(#51)
YoungMulla's Avatar
YoungMulla YoungMulla is offline
Car: 2012 BMW 135i 6mt
Default 08-26-2018, 07:28 PM
Ahhh ok. I do have an f chassis. I had a 335i with a jb4 loved it. Can’t wait to see what jb4 does with the twin scrolls. Is there anyways you Can you point me in the right direction for this forum. I’m can’t seem to find much info on it.
Thanks you!
Default 08-26-2018, 07:40 PM
Originally Posted by YoungMulla
Ahhh ok. I do have an f chassis. I had a 335i with a jb4 loved it. Canít wait to see what jb4 does with the twin scrolls. Is there anyways you Can you point me in the right direction for this forum. Iím canít seem to find much info on it.
Thanks you!
http://www.n54tech.com/forums/showthread.php?t=45226
DJTones DJTones is offline
Car: M550i
Default 08-31-2018, 06:57 AM
Hi Terry. Unfortunately I am still having some issues after removing old firmware and installing the hex file posted above. I have a few questions that might get to the bottom of it. My car 2018 M550 is back at the shop today to check the JB4 cables:
1) should all gauges be working in the App? Currently only Map 1 and Boost gauges work and move with acceleration. Other Maps are not working and all other gauges show zeros
2) after connecting to the app and then starting the car, I receive a drivetrain error on the car display. The kit seems to be connected since I can feel and hear a difference but I have no way of visually confirming it with the app
3) I recorded a log which I can send in case it will help you. Just let me know how I can send to you
4) I mentioned in a previous post, that I had a local shop install the kit and we ran a dyno pre and post installation and it showed and increase of 50hp and 50torque using Map 1. Other maps didn’t add performance
Default 08-31-2018, 08:49 AM
Post a JB4 log on map1 so I can check the settings and firmware. If OBDII is installed, RPM and other gauges should be showing in the app.
Car: M550i
Default Jb4 log map1 - 08-31-2018, 04:07 PM
Attached
Default 08-31-2018, 04:21 PM
I see. Firmware looks OK.
Also noticed on map2 without CANbus we set it to default to 1psi. I'll change that to 5psi.
As a quick test with engine running, press the prime button a couple times on the WMI page in the app, and see if that gets CANbus active. We have a reset CANbus in there combined with the purge mode.
Car: M550i
Default 09-01-2018, 04:26 PM
I had the kit reconnected by my local shop and no luck with the dials working in the app. It also only connects about 50% of the time now. The funny thing was when I picked up the car, the RPM gauge starting working but has not worked since. Only Boost and Map gauges are working (see pic while I was driving). I may have to send the kit back to Burger and try a replacement. Any other advice would be greatly appreciated.
Default 09-01-2018, 09:34 PM
Would be a waste of time to exchange the hardware as these are clearly software related issues.
You'll need the updated app if it only connects half the time. You can contact JB4 mobile for it directly. iOS updates are always 6 months behind thanks to Apple.
If the RPM gauge was working in the app at some point, then what changed exactly? Nothing else on CANbus or in OBDII port like a vent gauge?
Car: M550i
Default 09-02-2018, 12:32 AM
Thanks, I just emailed Donnie for this and Iíll revert back. I definitely had software issues starting from the very beginning with dozens of errors and timeouts in the firmware update process
Default 09-02-2018, 12:51 PM
Was there a previous JB4 firmware you had that logged normally?
bjorns bjorns is offline
Car: bmw m550 ix
Default 10-21-2018, 10:07 AM
i am using map 2 on jb4 hiring 3,82 sek 0-100km/t on sea level. temperature 12 degrees celsius can i expect more .
Car: bmw m550 ix
Default jb4 - 10-21-2018, 10:12 AM
this what i got with jb4 map 2.
Car: M550i
Default 10-21-2018, 11:11 AM
On an M550?
Tsela_f80 Tsela_f80 is offline
Car: F80 M3
Default 11-20-2018, 10:50 AM
has anyone had their car on a dyno yet with a JB4?
Default 11-20-2018, 09:35 PM
Since it's AWD not that many people dyno them, and those that do don't use dynojets so the numbers don't mean anything anyway.
Car: M550i
Default 11-21-2018, 07:21 AM
Yes, I have. On a Mustang dyno on Map 1 it showed an increase of 50hp and 50torque. Map2 doesnít work and I canít seem to get the mobile app working correctly for 5minths now.
Car: bmw m550 ix
Default map2 - 11-22-2018, 03:27 PM
Originally Posted by DJTones
On an M550?
yes m 550 ix 2018
Default 11-22-2018, 04:48 PM
We've got plenty of guys running higher maps, mobile, etc. Was it something I was helping you with? What's your email address? I'll look it up to see where we left off!
Car: M550i
Default 11-22-2018, 07:09 PM
Hey Terry. Yes, no solution yet. Email is antonioamato@gmail.com
If we can have a call, Iíd appreciate it. The g30 firmware still shows up as F chassis in the log and only boost gauge works. Drivetrain error appears and app fails to read codes
Default 11-22-2018, 09:16 PM
Don't see any emails from you. Who were you working with here? Email in a JB4 log as a starting point.
Car: F80 M3
Default 11-27-2018, 09:11 AM
Hey Terry Question for you.
Is the tune for the M550i still in "BETA" form ?
Default 11-27-2018, 09:34 AM
Technically it has not changed for some time, but because not all features work yet, I think we left the BETA tag on it.
Car: F80 M3
Default 11-27-2018, 12:02 PM
When do you expect all features to be included?
Also would you say map 2 is best for daily use on 93 Octane?
Default 11-27-2018, 01:18 PM
There is no set time frame, development is on going. Normally map1 or map2 is best. Try both and see what you prefer.
Car: F80 M3
Default 12-21-2018, 09:15 AM
Does the jb4 enhance throttle response?
