Default JB4 for 2018+ Jeep Wrangler/Cherokee 2.0L - 11-21-2019, 06:28 PM
Working on setting this thread up. A lot of the information below is from our Alfa JB4 which shares the same engine platform and will be updated with Jeep specific information in the near future!
By default the JB4 ships on map1. For higher boost map, logging, firmware updates, and other features, you'll need a JB4 Mobile adapter for wireless connection to your phone or a BMS data cable for wired connection to a laptop.
JB4 Mobile Smart Phone wireless connection directions Click here.
BMS data cable hard wired directions Click here.
Installation guide Click Here
Map guide as of v3 firmware (selected via JB4 Mobile/laptop interface. Map1 is the default map)
Map 0: JB4 disabled
Map 1: 4psi over stock tapering to 2psi at redline.
Map 2: 5psi over stock tapering to 3psi at redline
Map 3: 6psi over stock tapering to 4psi at redline
Map 4: Coming soon!
Map 5: Coming soon!
Map 6: User adjustable map
Map 7: Coming soon!
Map 8: VALET / Low Boost map
Firmware:
JB4_JEEP_1:
Initial platform firmware
Default 11-22-2019, 09:32 PM
Brandon at Krazyhouse Customs dyno testing our new Jeep 2L JB4 out on his dyno. Solid results on 93 octane vs. stock and got even better on an E30 mix! Will post the E85 mix runs after we make a few more tweaks to it!
JHOOPS2 JHOOPS2 is offline
Country Roads!
Car: 2009 135i
Default 12-02-2019, 10:14 AM
One of the things that I missed when I got rid of my 135i (N54) was the JB4 and it's simplicity... Now that I have a 2019 JL Rubicon... BMS will soon be back in my life! Thanks Terry!
-Jeff
Mods: FBO
jw1971 jw1971 is offline
oceanblue2019
Car: Jeep JL
Default Logs from Jeep - 12-08-2019, 10:30 AM
Hi Terry,
Here are a couple logs. 91 octane (best available locally).
Jeep feels strong.
Also found this which makes a good place to mount the JB4 close enough for the OBD2 wiring to reach.
JL Audio SBA-J-JL-FHB - Jeep Wrangler '18-Up Accessories
Default 12-08-2019, 10:51 AM
Looks normal to me for the platform. Have access to E85? You could mix in a few gallons to get octane up for comparison.
oceanblue2019
Car: Jeep JL
Default ******** - 12-15-2019, 05:56 PM
Hi Terry,
Will a test pipe trip the CEL? And if so I guess a piggyback can't really deal with that can it?
This just came out and looks like the first step to get some more power....
Twisted Steel Down-Pipe (Race Series) | aFe POWER
Default 12-16-2019, 10:42 AM
Originally Posted by jw1971
Hi Terry,
Yes, that will cause a CEL to come on.
Gibo68 Gibo68 is offline
Car: Wrangler JL 2.0T
Default MAP8 on my Rubicon 2.0T my 2018 (European Version) - 01-14-2020, 02:19 AM
I have tried the MAP8. This map puts the engine in safety mode.
The maximum speed is 50Km / h.
But it does turn on the engine light and then it doesn't go out anymore.
With the engine light on, maps 1-2-3 no longer work.
Why?
Default 01-14-2020, 11:16 AM
Why?
Yes, that's called Valet map. Makes the car super slow so when you give it to valet driver they wont go on a little drive with your car.
Put back in map 1 and turn car off and on and it should be back to normal.
Default 01-15-2020, 10:21 AM
The VALET map is still a work in progress. Record a log on map8 (when the light isn't on) and we'll see if we can tweak it next version to run slow without triggering an extra light.
Default 02-03-2020, 01:28 PM
Many thanks, but I don't think to use the Valet Map.
In any case, as soon as I select map 8 the light turns on.
Then it is difficult to turn off the light.
Default Air intake system - 02-03-2020, 01:48 PM
I have tried all three maps, and with the standard air filter they work really well.
If I install AFE Filters 50-70035G Momentum GT PRO GUARD 7 Air Intake System, it seems to me that the engine pushes less. Could it be true?
Default 02-03-2020, 01:54 PM
Have a log before and after the intake? Let's see how they look. I really doubt the intake hurts. Although it may not help either.
Default 02-03-2020, 02:17 PM
No, I have nothing, how and what should I do?
Default 02-03-2020, 04:13 PM
Use a dragy to do 1/4 mile runs on stock intake and aftermarket to log and compare differences? If no gain return the intake.
Default 02-04-2020, 06:06 AM
I found a test of a week ago, maybe a 0-100 km / h
2020-01-26 10_50_54_Map-3.csv (with standard air filter)
today I did 2 more tests
2020-02-04 13_18_08_Map-3.csv (with AFE air filter)
2020-02-04 13_19_52_Map-3.csv (with AFE air filter)
Can you see if it's better or worse with the AFE filter? :arco::arco:
Default 02-04-2020, 10:17 AM
It looks the same to me.
There is one logging parameter missing currently we need to sort out to better evaluate intakes, charge air temp!
Default 02-06-2020, 02:48 AM
Yes, I have seen that some data is missing.
Even the gear.
Anyway thanks
oceanblue2019
Car: Jeep JL
Default 02-07-2020, 06:05 PM
Hey Terry the factory intake pipe has some resonators that seem to help torque down low before boost comes on.
Most of the aftermarket intakes get rid of them for a nice smooth inlet pipe. But as a result the Jeep doesn't pull hard until into boost.
I had a S&B and that was the challenge. Felt soft down low but I did see more boost at peak over stock - so it was helping, just not where the big heavy Jeep needs it the most
Any ETA on getting ICT working?
Also any experience with the AC intercooler fluid chillers?
albel1214 albel1214 is offline
Default 2020 Cherokee - 02-12-2020, 06:39 PM
Has anyone done this on a cherokee yet? Was reading on another forum they are much more locked down and this won’t work.
-----SGM 135i-----
Hazynighthawk Hazynighthawk is offline
Default 02-14-2020, 09:53 AM
This ! Waiting to order till i see a review in a Cherokee
timberwolf timberwolf is offline
Default 02-28-2020, 03:08 PM
I just ordered this for my 2019 Jeep JLU Rubicon. Looking forward to reporting back.
Burgerized Cars:
19 Jeep Rubicon 2.0L
17 X5 50i
16 Golf R
13 M5
08 135i
Check out my videos
http://www.youtube.com/gvahan#p/u
Default 03-26-2020, 02:10 PM
Any updates??
Default 03-26-2020, 04:15 PM
Originally Posted by Hazynighthawk
Any updates??
Sorry for the lack of feedback. The Jeep picked up a nice bump in power. Clearly more grunt across the range. I floored it behind a jaguar suv that merged full throttle and he didn’t pull away. My fiancé said the rush reminded her of our ess tuned x5 50i! I know the x5 was much faster but she got to sinking stomach feeling from the passenger seat so that’s a great sign! 😂
Burgerized Cars:
17 X5 50i
16 Golf R
13 M5
08 135i
Check out my videos
Default 03-31-2020, 10:53 AM
Sweet i literally just got mine in today for my
Cherokee 2.0t. Was the install easy??
