FuelTuner's Avatar
FuelTuner FuelTuner is offline
Default JB4 Kicking out of Map 3 - 05-23-2019, 11:03 AM
Hey everyone,
Whats the parameters that dictate Map 3 kicking out into failsafe condition ?
I have the genaric map 3 settings , except boost cut set to 20 psi
2008 N54 335i
Pure Turbos
JB4 Meth
Intake / ********* , Exhaust , BOV, Intercooler, newplugs
MHD BEF ( pump gas usa )
JB4 meth w/ twin nozzles 70/30 mix
91 oct
I personally dont see anything in the log that would show an issue .... but again I do not know what ultimately causes the map to swap over to map 4 . I did not put this car together , install any parts . So I am assuming that the meth system is funtioning correctly as it shows flow and the system was purged and working .
Car was smoke tested intake and exhaust .
Log is attached.
Boost failsafe 20 psi
Default wg position 60
PID gain 25
Auto shift boost redux 60
FF WG adapt 72
Open Loop 70
Meth safe mode 0
Meth trigger mode 0
Max boost 1st 12
Max boost 2nd 0
Max boost 3rd 0
2008 E90 Auto
- JB4
- Code 3 Intercooler
- Ultimate Racing *********
- VK Oil Cooler
- MagnaFlow Exhaust
- Ultimate Racing Intake
- Tien SS-P Coilovers
- Hotchkis swaybars
- Hawk HP pads
- Quaife LSD
-19'' BBS LM
Default 05-24-2019, 12:35 AM
Originally Posted by FuelTuner
Hey everyone,
2008 N54 335i
Pure Turbos
JB4 Meth
91 oct
Log is attached.
PID gain 25
FF WG adapt 72
Open Loop 70
Meth safe mode 0
Meth trigger mode 0
Max boost 1st 12
Max boost 2nd 0
Max boost 3rd 0
Your throwing safety 1- boost safety
Yours is set to 18- bump that up to 19 or 20- SAVE & relog
