asjandu asjandu is offline
Car: 2009 BMW 335 xi, 2016 Mercedes C300 4matic, 2016 Dodge Durango Hemi AWD
Default Starter Shot - Oil deposit HELP!!!!!!!! - 06-04-2019, 06:54 PM
Hello,
So my starter was shot and I took it out today but found oil under it. Attached pictures. Not sure if this should be normal or?
Would this be the reason of the starter going bad because I had replaced it only 4 weeks ago but had been fiddling around with the motor so not sure if that would have shot the starter.
Any help will be appreciated.
nissubaru nissubaru is offline
Car: 2009 335i M-Sport
Default 06-05-2019, 05:57 AM
Pictures don't work.
BIMMIN BIMMIN is offline
Car: 2009 335i AT
Default 06-05-2019, 07:02 AM
Oil shouldn't take out your starter. Sounds like you have a short somewhere. Maybe a pinched wire during installation. Obviously you want to fix the leak though
2009 E92 335i AT
Engine
Rev9 Hybrid 16t twins, Injen cyborg intake, CP-e charge pipe with HKS SSqv BOV, RB external PCV catch can, BMS catch can, Cobb intercooler, HKS Legamax exhaust, RB inlets, VTT single barrel hpfp, fuel-it! stage 2 lpfp, MOTiV Flex fuel flash only w/ trans tune by Cedar Performance
558rwhp and 523rwtq on e60 110* ambient air
N54_ABQ's Avatar
N54_ABQ N54_ABQ is offline
Car: 2007 BMW E92 335i
Default 06-05-2019, 07:37 AM
Oil could be coming from a bad seal on the crank position sensor.
What brand starter did you replace with?
Some of the cheap autozone/orielly's starters are not known for their longevity.
2007 335i E92 6MT FBO, Stock Turbos
