JRB2 JRB2 is offline
Car: 2014 BMW 535i Xdrive
Default 2014 BMW 535i Xdrive with PWG (F10 N55) Boost Problems Help!! - 02-21-2019, 10:34 AM
I am hoping someone has had a similar problem or one of the gurus can pipe in and give me a new direction to look for a solution. Currently the car has the MHD with JB4 tune. The vehicle has an upgraded CP, Catted Down Pipe, Intake and exhaust. I run stage 2 tune with about 95 octane. I have sent in multiple logs trying to get the vehicle a bit more dialed in however I keep getting told that it appears to have a boost leak.
I have pressurized the lines and cannot hear any leaks nor can I see any by spraying soapy water. I have also replaced the boost solenoid as I didn't have a true way of testing that in hopes it would be the issue yet still nothing.
What doesn't make sense is if I run the car around 2k rpm and keep in in that gear to red-line it boosts at approximately 15 psi and holds the entire time. Yet if I just let the car shift automatically, when the car kicks down and goes through the gears, I can see that the ECU is calling for 15 psi however it will only boost around 9-10. You can see when it shifts the boost will spike and then go back down to the 9 psi range.
Any ideas???
hardparker hardparker is offline
Car: F25
Default 02-22-2019, 08:05 AM
Similar issue going on here possibly: https://www.n54tech.com/forums/showthread.php?p=624322
F25 X3 35i M Sport | Pure Stage 2 turbo + inlet | UR de-catted thingy | VRSF Race IC | FTP full thingies | BM3 PTF tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | 50iX brakes
Default 02-24-2019, 10:01 PM
Any ideas???
Wed need a log to evaluate
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
E30_Crazy E30_Crazy is offline
Car: '14 X1 35i, '87 325i MTech1
Default 03-11-2019, 01:55 PM
A wild guess, maybe your DV? After a gear shift, the DV does it's thing, then doesn't get a good seal again before the boost hits?
Default 03-30-2019, 12:57 AM
Since I made this post I have replaced the intercooler, upgraded to a pure stage 1 replaced the diverter with the GFB DV+. Still not hitting boost target. Not sure what can be adjusted. Any help would be appreciated!
Relegate Relegate is offline
Car: N55 135i
Default 04-23-2019, 05:36 PM
Keep us up to date. My car took a giant dump after I did the BEF and now Iím having to replace the DME. $1400 and back to stock power. Joy.
Default 04-23-2019, 06:50 PM
Seems to be running pretty good. Just wish I knew how to read and dial in the JB4. At this point I'm not itching to upgrade anything else but then again, not much left to do to.the car lol. That sucks about the DME. Can you take it somewhere and have them code it back to stock instead of buying a new one. Plenty of programmers out there.
