Jonplavist Jonplavist is offline
Car: Civic
Default How to read HPFP input - 01-13-2020, 08:16 AM
Hello,
I'm curious about the HPFP reading as it's the weak point on the K20c1.
When I graph it reads 17 in boost full throttle what does that really mean?
What is the highest number it reads and how can you tell if the HPFP is being taxed?
Default 01-13-2020, 02:52 PM
17 MPA which is around 2460psi.
When you run out of high fuel pressure you'll see pressure crater down below 9 MPA. As long as it's level and up you're good.
Car: Civic
Default 01-13-2020, 03:07 PM
Thanks Terry, not many owners take time to answer questions.
I love the unit and look forward to updates.
