08 335Ci's Avatar
08 335Ci 08 335Ci is offline
Car: 08 335Ci
Default Bilstein B16 Ridecontrol Coil Over Suspension - 10-15-2017, 06:30 AM
The shocks on my E92 are getting weak and need an upgrade. I'll admit I'm a bit partial to Bilstein, having had a set on my E30.
While doing some research I came across the Bilstein B16 Ridecontrol Coil Over Suspension
The pluses I see, once you set your ride height, there's no crawling under the car to twist a dial hoping it's the right setting.
Please no "I have brand xxx and ...'" I'm looking for comments from owners of this system. Actual experience. I want to know if the system is worth the cost and has it lived up to your expectations?
A follow up:
I went ahead and ordered this suspension from a reputable tuner/racer only to find .... this setup isn't in the country yet, and won't be until sometime (in Jan. ?). Also if it's not in stock you won't be seeing it until sometime next year. Bilstein isn't shipping to the US until then.
Totaled by a careless driver:
'08 E92 335, M sport option
