(#51)
dRDiesel's Avatar
dRDiesel dRDiesel is offline
Car: BMW
Default 04-08-2019, 05:49 PM
Terry Iím on map 0 latest update now and BEF is loaded. Iíll get you some logs.
Basic questions:
Do we need to still set FOL, FUA and duty bias and such including meth settings on map 7 when itís time to switch over from map 0?
BMW After BMW
Car: BMW M240i
Default BEF LOGS WITH METH! - 04-08-2019, 07:08 PM
Here are two logs... man this felt good! Finally, progress after cracking the DME!
Fueling looks better, and AFRs are better. Power is smoother. Throttle closures are almost completely gone.
Current settings are conservative, even compared to JB4 defaults:
- FOL 20
- FUA 10
- Additive 40
- duty biases pushing boost down below target down low
- WMI mix at 50/50
- 93 pump
Will change these based on Terry's next recommendations or new maps, but wanted to share progress.
Antec800 Antec800 is offline
Car: 340ix
Default 04-09-2019, 01:21 AM
Originally Posted by dRDiesel
Never mind Terry got it squared off. Just need a BEF file.
Do you need to email terry for the bef file to upload it?
JorgeIII JorgeIII is offline
Car: BMW F30 LCI 320i 2017
Default 04-09-2019, 09:16 AM
Hellow. Will the B58 maps be compatible with B48 20i & 30i clients or we have to wait for specific maps? In the late case, any ETA? Thanks.
BMW After BMW
Car: BMW M240i
Default 04-09-2019, 09:53 AM
Hey guys just wanted to update this thread. BEF does feel different its throttle response and such, but it's still a beta so it's not perfect. I did feel some serious misfire and choking last night I'm not sure how exactly were suppose to dial it in, but it needs some minor tweaking from MHD side if i had to guess. My AFR were hitting hit 11's and low 12's in some runs.
Attaching my logs from this morning - how do they compare? My AFRs and trims look much better, and DME BT is substantially higher. I am still on conservative settings. Look at my bias settings...
Also, I'm on 30 additive for now at Terry's recommendation while he tunes more. And FUA 10, which also offsets WGDC....
dRDiesel's Avatar
Car: BMW
Default 04-09-2019, 11:01 AM
They practically look the same, but i was a bit terrified to mess around with the JB4 settings since the BEF is still in beta. I emailed my logs over to Terry and I'm waiting for him to review it and pretty much move forward from there.
Default 04-09-2019, 12:25 PM
Since everyone is running different maps, different mods, and different things as we test and develop things, just email in logs for now. Once the maps are standardized then we'll start looking at logs posted to the thread.
acrhalo's Avatar
acrhalo acrhalo is offline
Car: 2017 BMW 440i MPPK
Default 04-09-2019, 04:32 PM
Is anyone testing with Meth yet Terry? Are one of the first maps going to be good with that? Or do you need a beta tester? I’m running fbo’s with Meth. All by you! I love it! Can’t wait to get more power from this!
Default 04-09-2019, 04:46 PM
Most testers are using WMI actually, the factory fuel pump is relatively week. So without CPI or WMI then boost is very limited on E85 mixtures.
acrhalo's Avatar
Default 04-09-2019, 05:02 PM
Fantastic! I’m looking forward to the results. Any idea when the beta testing will be complete?
Car: 340ix
Default 04-09-2019, 06:36 PM
Does the mhd app support android 5.0, Iím purchasing a s5 tomorrow
BMW After BMW
Car: BMW M240i
Default 04-09-2019, 06:44 PM
Check MHD site, think it’s android 3.4 and up?
Car: 340ix
Default 04-09-2019, 07:41 PM
Check MHD site, think itís android 3.4 and up?
I also ordered the bms cable so we donít need a otg cable correct?
BMW After BMW
Car: BMW M240i
Default 04-09-2019, 07:55 PM
Correct! Assuming your device is OTG compatible and has the right USB form factor. Which it most likely does if it is within past several yrs!
Default 04-10-2019, 09:48 AM
Working on adding fuel pressure logging to the JB4 firmware. Previously it was only active when the fuel pressure connector was attached. With the flash though there is no longer a need/benefit for the fuel pressure connector. But there is a need for everyone to be able to monitor fuel pressure. As it's looking to be a limiting factor in B58 performance right now.
BMW After BMW
Car: BMW M240i
Default 04-10-2019, 09:34 PM
MHD set up a new separate WhatsApp group just for JB4/ BEF: WhatsApp Group Invite
18bmwb58's Avatar
18bmwb58 18bmwb58 is offline
Car: 2018 bmw 340i m sport
Default Issues with with app - 04-14-2019, 09:32 AM
I have tried my samsung s9plus with a micro usb adapter and it does not detect voltage in the app ... i also tried my android tablet and it sais mhd flasher is not compatible with my tablet !? Any recommendations? **** is mad annoying
dRDiesel's Avatar
Car: BMW
Default 04-14-2019, 09:33 AM
You probably need to email MHD.
BMW After BMW
Car: BMW M240i
Default 04-14-2019, 12:22 PM
Agree with email MHD. My guess? Your cable is bad. What kind is it?
18bmwb58's Avatar
Default Yup cable is bad - 04-14-2019, 02:33 PM
I just got the cable from burger motorsports when i wiggle it it starts working 🤦*♂️
18bmwb58's Avatar
Default 04-14-2019, 02:34 PM
And the link that terry has up on first page with the mhd flasher does not work it sais its deleted
BMW After BMW
Car: BMW M240i
Default 04-14-2019, 02:37 PM
I posted a WhatsApp chat link for BEF. Join that and ask for the link. MHD has to provide it at this point.
BMW After BMW
Car: BMW M240i
Default 04-14-2019, 02:38 PM
Sometimes itís the OTG cable too. Nice thing about BMS cable is Mini USB is integrated.
dRDiesel's Avatar
Car: BMW
Default 04-15-2019, 07:00 AM
Beta might be closed, but it doesn't hurt to ask if you can still join.
BickNeckers BickNeckers is offline
Car: M140i rwd zf8 3dr
Default 04-15-2019, 01:37 PM
I already have the mhd app version for b58 through the link Terry provided. Are there maps available after you purchase the mhd flasher license right now or do they become available after the beta in this forum and do you have to manually upload the bef file through your phone? First time bef'er here.
