T52's Avatar
T52 T52 is offline
Car: 2016 BMW 340i xDrive
Default B58 (no BEF) and new maps - 08-07-2019, 08:16 AM
I recently upgraded my firmware from v11 to v13_1 on my '16 340i with JB4 and BMS Intake only. I run 93 octane pump gas and always used Map 2. Looking at the new Map guide would v11 Map 1 be similar to v13 Map 2, v11 Map 2 be similar to v13 Map 3 and v11 Map 3 be similar to Map 4?
JBoe JBoe is offline
Car: M240i
Default 08-07-2019, 11:44 PM
If you don't have BEF and FUD 6 enabled, the mapping is the same as V11. It only changes when you have V13+ and FUD 6 enabled. Stick with map 2... Same as before. Hope this helps to clarify.
T52's Avatar
T52 T52 is offline
Default 08-08-2019, 06:30 AM
Thanks for the explanation. I was confused because I was referring to the map guide shown for v13 Back End Flash Maps. My thinking was since I upgraded to that version firmware I should use that map guide. So even though I have v13 firmware without FUD 6 enabled the JB4 is using v11 map guide.
Car: M240i
Default 08-08-2019, 07:17 AM
That's correct. I recently asked this in the BEF, or Firmware/Settings thread and Terry confirmed. It was just a week or so ago. If you want, search my post history and you'll find it.
