JDARCO JDARCO is offline
Car: 17’ BMW M240xi
Default App Not Reading Codes - 09-01-2018, 07:57 AM
Hi, just installed my jb4 with bt. Was able to connect to jb4 and update to most recent file but my car is throwing a code and the app keeps failing when trying to read the codes.
I double checked all my cords, everything is connected properly. Is this a bad obdII cord?
Appreciate any advice
Default 09-01-2018, 08:53 AM
Does logging work in the app?
Car: 17’ BMW M240xi
Default 09-01-2018, 11:03 AM
Just did two logs, one on map 1, the other on map 2. Power is clearly there but doesn’t look like information is in the graph. Also not getting any information from the display screen besides what map I’m running.
Default 09-01-2018, 12:50 PM
I can see map1 is working to boost performance, but yes none of the OBDII data is coming through. Could be a couple things.
1) Issue with OBDII cable
2) New software update from BMW that broke the logging in some vehicles, we're working on a firmware fix for that.
Car: 17’ BMW M240xi
Default 09-01-2018, 02:03 PM
Is it possible to have a new cable sent to me?
Don’t mind waiting for the update as long as driving the car with the codes doesn’t damage anything.
New power is awesome despite these issues, thanks again for your help.
Default 09-01-2018, 03:19 PM
Sure email our support and they can sort that out for you!
Car: 17’ BMW M240xi
Default 09-01-2018, 04:04 PM
Sorry, one last question. Can map 3 be run on 93 octane or does it require higher than 93 octane.
