j3vr6 j3vr6 is offline
Car: 2016 340i RWD
Default HCP Backend Flash for JB4 for B58? - 02-04-2019, 05:47 PM
Saw this on the HCPerformance's instagram account. They now offer back end tunes for the JB4 for the B58 engine.
See this Instagram photo by @hc.performance: HCPerformance on Instagram: “B58 backend flashes available ! #Repost @wrenchstudios with @get_repost ・・・ @panda340i remotely flashed for @mitchellmorson with our Most…”
What exactly would be the gain for doing this?
Default 02-04-2019, 06:24 PM
Yes we have a few JB4 B58 customers running flash maps now, nice improvement over stock, although I'm not sure they are all 100% where I want them yet. But they will get there.
Car: 2016 340i RWD
Default 02-05-2019, 04:11 AM
How is this different from the JB4 piggyback, though? Are these tunes that compliment JB4 and used in conjunction, or are they just flash tunes that replace the JB4 all together?
jrdoming jrdoming is offline
Default 02-05-2019, 06:46 AM
They compliment it. They help control some of the things that the jb4 can't coax the ECU to do in regards to fueling while the jb4 continues to control boost and give you the ability to make on the fly map adjustments etc.
2017 340i M Sport. JB4
dRDiesel's Avatar
dRDiesel dRDiesel is offline
Car: BMW
Default 02-05-2019, 10:48 AM
It's better if you wait for MHD since new maps will be made based off their back-end flash.
| 2013 BMW 335is |
| MHD Custom E60 | Stock Turbos| 2" Inlets | down-pip3s | DCI | PR coils | BMP Stage 2 fuel pump |
panda340i panda340i is offline
Car: 340i Xdrive
Default 02-05-2019, 11:06 AM
I got the HCP flash via Wrench studios in England. Really pleased so far. I'm running a e30-e40 mix with x98 in the tank. Trims look good. The car feels an animal at 60 add. So glad i went down the route of BEF with JB4 vs flash tune with mission. I need to get a 0 map log to terry to look at but so far so good.
https://www.facebook.com/photo.php?f...&theater&ifg=1
2016 340 xdrive - JB4 - Dinan Midpipe - Dinan Muffler - Dinan Shockware - PS2 - BMS methkit - Dual DO7 nozzles - HCP BEF
dRDiesel's Avatar
Car: BMW
Default 02-05-2019, 11:20 AM
60 additive! Do you know how much boost your hitting? Target/Actual
| 2013 BMW 335is |
Car: 340i Xdrive
Default 02-05-2019, 01:15 PM
Its targeting 23-24 and im hitting it. Did see the link to my facebook post with the log. Not sure how to attach pictures on here
Default 02-05-2019, 02:27 PM
The flash maps remove some of the limiters in the ECU and get the tuning close to where we want it, and the JB4 handles the rest including setting the final boost target, fine tuning, features, logging, safety systems, etc.
Car: 2016 340i RWD
Default 02-07-2019, 05:18 AM
So on a B58, what additional gains would you get with the backend flash installed with a jb4?
Default 02-07-2019, 09:34 AM
Depends on your fuel, how aggressively you want to push the tuning, and what was changed exactly in the BEF. A good flash will raise the fuel limiters so you don't get a wobbling boost target and/or throttle closure at higher boost targets.
Antec800 Antec800 is offline
Car: 340ix
Default 02-11-2019, 06:50 AM
Will we need to purchase anything else or just hook the laptop up to the jb4 and install the flash?
Default 02-11-2019, 09:24 AM
Most people use the JB4 mobile adapter for logging via the JB4, but data cable and laptop works too.
Default 02-11-2019, 10:27 AM
The backend flash will go through the MHD tool so you'll need a cable and the app/license on your phone. Don't know all the details of cost or anything however.
acrhalo's Avatar
acrhalo acrhalo is offline
Car: 2017 BMW 440i MPPK
Default 02-23-2019, 04:58 PM
I was just on the MHD web site. There’s still nothing on the B58 release. Any idea how much longer?
Default 02-23-2019, 05:34 PM
We have the BETA software and are starting to play with it.
Car: 340ix
Default 02-23-2019, 06:19 PM
Is it true we need a android device for the mhd tune? Or we can still do everything through a laptop
dRDiesel's Avatar
Car: BMW
Default 02-23-2019, 08:33 PM
B00st!!!
| 2013 BMW 335is |
dragy dragy is offline
Car: BMW 320i
Default 02-24-2019, 05:47 AM
Any plans for B48 BEF?
BMW After BMW
Car: BMW M240i
Default 02-25-2019, 01:21 PM
This. ^^^^^^^^
Pretty big update/news!
Car: 340ix
Default 03-02-2019, 12:29 AM
How is it going with the beta software
BMW After BMW
Car: BMW M240i
Default 03-02-2019, 08:24 AM
Android only for now: f30.bimmerpost.com/forums/showthread.php?t=1583722
You will need the K+D-CAN cable, an Android device, and a purchased MHD license from the Google Play store to install any MHD-based flash maps. I am sure BMS will release instructions, but typically you flash MHD Stage 0 using your Android device and the cable, then flash the BMS BEF map using the same MHD/Android.
Beyond that, wait for BMS instructions in terms of what to do with the JB4 app & which JB4 maps to use specifically for the B58 BEF.
Jay1312 Jay1312 is offline
Jay1312
Car: BMW 320i and M5
Default 03-26-2019, 01:53 AM
Where are you getting the ethanol E30 from in the UK and secondly are the fuel lines safe running E30 consistently from the tank?
jalkster jalkster is offline
Car: 340i M-Sport
Default 03-26-2019, 07:36 AM
People are running full e85 on stock fuel system.
340i 8AT DME Stage 2 | JB4 | AP Intake | ER ** | Meisterschaft GTC | Ohlins R&T | Ground Control Camber Plates | MP LSD | 437M | RE-71R
N54_liam N54_liam is offline
Car: 135i e82 n54
Default 04-17-2019, 02:48 AM
How will the BMS BEF compare to the HCP flash already available?
Current: M140i
Previous: N54 - Forge BOV - Forge Chargepipe - Airtec Intercooler - DCI - VRSF - JB4 - LCA
