Default JB4 for Honda Turbo 1.5L & 2L Applications - 06-15-2018, 08:56 AM
Order Here: https://burgertuning.com/collections...onda-civic-jb4
Install Guide: http://www.burgertuning.com/instruct...bo_install.pdf
We picked up a tenth gen 2018 Civic Sport CVT 1.5L turbo for product development. Immediate development includes a JB4 Honda Turbo tuning system, BMS Performance Intake, & Pedal Tuner module.
While there are already various flash tune options out for the vehicle flashing leaves a trace behind not only in the ECU but in the vehicles various modules, so for those who don't wish to flash we think there is a great opportunity for a well developed tuning system like the JB4. And down the road we plan to add WMI integration and other features even the flashed guys might find useful!
We'll use this thread for JB4 firmware updates, map guides, results, and log evaluation.
Honda Map Guide as of v2 firmware:
Map 0: Disables JB4 all together
Map 1: +3.5 psi, default map. Suggested for 91+ octane.
Map 2: +4.0 psi, Suggested for 91-93 octane
Map 3: +4.5 psi, Suggested for 93+ octane
Map 4: +5.0 psi, Suggested for 30% E85
Map 5: +6.0 psi (30% E85 or race gas, alpha testing, seems OK so far)
Map 6: User Adjustable Custom Tuning Map
Map 7: +9.0 psi (30% E85 or race gas, alpha testing, use at your own risk!)
Map 8: VALET/Low Boost Map
FUD Bit Settings as of v4:
FutureUseD on User Adjustment Page:
bit0 -
bit1 -
bit2 - Turn on to disable JB4 hot/cold water & oil temperature protection
bit3 -
bit4 -
bit5 - Turn on to disable over boost and run lean safety systems
bit6 - Turn on if vehicle has an aftermarket flash map loaded to the ECU
bit7 - Turn on to enable more aggressive gas pedal based boost mapping
Firmware:
Note TypeR requires special firmware with "TYPER" in the firmware name and has a revised map guide. Currently only map1 and map2 is enabled for the TYPER firmware.
JB4_HONDA_5:
1) Setup firmware split for TypeR from normal Civic models. TypeR now has dedicated firmware with "TYPER" in it's name.
2) Adjustments to top end taper on all maps, determined it's best to taper boost down over 6000 rpm. CVTs shift better this way, and manuals normally shift by 6000 rpm on their own.
3) Setup map7 as full "send it" map. Not sure how safe it's going to be so use with extreme caution.
JB4_HONDA_4:
1) Enabled FutureUseD adjustment options outlined above.
2) Adjusted interface boost scaling, after updating firmware disconnect and reconnect to reset interface scaling.
3) Added in over boost and run lean safety systems. If boost exceeds the user defined "boost safety" setting for more than 1 second the JB4 will revert to map0. Similarly if AFR goes leaner than 14:1 at full throttle for more than one second the JB4 will revert to map0. These safety system can be disabled in the FutureUseD bit5 if needed for diagnostic purposes.
4) Relocated "knock control" under IGN-2 and adjusted "TimingAVG" to reflect a new 0-10 metric for knock control. It's scaled such that 0 = 0.50 10 = 1.20 which I think is more intuitive. We'll keep an eye on it and users can continue to reference whichever scaling they prefer.
5) Various minor logging parameter fixes.
6) Adjusted pedal to boost mapping to be more conservative/smoother. The previous more aggressive mapping can be enabled under FUD.7.
7) Enabled hot/cold protection. Boost will remain at stock levels until water temp is > 160f degrees and if water temp goes above 250f degrees boost will decay down to stock levels. Can be disabled under the FUD.2 bit.
JB4_HONDA_3:
1) Changed how RPM & Pedal input are logged on the back end. Should be seamless to users.
2) Added WGDC logging parameter
3) Added long term fuel trims under fuel_trims2, using same scaling as fuel_trims. 25 = 0%, 50 = +33%.
4) Programmed a mystery temp parameter under OilTemp. I think it represents temperature of air coming off the radiator. Not sure yet. Will keep an eye on it. Still don't have the actual oil temp logging parameter yet.
JB4_HONDA_2:
1) Enabled additional CANbus channels including air/fuel ratio, fuel trims (scaled 25 = 0, 0 = 34%, 50 = + 34%), ignition advance, IAT (charge air intake temps), high fuel pressure, and more!
2) Revised maps to reduce top end boost taper.
3) Enabled additional higher boost maps for testing purposes only, ideally for those on high quality fuel (e.g. E85 mixtures or octane booster) to start. Later when we've collected more data we'll open up these maps for pump grade fuels.
JB4_HONDA_1:
1) Enabled CANbus with basic information for engine speed, vehicle speed (to allow boost by speed settings), water temperature, and pedal input. More coming! To activate just update firmware and attach the included OBDII cable to the JB4 harness. Install photos for OBDII coming soon.
1C) Adjusted boost scaling/zero point for more accurate boost display.
JB4 Mobile Smart Phone wireless connection directions Click here
BMS data cable hard wired directions&software Click here
JB4 Mobile DEMO:
How to route OBDII:
Dragy Testing:
Dyno Testing:
How to update firmware:
For firmware updates we suggest you turn off WiFi, change upload timeout to 25, and set your phone next to JB4 box under the hood.
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 06-15-2018, 09:04 AM
Very impressed by this 1.5l engine. This 10th generation civic drives pretty good for what it is.
217 wheel hp now makes it even better
Default 06-15-2018, 09:34 AM
Also works on the 2018 Honda Accord with the same 1.5L Turbo engine!
Ando @ BMS's Avatar
Car: bmw 335i
Default 06-15-2018, 10:32 AM
These is the current application list.
1.5L turbo Honda Civic
• 1.5L turbo Honda Accord
• 1.5L turbo Honda CR-V
• 1.5L turbo Honda Fit
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2021 M550i xDrive
Default 06-15-2018, 11:00 AM
Theres a 1.5L turbo Fit? I thought it was N/A?
Mike Levy
2022 Black Sapphire X3 M40i
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 06-15-2018, 08:53 PM
Nice to see you guys expanding the market and reaching other platforms! It's tough competition though with hondata and ktuner ruling this section and offering flexfuel, and other crazy features for pretty cheap.
*cough cough* offer something for the cla 45 amg
Mods: Stock for now
Default 06-15-2018, 09:03 PM
Yes tons of flash tuning out for them. But not everyone wants to instantly void their warranty/lease agreement by flashing the car. And the JB4 has resale value. It's a good option for someone looking for a quick install/remove type product that adds a decent amount of power and can be resold down the road when wanted.
Lifted07Duramax Lifted07Duramax is offline
Car: bmw 335i
Default 06-17-2018, 11:08 AM
380lbs of torque?
VRSF 5" FMIC, VRSF *********, BMS DCI, JB4 G5 ISO, RB Turbos, BMS Flash, Muffler Delete
Default 06-17-2018, 11:13 AM
It's a CVT (continuously variable transmission) so I don't think the torque reading is accurate. We just left it on there so you can see a relative difference vs. stock.
Mike_L's Avatar
Anti-Social
Default 06-17-2018, 12:47 PM
It’s also very weak. You’re gonna hit its limits much sooner than you would with the manual or a real automatic.
Mike Levy
Car: bmw 335i
Default 06-17-2018, 01:13 PM
I’ve heard that a lot. CVT is a lot weaker but advantages in other areas. So it’s true? Mike didn’t know you were in here. Been following you for so long from my duramax days lol
Mike_L's Avatar
Anti-Social
Default 06-17-2018, 03:50 PM
Its true.
I don't think I'm the Mike you've been following. I never had a Duramax. Are you thinking of Mike Litsch from DiabloSport?
Mike Levy
seven0five seven0five is offline
Car: Audi A4
Default 06-19-2018, 07:26 PM
After using a JB4 for Audi EA888 Gen 3 with great results for several months in my car, this has been a very welcome addition to my wife's Honda.
I've been running the JB4 for the Honda 1.5L Turbo in my wife's Civic Touring CVT for a week now and am really impressed with the results. The CVT has always been and still will be the weak point of this car, but with the JB4 the acceleration is noticeably quicker and I find the drive much more enjoyable now.
Looking forward to the full CANbus support!
Default 06-19-2018, 08:40 PM
Glad to hear!! We're working on it!
Default 06-20-2018, 07:26 AM
Agreed! It makes a huge difference in tq and peak power to be honest.
Car: Audi A4
Default 07-28-2018, 01:46 PM
Any news on the CANbus support?
Car: bmw 335i
Default 08-04-2018, 12:47 AM
Was this on a stock civic?
If so what everything run ok if there were a full exhaust and intake plus this tune? Or would it need adjustments
Car: bmw 335i
Also have the log for this car?
Also wanting to see what the boost was
Thinking of getting one for a 2nd car
Default 08-04-2018, 08:36 AM
All stock. The JB4 only logs boost for the model currently, for some reason don't see the logs in the dyno file. But we're adding 3-4psi over stock. I think stock was around 11psi.
PR3CI5N335i's Avatar
Need4Speed
Car: 2010 E90 335i M-sport
Default 08-07-2018, 10:39 PM
T, any plans to make a JB4 for the 2.0T in the 2018 Accord Sport? Thinking of picking up one as a daily. Stock has 252hp/273tq
SOLD - FBO N54, Pure Turbos stage 2, TFT inlets, JB4/MHD, EOS intake manifold w/PI, Fuel-it stage 3
Default 08-08-2018, 09:40 AM
I'm sure we will eventually. Just need to get one down here to verify
Dan Villa Dan Villa is offline
Car: Accord Sport 2.0t 10AT
Default 08-17-2018, 10:37 PM
Ive been speaking with Ando G and says it should work on the 2.0t i sent him pics of my sensors and they look the same as the 1.5t. Im about to order to test it out.
Car: Audi A4
Default 08-18-2018, 12:01 PM
Any development on CANbus support yet?
Default 08-18-2018, 03:23 PM
Nothing yet, sorry. But it's on our radar!
Default 08-18-2018, 03:30 PM
Terry can you confirm this will work on my 2.0t?
