Go Back   N54Tech.com - International Turbo Racing Discussion > General > Market Place - For Sale / Trade / Wanted
Reload this Page N54 RB "Ones": TD03L-9 Blade with 14T Billet Compressor kits (for the DIY guys)
Rob@RBTurbo's Avatar
Stalker
Car: 335I
Talking N54 RB "Ones": TD03L-9 Blade with 14T Billet Compressor kits (for the DIY guys) - 02-28-2017, 04:38 PM
For quite a while now there has been a desire for a good Stage 1 product that is cheap... well the time is here.
We started by having some custom "larger than TD04" Thrust Upgrade hardware made to adapt into the TD03 OEM turbos ensuring that these units will have some very robust thrust hardware for limited thrust wear.
We then decided that clipping the OEM TD03L-11 blade would still be a bit flow limited for the large 14T compressor so we custom made new TD03L-9 blade turbines. These units side by side with the OEM turbine shows significant improvements in wheel flow path and thus a better match for the much larger 14T billet compressor.
The end result is a mega cheap new High Flow Stage 1 compressor kit for you all looking for a true better than OEM replacement but with increased performance, availability, AND budget in mind. As these cars are getting much cheaper they are also being purchased by the more mechanically inclined (or younger ambitious) types, so we do realize that budget and DIY is where it is going out there.
Ultimately what you get are 100% OEM MHI CHRA's with all new bearings, seals, clips, and significantly beefed up thrust hardware and high flow wheels so you can transplant them into your old turbine housings and be off without a hitch. But keep in mind that even though they are "Plug and Play" that this is still a cumbersome DIY so you should have some confidence and the tools necessary to tear into your own turbo and make the install. Our intention is to not offer these and then get pounded with support questions along the way, as such we are keeping the cost very low. We are simply trying to provide the part that you need to get back on the road as your OEM turbos take a dump, so please make sure you understand what you are doing before purchase.
The cost is $975 per set plus shipping.
NOTE 1: There is a $300 core charge that is fully refunded when the old compressor kits are returned to RB Turbo. We will need to know the model and drive side of the vehicle at time of ordering. What you see is what you get in the pictures, and is what we expect back to have the core refunded.
NOTE 2: We DO recommend high flow inlets with this product.
NOTE 3: We also have these available in complete turbos as well meaning a complete bolt-on solution with brand new wastegates, actuators, etc. already completed. Please email for details.
All units are all VSR balanced to under .2g to 200k RPM and each unit will come with its own document.
If you are in the USA the cost will be $999 shipped for the set. Our paypal is rob.rbturbo@gmail.com and you can also email the same address with any questions (ie. international shipping quotes, etc).
Thanks,
Rob
08335ibmw 08335ibmw is offline
Default 02-28-2017, 06:17 PM
Might be a stupid question but any warranty? Lol
Jb4 g5 , bms dci, er fmic , active d.ps , bms charge pipe, tial bov -2008 335i
Stalker
Car: 335I
Default 02-28-2017, 07:18 PM
Yes. A 12 month unlimited mileage limited warranty against manufacturing defects.
Stalker
Car: 335I
Default 03-02-2017, 02:00 PM
1 Intro set sold. 3 more available at intro price.
Thanks,
Rob
Stalker
Car: 335I
Default 03-06-2017, 01:47 PM
First intro set shipped over the weekend. Another is built and ready to ship as well.
Wheeliej Wheeliej is offline
Car: 335ix
Default 03-06-2017, 10:18 PM
very interested as I just did a motor swap put turbos from 47k motor and everything was good for an hour of local street riding went home plugged in jb4 not sure what map it was on steering controls not working and made a left on my block hit 5k rpms and smoked out the entire neighborhood leaking oil from ** v-band clamp front turbo so loking for some new turbos I run into this... whats the price for bolt on ready to go. after rebate from cores
Stalker
Car: 335I
Default 03-07-2017, 05:35 AM
If the cores are sent in advance we can do $1475 shipped to the USA for a complete set with wastegates/actuators/etc. on the intro deal. If cores are not sent in advance there is a $300 fully refundable core charge added.
Thanks,
Rob
Stalker
Car: 335I
Default 03-14-2017, 06:56 PM
Another intro set sold- 2 left.
SLlDER SLlDER is offline
Default 03-16-2017, 08:00 AM
How much of an upgrade is this over stock?
Stalker
Car: 335I
Default 03-17-2017, 07:14 AM
This is a "Stage 1" upgrade (hence the name RB Ones), but it is a Stage 1 that is going to perform much better due to all other Stage 1's due to the higher flow turbine.
Thanks,
Rob
Stalker
Car: 335I
Default 03-21-2017, 09:27 PM
FYI only one of these intro priced RB Ones DIY (Stage 1) kits are left now.
crazyyardie's Avatar
crazyyardie crazyyardie is offline
Car: 2007 335i
Default 03-23-2017, 05:45 AM
I'm rhd 135i will I need to machine the housing or anything like that and do you have a upgraded wastegate rattle fix ?
BeastMode335i's Avatar
BeastMode335i BeastMode335i is offline
Car: 08 E92 335i
Default 03-23-2017, 07:30 AM
Great deal Rob.. My replacements are still running awesome, 5k miles later..! I can vouch for Rob and his products and this is a great deal for anyone looking for a stock-like replacement with a warranty..!
MR F30 335i - MSport - Stock AF
Stalker
Car: 335I
Default 03-23-2017, 08:02 AM
Nothing needs to be machined, this kit comes with the compressor covers already machined for you. It is plug in play for the mechanically competent types of the world.
If you are concerned about getting new wastegates done for you then the DIY is not for you. We would suggest looking at our website for complete offerings here:
http://www.rbturbo.com/products/135i/135i
Keep in mind our DIY offerings are for the DIY'ers of the world who like to do their own thing but with limited resources all for the cheap price.
Good deal and thanks sir!
Car: 2007 335i
Default 03-23-2017, 11:50 AM
Sent you email
Stalker
Car: 335I
Default 03-24-2017, 08:01 AM
Sent you email
Responded.
It appears we are now sold out of the intro sets. Cost now reverts to normal DIY pricing as listed in first post.
Stalker
Car: 335I
Default 06-21-2017, 04:04 PM
Update: These RB Ones (Both the DIY compressor kits and complete setup versions) now have about 5 months under their belt and with over 20 sets in use we have not heard of a single issue to date. Thus these RB Ones (Stage 1's) have been a pretty hot commodity and a great overall success.
Thanks,
Rob
Stalker
Car: 335I
Default 08-24-2017, 08:42 AM
Another couple months have gone by and we are now right at 7 months of production of the RB Ones (DIY and complete turbos). To date have sold right at 25 sets and we have heard of no issues with them whatsoever with either the DIY or complete turbos; thus it has been a very solid product.
Car: vw passat
Default 08-24-2017, 07:05 PM
with 25 set sold any dynos or reviews? ive searched and came up with nothing.
Stalker
Car: 335I
Default 08-25-2017, 06:14 AM
Certainly 25 sets sold as we just closed out our first batch of 50 turbines. Pretty wild there's not much of a peep right? Goes to show you what happens when customers are generally happy.
As for results expect them to be just like any other Stage 1 setup but with a certain edge due to the use of a custom 9 blade turbine wheel in lieu of the typical clipped OEM 11 blade wheel.
Rob
Stalker
Car: 335I
Default 10-09-2017, 05:46 PM
Someone posted a couple dyno result threads here:
http://www.n54tech.com/forums/showthread.php?t=49361
http://www.n54tech.com/forums/showthread.php?t=49378
~8 months into production and ~30 sets sold (BOTH DIY and complete turbos)... still not a single complaint/warranty return/etc.
Rob
nyluke124 nyluke124 is offline
Default 01-23-2018, 06:16 PM
Im currently running these with other bolt ons and they feel awesome compared to stock. Havent done a dyno with them yet but could definitely feel a again especially with the silicone inlets also.
07 e90 335i, jb4, e85 BEF, RB ones turbos, RB inlets, vrsf cp w/ tial BOV, vrsf **'s, vrsf dci, circuit werks exhaust, fuel it stage 2 bucketless, vrsf street I/C
Car: 08 E92 335i
Default 01-24-2018, 08:04 AM
Got about 17k miles on mine now, no complaints..!
Stalker
Car: 335I
Default 01-24-2018, 10:47 AM
Sales has slowed quite a bit on these units as we are only at an official count of 32 RB One sets sold at this point at nearly 1 year of production. They have been excellent overall with lack of issues aside ONLY 1 set that came back due to customer/install error to date.
On that note and including our entire product portfolio back for all shipments from 1/1/2017 forward, this is the only set that we have had come back (and it wasn't even our fault). This is out of a cumulative 150+ sets of turbos shipped in that timeframe. Reliability is clearly VERY dialed in these days.
Rob
Stalker
Car: 335I
Default 02-18-2018, 09:06 AM
Bump! Not sure why sales slowed on these things as they are quite the steal! Still doing awesome at right at a year now. Also available in complete ready to bolt on turbos of course.
Rob
