BMW135xe BMW135xe is offline
Car: Bmw 135I
Default Stuck with no fimware in my car - 07-19-2019, 04:51 PM
Need some help here.I had firmware failure .Now car starts but stalls after 10 seconds.I can't connect with my e-phone and steering wheels buttons for the jb4
don't work.I disconnected the battery , but no luck. So what is next ditch the jb4 and go MHD Flash only.
Default 07-22-2019, 10:35 AM
No, you just try and upload the firmware again.
Car: Bmw 135I
Default 07-22-2019, 11:19 AM
Firmware won't download with my app . My apple phone says-unable to read/ validate settings.Check your user/meth settings to ensure they are correct,
which is the firmware. How can I validate if I can't connect to the jb4 . Their is no disaster recovery for
it,so best case scenario is to send my clipboard to be reflash or buy just the jb4 box for $175.I was thinking buying a new JB4 box only?
Default 07-22-2019, 12:36 PM
Sounds like you have the bluetooh module- correct?
Try deleting & re-installing the app on your iphone.
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: Bmw 135I
Default 07-22-2019, 02:34 PM
Yes I have blue tooth module . Try app three times reinstall nothing. Disconnect battery nothing.
Put connect kit with 12V power nothing. What do you recomment?
1-Send chipboard for reflash
2-Buy new jb4 box for $175.
I can't communicate , because it left car without firmware.
Default 07-22-2019, 03:16 PM
have you tried removing the jb4 / starting the car?
i'd also inspect the jb4 in general- sounds like maybe it lost power or a connector may be lose- which is why the bluetooth can't find i.t
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: Bmw 135I
Default 07-22-2019, 03:35 PM
Car starts fine ,but stalls after a while with check engine light.
Yes, tomorrow will remove JB4 and see if cars runs without any problems.
I will check also ECU . Hope is not damage>
Thanks for the feedback>>
