///Monst3r ///Monst3r is offline
Car: 07 335i
Default Single Turbo Logs - 08-15-2019, 12:23 PM
Im having an issue with rich fueling(enough where raw fuel is coming out my hood exit exhaust). Rich on top causing a limp mode. Di I just turn down the port injection and re-log I was having the same issues when I turned fuel down to 30 on al rpms as well but log was destroyed because of limp.
Fueling system includes walbro 450 and 525 on hobbs switch stock feed lines to new hpfp, index 12 injectors and Phoenix manifold with 6an return and 1.1 regulator. I also have cm5 meth nozzle for cooling since its 110+ but am not currently spraying.
07 e92 MT 335i- JP works TS TM 6466 1.0 a/r, custom 4in fmic, vrsf cp, tail bov, custom catch cans, external pcv mod, adv O2's, phoenix intake manifold,fuel it port injection, bms meth kit dual cm10, Motiv twin disk, 450/540 in tanks/ 6an return and regulator, stoptech drilled and slotted rotors & pads,15in drag setup , ST coilovers,berk full exhaust ,jb4 g5, mhd
2012 650i- D0wn pip3s, jb4, custom drop in filters, carbon filter delete
Default 08-15-2019, 09:39 PM
Wow- yeah that is crazy rich.
The last safety you through was 5- fuel trim variance.
Couple questions:
Which flash are you using?
I’m assuming full e85? (Confirm)
What CC injectors in the manifold?
What happens on lower maps?
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 07 335i
Default 08-18-2019, 02:17 AM
Full e85
e85 single turbo PI Flash
750cc injectors
Generally Issues until after 20psi but very inconsistent
Default 08-19-2019, 11:45 AM
Originally Posted by ///Monst3r
Full e85
750cc injectors
Can i see a lower map log?
e92 AT 335xi 2.0
Doc Race Kit 6062
