Default Mercedes AMG C63 & C63S JB4 - 09-18-2018, 01:25 PM
This is the central point of contact for all Mercedes Benz AMG C63 & C63S JB4 related information. Anything from install directions, to firmware updates, to settings, to frequently asked questions. Any and all relevant info is linked in this post. If you come across something missing from here be sure to let us know.
Order the full JB4 system here.
Map changes, datalogging, updates are done using the BMS data cable or the JB4 Mobile bluetooth kit.
JB4 Mobile Smart Phone wireless connection directions Click here
BMS data cable hard wired directions Click here
Map Guide as of V2 Firmware:
Map 0: Stock operation, JB4 disabled
Map 1: Default performance map, 4psi peak over stock, taper to redline
Map 2: 5psi peak over stock, taper to redline
Map 3: 6psi peak over stock, less taper to redline, suggested for E85 mixture or octane booster
Map 4: 6.5psi peak boost request over stock, less taper to redline, requires unleaded racing fuel or E85 mixture
Map 5: 7psi peak request over stock, less taper to redline, requires unleaded racing fuel or E85 mixture
Map 6: Custom additive boost profile, boost request over stock
Map 7: Progressive WMI (water/meth) mapping based on boost additive setting and WMI flow
Map 8: Low boost VALET / Safety map
We suggest all vehicles email in or post a log on map1 so we can confirm all is well BEFORE attempting to run higher power maps.
User Adjustments
While there are several user adjustable parameters, for now we only want customers to adjust the boost by gear settings. These are critical to improving traction off the line and something no other C63 tuning system offers, so take advantage of them! Enter the amount of boost to reduce per gear. For example, entering 3psi in 1st will reduce 1st gear by 3psi regardless of the performance map selected. We suggest values of 4psi in 1st gear, and 2psi in 2nd gear, to start. Most vehicles will not need to limit boost in 3rd gear.
Optional BCM (Boost Control Module)
The JB4 attaches to the manifold TMAP, chargepipe MAP, and fuel pressure connections on each side of the engine, for six total connection points plus OBDII for CANbus. These fundamental attachments provide the JB4 with a wide range of tuning adjustment. For vehicles targeting very high boost levels using heavy bolt modifications, WMI, larger turbos, and/or very high octane, additional wastegate dutycycle may be beneficial in driving boost up to the higher target. To increase wastegate dutycycle the BCM add on harness is required. Although not currently available it will be $199 and plugs in to the JB4 harness and the boost control solenoid under the vehicle for direct wastegate control.
V4:
1) Various minor tuning changes
2) Increased sampling rate for smoother performance
Default Settings:
How to update firmware:
For firmware updates if having issues we suggest you turn off WiFi, change upload timeout to 25, and set your phone next to JB4 box under the hood.
Track Results:
Dyno Results
Zeid Nassar Zeid Nassar is offline
Car: Bmw M4,Amg c63s
Default 09-22-2018, 06:17 AM
Good results so far��, any plans to push it more with WMI and ********* ? Let’s see what this monster can do������.
Any news for the release date? Can’t wait to remove the racechip and put the jb4 on it
notabenex notabenex is offline
Car: MB W205 C250
Default 09-27-2018, 11:37 PM
Please take my money!
Any release date? Will it be 2018?
Default 09-28-2018, 05:11 AM
Probably in a month or so
Car: MB W205 C250
Default 09-28-2018, 05:13 AM
Sounds amazing. I am willing to do the testing in EU. I am close to dyno.
Car: MB W205 C250
Default 10-10-2018, 01:34 AM
Any updates?
Default 10-10-2018, 08:30 AM
JB4 and intake are in production. Will post when first batches are ready.
Default 10-10-2018, 10:25 AM
Need to do more testing for intakes
Default 10-11-2018, 07:40 PM
Headed back to the dyno today for additional intake testing, and also some new JB4 mapping we're playing with to best take advantage of a race gas mixture. Put down lots of 570whp runs with a best of 577whp.
Default 10-11-2018, 08:45 PM
Is that basically a 30-40whp delta with intake on top of the tune? Crazy how restrictive the intakes are, it's holding back so much even tuned!
Default 10-12-2018, 08:36 AM
Intake really opened it up, when combined with direct solenoid control via the JB4 for additional boost, look out. Once the JB4 & intake are released we'll get working on an integrated WMI kit.
Default 10-12-2018, 09:32 AM
So far this thing is on par with my M4 like exactly. Can you line those graphs up later?
Car: MB W205 C250
Default 10-13-2018, 09:27 AM
Would there be a chance to bypass speed limiter?
I have EU C63 and I can easily reach 257kmh on speed daily when going to work
Default 10-13-2018, 09:43 AM
We're not planning on that at least not initially.
jlcf22 jlcf22 is offline
Default 10-15-2018, 09:43 AM
so these cars have potential to make more power than the m3 f80/f82? looks like the c63 would make 650whp easily with meth, e30 mix and some kittie cats?
Default 10-15-2018, 10:02 AM
Similar potential I think to the S55.
Car: MB W205 C250
Default 10-21-2018, 12:41 AM
Checkin this thread 5x a day, just to get it ASAP B-)
Default 10-21-2018, 09:57 AM
Don't worry we've got a batch of 250 under production. The first go around is always a little slower. May be a few weeks. But we'll post as soon as we have them.
In the mean time we'll be durability testing the JB4 tuning and intake as Shift Sector next weekend, and NoFlyZone a couple weeks after.
Jon @ BMS's Avatar
Jon @ BMS Jon @ BMS is offline
Administrator
Default 10-28-2018, 01:38 PM
We got lots of good data at the Shift Sector event. We'll be integrating what we learned into some changes to the prototype mapping. Hit the speed limiter on all the JB4 runs. Map 0 which disables the JB4 ran 11.5mph less at 144.4!
All runs on a mix of about 80% race gas with the BMS intake prototype installed.
It is the sole responsibility of the purchaser and installer of any BMS part to employ the correct installation techniques required to ensure the proper operation of BMS parts, and BMS disclaims any and all liability for any part failure due to improper installation or use. It is the sole responsibility of the customer to verify that the use of their vehicle and items purchased comply with federal, state and local regulations. BMS claims no legal federal, state or local certification concerning pollution controlled motor vehicles or mandated emissions requirements. BMS products labeled for use only in competition racing vehicles may only be used on competition racing vehicles operated exclusively on a closed course in conjunction with a sanctioned racing event, in accordance with all federal and state laws, and may never be operated on public roads/highways. Please see http://www.burgertuning.com/emissions_info.html for more information on legal requirements related to use of BMS parts.
Car: MB W205 C250
Default 11-10-2018, 01:17 AM
Hi, would it be ready before christmas?
Default BMS 2018 C63 JB4 Dragy Testing - 11-18-2018, 10:53 PM
Was great boost weather tonight (55F) so decided to head over to the private track for a few pulls.
Testing was done in our 2018 C63 base model, JB4, BMS intake, 30% E85 fuel. JB4 tuning was set to map5 (+7psi over stock peak), launch mode active, and to improve traction I used the JB4's boost by gear option to reduce boost by 4psi in 1st.
Overall happy with the best run of 11.5@127mph. If we could get that 60' down in the 1.7s range where it should be, look out!
Default 11-19-2018, 09:11 AM
This is very impressive, that trap speed is wow.
Default 12-14-2018, 10:22 AM
Release date?
Default 12-14-2018, 11:57 AM
Originally Posted by jlcf22
Release date?
As long as they stay on schedule it looks like next week from what I have here in my notes!!
spikiii's Avatar
spikiii spikiii is offline
JB4 addict
Car: powered by JB4
Default 12-15-2018, 03:40 PM
This is AWESOME~!
I just offloaded my 340i and stepped up into a C63s. Having been with you guys for ages in my bimmer, i thought switching brands would mean loosing out to another tuner.
Have been reading up about tuning options for the w205 C63S and for piggyback variants, there's not a huge number of them out there. The one thing they keep mentioning is a "difficult installation" or "leave 3-5hrs aside to install" - @Terry, @Jon, @Payam, how does this install compare (effort/diffuclty-wise) to the B58 install?
If/When you guys release this (happy to help test too - I was on your first beta batches for the B58 too) ... so much joy right now :D :D :D Can you let me know indicative price too?
