TimboBlackkers TimboBlackkers is offline
Car: '08 135i MT
Default In-Tank fuel pump upgrade on stock wiring - 05-16-2019, 05:08 PM
Hi Team.
Just a quick one. I've got a Walboro 525 on the way to replace the factory fuel pump. (Planning more boost and heavier E mixtures)
It looks like this pump can draw ~25A in normal operation.
Is it fine to use the stock wiring for this or should I wire in a 60A horn relay direct from the battery?
Car is an 08 6MT 135i
Thanks,
Tim
jymmijamez's Avatar
jymmijamez jymmijamez is offline
Car: 2009 BMW 135i
Default 05-17-2019, 10:50 AM
your going to need to run a separate power feed from battery, I don't think you'll need 60amps. I have not heard of anyone running a stand alone 525 pump, usually they are the secondary pump, not saying it can't but there might be other issues.
2009 Space Grey 135i 6MT - FBO Phoenix Intake PFS Stage 4 and PI w/ JB4 MHD BEF VTT GC Lites MFactory Limited Slip - Trebila Tuned -- 534hp 488tq
Car: '08 135i MT
Default 05-19-2019, 04:52 PM
Thanks,
I know that horn relays come in 30 or 60A. I think 30 is a little tight for the application where 25A draw is normal.
I'll see if there's a 45 or similar available.
I think a direct battery power feed is a good idea.
Thanks for your input.
Tim
jymmijamez's Avatar
Car: 2009 BMW 135i
Default 05-20-2019, 09:30 PM
Plug Play Fuel Pump Activation Harness
