Flyknit Flyknit is offline
Car: 440i GC
Default JB4 B58 help - 04-08-2018, 04:48 PM
I'm getting the following message and the map keep resetting to map 0. Did anyone encountered this before? Car is stock except Akra exos.
Tried to use an invalid map (122). Setting map to 0.
Default 04-08-2018, 08:21 PM
Tried selecting map1? Perhaps an issue with your blue tooth adapter or device.
Car: 440i GC
Default 04-08-2018, 09:07 PM
After selected map 1, the car runs on map 1 (I verified itís running map 1 from mobile) for a while (5mind - 20mins) and then it reset back to map 0.
This happens to my friend 340i as well.
I have attached the log (tis time it show 125) if that helps. It seems once it showcrhe error message, the logging stopped as well.
Default 04-09-2018, 10:41 AM
Best to post in the JB4 mobile support thread so they can help you out.
http://www.n54tech.com/forums/showthread.php?t=21742
Car: 440i GC
Default 04-10-2018, 04:24 AM
Ok. I thought this section is for support and help.
Default 04-10-2018, 03:18 PM
For JB4 logs and performance...yes, for JB4mobile, not so much. They have a dedicated thread for that.
Car: 440i GC
Default 04-10-2018, 03:35 PM
Why is this related to mobile?
I would have thought this is related to the JB4 unit or firmware (or something not set correctly) that cause Jb4 to reset to map 0. Manually set the map via the signal stalk also result in the map reset back to map 0.
