Default M3/M4/M2C S55 JB4 Anti-LAG setup - 05-08-2020, 02:58 PM
Finally getting around to writing up some directions for this. We plan to offer a kit down the road but for now I'll just post it as a DIY for those who want to dive in and start playing around.
Requirements for S55 Anti-LAG:
1) A BEF with the proper table adjustments. We add "AL" to the filename of our BEF to indicate the changes required have been made.
2) Solder a resistor to the JB4 control board, see photo below.
3) Add a wire to the JB4 harness between spot #20 on the JB4 connector and spot #2 on the BROWN MAP sensor connection. DSUB pin (standard, not high desnity) required for this. No resistor is needed in the wire. Posi-tap for MAP side connection is the easiest method.
4) Latest JB4 firmware with anti-lag logic enabled by setting DWP = 90.
Default 05-12-2020, 10:17 AM
Nice write up!!
luchocamp's Avatar
Default 05-21-2020, 03:38 AM
I need that to build 10-12psi from zero on upgraded turbos ..... great news
15 BMW M4 Full Weoght 10.69@133mph stock turbos SOLD
18 BMW XXXX Car in Process
ghost.f82 ghost.f82 is offline
Car: Pure Turbos M4 CP
Default 06-25-2020, 09:28 AM
What changes need to be made to the backend map? I'm really interested in trying this with my F80Paul map, though it's via BM3. He's not sure what changes are needed, so if you could provide them then it would be appreciated
luchocamp's Avatar
Default 06-25-2020, 09:49 AM
Do you have a JB4 ?
Default 06-25-2020, 10:00 AM
Originally Posted by luchocamp
Do you have a JB4 ?
Not yet, but if this can be made to work Iíll happily buy one
luchocamp's Avatar
Default 06-25-2020, 10:15 AM
I had see several cars running with JB4 no matter which flash or plattafom. Not 100% sure for antilag if could be done on other different flash from BMS
Default 11-13-2020, 10:24 AM
We'll have an upgrade kit on our site shortly to simplify the install for this!
