Bluesz_ Bluesz_ is offline
Car: '10 535i xDrive
Default Bluesz's Log Review - 09-18-2019, 10:21 PM
Hey Guys,
Since I see other threads of log support,
I'd like ya'll to see how my car is running as well.
'10 535i xDrive w/ ~130K Miles (xDelete is on)
JB4 w/ MHD Backend "PUMP_USA"
NGK 95770 Spark Plugs
BMS DCI's
VRSF Chargepipe w/ Tial (Unpainted Spring) w/ BMS Vacuum Hose Adapter.a
On 93 Pump
I've ran JB4's Map 1,2,5 from ~2,000-7,000 rpms w/ TC off and on 3rd Gear
Map 2 seems to always shudder around 5-6k
Joelkswagen Joelkswagen is offline
Default 09-19-2019, 02:24 PM
Your IATs are through the roof. They next thing you need is a 7" Intercooler. These temps are causing you to pull timing all over the place. You shouldn't run map 2 right now without one. Even map 1 is maxed out on heat a timing pulls.
Rule77's Avatar
Rule77 Rule77 is offline
Car: 08 E90 335i
Default 09-19-2019, 02:49 PM
Originally Posted by Bluesz_
Hey Guys,
BMS DCI's
On 93 Pump
I would only run map 1 with all those timing corrections. +1 on the fmic
08 E90 335i - MONTEGO BLUE - JB4/MHD E85 BEF
BMS DCI - BMS OCC - NRW CARBON COWL FILTERS
MMP CHARGEPIPE - TIAL BOV - VRSF 7.5” RACE FMIC
VRSF DP’s - VRSF INLETS - VRSF OUTLETS
BMS PEDAL TUNER - RB PCV VALVE - 3.5 BAR TMAP
NGK 97506 @.022 - PFS STAGE 2 LPFP - H&R SPRINGS
SPOOL PERFORMANCE ETHANOL ANALYZER
MISHIMOTO 25 ROW OIL COOLER
BMS SPORT OIL COOLER VALVE - NRW V1 PADDLES
MISHIMOTO 15 ROW TRANSMISSION COOLER
19” 666m WHEELS - HANKOOK VENTUS V12 EVO 2’s
Default 09-20-2019, 07:31 AM
Agree with all said.
I’d be looking into a solid fmic - we offer a 7.5 race that everyone loves
Default 09-20-2019, 07:45 AM
Thanks guys for all inputs. I will get a FMIC and post results
Default 09-20-2019, 10:27 AM
https://burgertuning.com/collections...nt-intercooler
