naoaki's Avatar
naoaki naoaki is offline
Default Twin solenoid math - 10-19-2018, 04:50 PM
Hey, guys I am using direct port meth. I also have a 7th injector. I thought that if you separated the 7th injector from the direct port system and placed it using another solenoid, it was released from the 7th long piping and the reaction speed could be improved. The point I care about is whether the FSB can provide enough voltage to properly move the two solenoids. Does anyone know an example of using two solenoids with FSB? Thanks in advance for all the responses in advance.
BMW 2007 E90 335i
Default 10-22-2018, 08:08 AM
Where are you putting that 7th injector? Why?
Ron Vogel Ron Vogel is offline
Car: E61 535Xi
Default 10-22-2018, 06:27 PM
You would want a 7th injector before the TMAP.....mostly for the "T" part of it
naoaki's Avatar
Default 10-23-2018, 01:53 AM
I'm putting seventh behind the direct port system. I wanted to use two solenoids because I want to shorten the pipe because it is long. I thought that there was a possibility that the reaction rate etc. would rise as well. How is that?
BMW 2007 E90 335i
