggested tweaks to Map 6 as it stands now?
Car: Evo VIII
Default 11-09-2021, 10:25 AM
As it stands right now, copy the user adjustment settings I sent you but make these changes.
-FOR ALL (22) PSI VALUES CHANGE TO (20.5)
-BOOST SAFETY SET TO (22)
Please upload another log once the changes have been made. Thanks!
Car: 435 Xi
Default 11-09-2021, 11:15 PM
Settings were adjusted and the boost curve looks great except it isn't targeting 20.5 as input. Let me know what you think, thanks!
Default 11-10-2021, 01:01 PM
Why have you disabled FF gain with the stock turbo? You'll need to re-enable that or do some DB tuning.
Car: 435 Xi
Default 11-10-2021, 01:39 PM
Hi Steve-
I wasn't aware it was off. You are referring to the FF option under ethanol setup for the sensor? Correct me if I am wrong since I haven't poked around in those settings since I installed the FF wires a couple years ago.
Car: Evo VIII
Default 11-10-2021, 04:17 PM
Steve is talking about "Feed Forward (FF)" not Flex Fuel. Make sure to enable "Test Duty Bias Learning Algorithm". Pictured below are your current settings.
Car: 435 Xi
Default 11-10-2021, 04:30 PM
I have no idea how it got switched off as I am assuming it is a default. I must have hit it inadvertently at some point. I will reenable and do additional logs. Thank you for catching this!
Car: Evo VIII
Default 11-10-2021, 04:34 PM
No problem!
Default 11-11-2021, 12:58 PM
To clarify...on different platforms, the options will read differently. The one Cannon posted a screenshot of is from a different platform. You don't want to disable FF adaption unless you are running an upgraded turbo(s) or have an issue with FF continually rising. In both cases you would then need to understand and implement duty bias tuning.
Car: 435 Xi
Default 11-11-2021, 04:06 PM
Ok, thanks Steve. So bit 5 and 6 should be on in my setup, correct?
Car: 435 Xi
Default 11-12-2021, 09:25 AM
Enabled duty bias algorithm...did several pulls as shown in the log. Still not targeting 20.5 as entered? Look forward to the next step. Thanks!
Car: Evo VIII
Default 11-12-2021, 12:24 PM
Please get another log in 3rd or 4th gear from 2k rpm to redline. Thanks!
To properly evaluate the tuning, we'll need a full throttle JB4 log from 40-90mph on a safe private track.
Car: 435 Xi
Default 11-12-2021, 03:53 PM
I think I got the info you guys need in these runs. I get so wrapped in playing with the car I forget how specific the logs need to be to be eval. Thanks
Car: Evo VIII
Default 11-12-2021, 04:20 PM
This log looks much better. Maybe just a bit more DB tuning in the top end and you're golden.
Car: 435 Xi
Default 11-12-2021, 04:24 PM
Ok...will the algorithm get the DB dialed in or do I need to make manual adjustments? Any idea why it isn't targeting 20.5 as indicated in the map 6 profile? Thanks!
Car: Evo VIII
Default 11-12-2021, 04:30 PM
Duty bias adjusting itself should help with your boost getting closer to target.
Car: 435 Xi
Default 11-15-2021, 01:35 PM
Everything is running really well and the DB is adjusting itself and getting more and more dialed in, only one little thing is coming up. At idle, the car seems to now hiccup here and there when idling...is this normal?
Car: Evo VIII
Default 11-16-2021, 11:08 AM
100%
Car: 435 Xi
Default 11-30-2021, 09:58 AM
Good morning
I added the TMAP sensor and programmed according to what was indicated. Log attached. Let me know if you see anything or have suggested changes or if I need to get better logging. Thanks
Car: Evo VIII
Default 11-30-2021, 11:07 AM
Nice! Try going back to default duty bias settings and drive around for a while and see if it will take care of itself.
Car: 435 Xi
Default 12-07-2021, 09:25 AM
Switch all DB back to 50 and it is continuing to adjust. I am getting a power drop at WOT frequently where the car drops and then picks up power in the middle-ish of the power band. It happened twice during this log. See anything?
