918mostwanted 918mostwanted is offline
Default 2step&anti-lag install for AT ?ís - 12-01-2019, 01:54 PM
Is the install the same for AT? Cause the install guide I found was for MT. And also do I check the dtml wmi input box under ethanol setup?
E82(AT) w/hybrid twins, cp w/bov, catles dowpipes, stage 2 lpfp, jb4 w/mhd bef, relocated stainless inlets, 3.5 tmap. on 91 oct.
Fredm21 Fredm21 is offline
Car: Bmw 335i 2007 N54
Default 12-01-2019, 06:46 PM
Yes itís the same, you donít use the clutch wire..
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
BMS WMI with single nozzle ( 10 )
JB4 map 3 w/bluetooth & antiliag
Afe intake filter
BMS intercooler
BMS tranny cooler
BMS Double baffle catch can
MHD BEF Racegas
Precision Raceworks Coil
-Running 91 octane with WMI
Default 12-01-2019, 07:10 PM
What about user settings?
Default 12-02-2019, 03:52 AM
You have to activate bit3.
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
