Manley00 Manley00 is offline
Car: 2020 BMW M550
Default 20 M550 CTS intake log check 3-5 - 04-13-2022, 07:09 PM
Good evening!
Curious if someone would mind looking at this log for me. From my last post Iíve learned a little more about BMW and looking at the data. Outside of my timing drop Iím curious if all else looks ok? This is map 1. Iím not sure I fully grasp the IGN numbers. Whatís do the decimals next to them dictate?
Started at about 3k WOT to 120 (on a closed road).
Iím running 93 here in Texas. Was about 60 degrees.
Car: Evo VIII
Default 04-28-2022, 02:21 PM
Timing appears to be pretty sporadic, do you buy chance have any access to E85 near by?
Car: 2020 BMW M550
Default 04-29-2022, 03:42 AM
Unfortunately I do notÖ. Guess one of the things Iím unsure of. Next to the avgign number. What does the .7 and such represent? I believe my stations here are currently switching out their winter blends.
Also, not sure if this is normal. Iíve got a CTS intake on it now. Iím getting what sounds like flutter at WOT. Iím assuming itís the wastegate doing itís thing. Boost seems fine.
Thanks for taking the time to help!
Car: Evo VIII
Default 05-04-2022, 11:18 AM
Please upload a 2nd to 4th gear log.
Car: 2020 BMW M550
Default 05-08-2022, 09:09 AM
This is exactly what was asked for- I believe. So confused by the throttle closing. This is a light Map 6 with max 3lbs added.
Car: Evo VIII
Default 05-09-2022, 10:28 AM
Please upload another log, but in map 1, and traction control completely off if it wasn't already.
