Juiced46 Juiced46 is offline
Car: 2011 335xi M sport
Default Does U.S. JB4 clear codes? - 08-05-2018, 10:05 AM
I tried clearing codes today with no luck through the cluster software. Will a U.S. version of the JB4 clear faults through the cluster or JB4 software?
Furthermore, the car set a Tmap short circuit fault today, CEL and car feels and sounds off. Hearing a loud hissing noise @ WOT. Sounds like the wastegate is just dumping. This is on MAP 3.
2015 Yas Marina Blue M3
Default 08-05-2018, 12:14 PM
Yes you can delete fault codes in the USA. But, if there is a problem with the car then the codes for that problem won't clear.
So check your TMAP, maybe its loose, chargepipe blew off, etc?
