Default JB4 for Alfa Romeo Giulia - 10-12-2018, 09:32 AM
*** We're going to use this thread as the general Alfa Romeo Giulia JB4 informational thread including posting the install guide, mapping guide, software, firmware updates as we release them, logs, and general discussion. ***
Order Here!
By default the JB4 ships on map1. For higher boost map, logging, firmware updates, and other features, you'll need a JB4 Mobile adapter for wireless connection to your phone or a BMS data cable for wired connection to a laptop.
JB4 Mobile Smart Phone wireless connection directions Click here.
BMS data cable hard wired directions Click here.
Installation guide Click Here
Map guide as of v3 firmware (selected via JB4 Mobile/laptop interface. Map1 is the default map)
Map 0: JB4 disabled
Map 1: 5psi over stock tapering to 2psi at redline.
Map 2: 5psi over stock tapering to 3psi at redline
Map 3: Unassigned
Map 4: Unassigned
Map 5: Unassigned
Map 6: Unassigned
Map 7: Unassigned
Map 8: VALET / Low Boost map
JB4_ALFA_3:
1) Adjusted IAT scaling, not sure if it's fully accurate yet but much closer.
2) Moved VALET map to map8, minor revisions to map1 and map2.
T1) Minor change to IAT scaling to try to get it more accurate.
JB4_ALFA_2:
1) Enabled CANbus engine allow the JB4 to now access the full suite of engine data including engine speed, ignition advance, air/fuel ratio, fuel trims, throttle & pedal position, engine temperatures, fuel pressure, and more. Requires OBDII cable to be attached to JB4. See install video below.
JB4_ALFA_1:
1) Fixed bug with false alarm fault code related to IAT/TMAP sensor.
How to update firmware:
For firmware updates if having issues we suggest you turn off WiFi, change upload timeout to 25, and set your phone next to JB4 box under the hood.
Default 10-15-2018, 08:33 AM
Ready for purchase, will have some dyno numbers soon.
1/8 mile testing gained +3mph with just map 1, about 30whp gain.
http://www.burgertuning.com/alfa_rom...nce_tuner.html
stealth_alfa stealth_alfa is offline
Car: Alfa Romeo Giulia Ti
Default 10-18-2018, 10:02 AM
Just purchased it on Monday and came in today! I'm new to JB4s so I apologize for my ignorance but is the best way to produce the most power out of this is with e85?
Default 10-19-2018, 09:33 AM
It's still a new product. For now I'd just install it, run map1, and mix in 2-3 gallons of E85. As we get more of them out there we'll provide higher power map suggestions.
Default 10-22-2018, 08:49 AM
Did you install it yet?
CableMan67 CableMan67 is offline
Car: 2018 Alfa Romeo Stelvio Ti
Default 10-25-2018, 03:00 PM
Looking to get JB4 for my 2018 Alfa Romeo Stelvio Ti, any numbers yet? Also does this Giulia intake fit the Stevlio? When will it be available?
Default 10-25-2018, 03:22 PM
Stelvio and Giulia should be identical in Jb4 and Intake system. Jb4 is ready now, Intake system will be out in a month.
If you can upload a picture of your engine bay that would be the best. You can also check our install guide!
Default 10-25-2018, 04:14 PM
Not yet, unfortunately, my car is being fixed in a body shop for some minor damage but I will install it and attempt to make a custom map for it on map 6, with a ******** too that is currently being fabricated for me.
Default 10-25-2018, 04:15 PM
down pipe *
Default 10-25-2018, 06:17 PM
Here's a picture on my Stelvio engine bay, looks like intake from Giulia should fit from the video.
Do you have price?
not.qv not.qv is offline
Default 10-26-2018, 09:23 AM
hey! cool to see new products in the market.
are you guys only putting one map out??
...how long till we can get some sound tuning?
I've been wanting gunshots or at least a good burble since day one.
Martyn10 Martyn10 is offline
Car: Alfa Romeo Giulia ti Sport
Default 10-30-2018, 11:40 AM
I have a question. I have already fitted an EC V2 intake system on my Giulia. Does this pose any issues with adding the JB4 tune with that already in place? Would I still get a 30whp power increase? Does the JB4 map 1 change the max RPM?
Default 10-30-2018, 01:29 PM
Not at all, the intake would only help you get more gains! Jb4 does not change max RPM.
Default 11-07-2018, 07:35 AM
Any update on how this tune is working and/or numbers?
Also is the intake getting released this month, next month?
Default 11-07-2018, 05:40 PM
We should have some dyno numbers soon actually. We have lots of positive feedback actually already. Traction is a huge issue for the RWD so we know it's making power
Intake should be released end of month.
Default 11-26-2018, 01:38 PM
Any update when intake for Giulia/Stelvio will be available to order?
turbologist's Avatar
turbologist turbologist is offline
Car: E90
Default 12-08-2018, 02:09 PM
Hey Terry, any updates on working out the bugs and such?
What’s the feedback you’ve been getting?
You wanna street car or you wanna race car?
Alfa Romeo QV, Ferrari 488GTB: Street Car
DC2: Race Car
Default 12-08-2018, 07:31 PM
We've gotten a few out, waiting for more customer logs and feedback to come in.
Car: E90
Default 12-08-2018, 10:13 PM
Sounds good my man... Looking forward to some positive news.
If you need another guinea pig, pm/ email me...
DC2: Race Car
Default 01-03-2019, 08:09 PM
Payam,
Any update on the release of the intake?
Default 01-14-2019, 04:31 PM
Payam,
Intake is released!
Alfa Romeo 2.0T - BurgerTuning.com
Default 01-14-2019, 04:32 PM
Still early days, couple reports of a startup throttle code we need to address. The more testers the better. Just engage us via email if any issues come up so we can work with you on the firmware.
Default 01-30-2019, 01:52 PM
Sold a few already, where you guys at? Post some sound clips and pictures
Lifted07Duramax Lifted07Duramax is offline
Car: bmw 335i
Default 02-02-2019, 06:52 PM
dyno numbers?
VRSF 5" FMIC, VRSF *********, BMS DCI, JB4 G5 ISO, RB Turbos, BMS Flash, Muffler Delete
Default 02-02-2019, 06:59 PM
Don't have any for the intake, at least not yet.
If anyone has time to test a JB4 firmware update email me, I have an idea that may get CANbus working.
