Default ACF 6266 + Meth Dyno - 05-11-2017, 03:55 PM
Had a chance to tune a customer car today running an ACF 6266 twin scroll kit, 50% E85, WMI with dual CM10 nozzles. Manual trans and the usual bolt on mods. Overall a fairly inexpensive and simple setup. Tuning via JB4 and BimmerBoost back end flash map. Running map8 progressive meth safety map with a 65 additive.
As you can see the limiting factor was fueling... Port injection in this cars future. Easily another 50whp in this little 6266 G2 and it spools really well.
Also the customer did not like the linear throttle mapping we have in our default maps so I gave him a more aggressive non-linear mapping. I'm going to be adding it to the default maps as a map option but if anyone does not like the linear mapping we have now in the single turbo firmware drop me an email and I can shoot over a more aggressive mapping you may prefer.
rileyg rileyg is offline
Car: e92 335i
Default 05-11-2017, 05:10 PM
Nice results. That's a pretty sweet set up for the money. Anxiously awaiting results for the upcoming bottom mount acf kit.
alexis485's Avatar
alexis485 alexis485 is offline
Car: 2011 BMW E92
Default 05-11-2017, 07:09 PM
Nice numbers!
Terry, I'll be running Stage 3 turbo in less than month. Do you have that same firmware for N55 E series?
2011 E92 ABR N55 Built Motor | ABR Built 6AT | Big Boost 3.4 Turbo Kit | JB4 + MHD | xPH Stg3 Flash | Fuel-It Stg 3 LPFP | Fuel-it PI Kit | COBB Exhaust | E85 |
weebles weebles is offline
Default 05-12-2017, 12:31 AM
Stage 2 LPFP ??
Prototype007 Prototype007 is offline
Car: 2009 335i
Default 05-12-2017, 05:23 AM
6266 is an excellent turbo.
With some additional fueling, I'd imagine this setup will be able to carry the torque curve a little higher in the 4200 - 5300 rpm range as well.
2009 335i Automatic Coupe.
Default 05-12-2017, 06:27 AM
Originally Posted by weebles
Stage 2 LPFP ??
Stage 1 lpfp actually.
dyezak dyezak is offline
Default 05-12-2017, 06:50 AM
If they add additional fueling to allow full e85 I bet things would get really interesting up top
And with MHD's new option coming to allow linear map scaling between a 100% e85 map and a full pump gas map....
Car: 2009 335i
Default 05-12-2017, 07:18 AM
Oh yes. #AllTheGains
CharliesN54's Avatar
CharliesN54 CharliesN54 is offline
Car: 2008 335xi
Default 05-12-2017, 07:46 AM
Am I reading this right? 700hp with no PI?
Single Turbo Z4 that's constantly broken
Default 05-12-2017, 08:24 AM
Back in the day before PI came out this was how we did it. Lots of meth. If this car had race gas instead of E50 could probably support 750whp.
sosn54 sosn54 is offline
Car: BMW 335I Xdrive
Default 05-12-2017, 08:36 AM
How much does this kit cost?
2010 E92 335iX, JB4 G5 ISO, MHD RACE BEF, N20 TMAP SENSOR, VTT GC Lites, VTT Inlets Outlets, BMS DCI, VRSF c.a.t_less D.P., VRSF 7.5" Race FMIC, VRSF Charge Pipe with tial BOV, BMS Meth Kit, BMS OCC, Boost Concept Stage 2 LPFP., 335iS Clutch, MFactory Single Mass Flywheel, CFS High Performance Aluminum Radiator, N55 exhaust.
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 05-12-2017, 08:37 AM
Not necessarily linear...you can have it scale however you want. Also, it allows for separate interpolation for fuel, vs. timing, vs. load, etc.
Stucks Stucks is offline
Default 05-12-2017, 10:03 AM
some guys still use race fuel and meth vs ethanol to this date.
payams car used to make similar power with a similar setup also didnt it?
(stage 1 lpfp i think too lol)
Current: 2008 e92 335i coupe.
Default 05-12-2017, 10:20 AM
I can interpolate on a parabolic curve? Mind blown.
(just kidding )
Venom77's Avatar
Venom77 Venom77 is offline
Car: 335I
Default 05-12-2017, 12:01 PM
Looks like it touches 30psi?
Garrett Gtw 6465, Supporting mods , Mhd/Jb4
BeastMode335i's Avatar
BeastMode335i BeastMode335i is offline
Car: 08 E92 335i
Default 05-12-2017, 12:22 PM
Awesome..
MR F30 335i - MSport - Stock AF
Default 05-12-2017, 05:47 PM
Yes target around 29psi on these pulls.
