PlumpyPusher PlumpyPusher is offline
Car: F30 328i
Default Power cut in higher RPM range - 01-19-2020, 08:09 PM
Under full throttle I feel the power cut and surge in higher RPM ranges. Iíve searched here and bimmerpost and have found one or two threads of others experiencing this, but so far for no definitive answer. Iím hoping someone can give me some insight about what is happening, or at least peace of mind that nothing is wrong. Log attached.
2015 328i Sportline
VRSF ******* **/ VRSF 5Ē HD intercooler / K&N drop-in
Default 01-19-2020, 09:23 PM
Is the JB4's fuel pressure connector attached?
Car: F30 328i
Default 01-20-2020, 04:53 PM
I left part of the harness disconnected because the instructions indicated it was for 320. I took care of it this morning and logged a new run. Didnít experience the power fluctuation, but only went full-throttle once.
2015 328i Sportline
Default 01-20-2020, 06:32 PM
OK next up try to recreate it in a log!
Car: F30 328i
Default 01-20-2020, 06:58 PM
Aaaaaand here you go, Terry. 4th gear, cuts at 5k. I added it to the end of my last log.
2015 328i Sportline
Default 01-21-2020, 04:38 PM
My first guess here is knock or timing pull. Does it come up on map1? What fuel is being used?
Car: F30 328i
Default 01-21-2020, 05:59 PM
I haven’t given map 1 a try yet. I’ll post a log as soon as I get a chance. The gasoline is Shell 93 octane.
2015 328i Sportline
Car: F30 328i
Default 01-22-2020, 05:48 PM
Didnít experience anything out of the ordinary during the map 1 log run. Attached for review. Same fuel, though the ambient temp is about 15-20 degrees colder.
2015 328i Sportline
