Type_R_2018 Type_R_2018 is offline
Car: 2018 Honda Civic Type R
Default Please look at these logs - 09-22-2019, 11:18 AM
Hi, can you please look at these two logs and check for knock or anything happening thats not supposed to be happening.
Both logs are a 4th gear pull from 3000rpm to red line and shifting into 5th gear
I use Western Canadian 91 or 94 octane gas. I know our gas isn't as good as it is in the states so thats partially my concern.
Please let me know,
Thanks.
Default 09-22-2019, 05:58 PM
Would need the CSV files... Not PDF.
Default 09-22-2019, 06:08 PM
sorry about that.
This should be what you are looking for.
Default 09-24-2019, 06:39 PM
Look more or less as expected. Some octane would help power here for sure.
Default 09-25-2019, 10:57 AM
Does everything look fine tho? do you see any engine knock or anything to be concerned about?
I just want to make sure everything is running safe on Map 1 & Map 2.
