benmays99 benmays99 is offline
Car: '09 E91 335i N54
Default Boost over target 30FE persistent code - 09-16-2021, 11:55 AM
Hi guys,
Just installed my JB4 on my '09 E91 LCI 335i and went for a few test runs on map 1 and was fine for about 20 mins but after that I'm now consistently getting code 30FE boost over target which is putting the car into limp mode/low boost mode (3100) with check engine light on the dash.
I haven't adjusted any of the settings on the config page or dials menu but I've included them below.
Any ideas on what's causing this?? I've tried it with 2 different JB4 units and both had the same issue with my car.
Settings:
Firmware version 32/12//2
Fuel bias all 0
Duty bias all 50
boost safety 18
default wastegate pos 60
PID gain 25
Auto shift boost reduction 60
FF/ wastegate adaptation 31
Fuel open loop 90
Max boost 1st 12
Default 09-16-2021, 12:11 PM
Just found a post of someone having a similar issue, should I try and adjust menu 12 at 1800 and lowering PID to 15??
JB4 Overboost Issue 30FE - N54Tech.com - International Turbo Racing Discussion
