Default F Chassis N63TU JB4 - 02-23-2017, 04:55 PM
Installation is the same as the n63 connecting to each TMAP sensor on the intercooler and running the OBDII cable under the dash. Additionally the MAF connectors (on the to of the engine) must be unplugged for the n63tu JB4 to function properly.
V2 systems now also include optional built in BCM connections which can be attached for those looking to push higher boost levels.
Dyno Testing:
3/17/17: New n63tu dyno record here! http://www.n54tech.com/forums/showpo...1&postcount=28
5/1/17: Broke the 600whp barrier! Yet another n63tu record: http://www.n54tech.com/forums/showpo...1&postcount=64
Firmware:
Note that older system shipped with a V1 EWG board while systems shipped after 2019 include a V2 PWG system. The V1 EWG board does not have BCM connections and will not operate with the V2 PWG firmware.
Map guide:
Map0: JB4 disabled
Map1: Additive map, up to 5psi requested over stock
Map2: Additive map, up to 6psi requested over stock
Map3: Absolute map, 18psi peak, BCM suggested
Map4: Stock with CANbus active for logging and in dash gauges
Map5: Absolute lower torque map ramping up to 20psi at redline, BCM required
Map6: User definable map generally used for diagnostics
Map7: Absolute map, 23psi peak, BCM + fuel control wires required
Map8: Progressive WMI map, boost varies based on meth flow and boost additive on the WMI page. BCM suggested.
Optional fuel control wires:
Not included with the JB4 system but can be added to V2 PWG boards for those looking to run higher boost levels or E85 mixtures. Also a bit of a DIY project. You'll need to identify your fuel pressure connectors at the end of the fuel rail, determine if they are "large" or "small" style, order 2x fuel pressure connectors from our website, and extend the wires on one as required to reach the fuel pressure connector. The JB4 pins for the connectors are posted in the photo here: N54Tech.com - International Turbo Racing Discussion - View Single Post - F Chassis N63TU JB4
How to update firmware:
For firmware updates if having issues we suggest you turn off WiFi, change upload timeout to 25, and set your phone next to JB4 box under the hood.
Slo7 Slo7 is offline
Car: 2013 750li
Default 02-24-2017, 03:00 AM
Looking forward to this! 2013 750li n63tu, I want in on this! I thought you all forgot about the TU
padrino's Avatar
padrino padrino is offline
Car: 07 335i JB3
Default 02-24-2017, 06:50 AM
Looking forward to it! 2016 750xi here, love the potential this engine has for tuning
2016 750xi
Pure Turbos's Avatar
Default 02-24-2017, 11:52 AM
Sweet! Nice work! Huge gains per $ !
Did you find any limitations on the top end? Turbos or HPFP or Octane?
m123 m123 is offline
Car: 440i F32
Default 02-24-2017, 12:03 PM
Great work
F32 440i JB4
F11 550i N63tu JB4
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 02-24-2017, 01:10 PM
Optional fuel pressure connections for V2 board
Default 02-24-2017, 02:23 PM
Originally Posted by Ando @ BMS
The torque is insane while driving.
Need new tires. Spinning in 3rd on the highway.
Hell yea. I want a ride tomorrow!
Car: 2013 750li
Default 02-24-2017, 02:29 PM
UPDATES! lol, I know she has a lot more left in her! Nice work!
Default 02-24-2017, 03:34 PM
I hope the trans holds! lol. If only we could reach that 2nd boost solenoid there is another 50hp at our fingertips. I guess worst case might be to make the BCM posi-tap installed somehow for the really hardcore guys.
135idct 135idct is offline
Default 02-24-2017, 04:08 PM
the trans can hold torque more than the f10 m5
Car: 2013 750li
Default 02-24-2017, 04:26 PM
Heard this before as well? Wonder how true this is? 🤔
Frikiton's Avatar
Frikiton Frikiton is offline
Car: 2016 F25 X4 M40i (N55)
Default 02-24-2017, 05:21 PM
Seen a FBO 2014 550xi Flash Tuned & was beating on M5 Competition Pkg w/ BMS stag1 in a quick roll-race
F90 M5 Comp - @BM3Tuning 100-200 5.29s / 60-130 6.1s | @HCP.US
F97 X3M Comp - Tuning Soon!
F80 ZCP DCT Tune Only | @BM3Tuning Stg1+ E85 60-130mph 6.7s
Car: 2013 750li
Default 02-24-2017, 06:59 PM
That's sick! I know these motors have tons of potential!
Frikiton's Avatar
Default 02-24-2017, 09:09 PM
https://www.youtube.com/watch?v=2EDiYeCzMsY
08n54 08n54 is offline
Car: 2008 535xi
Default 03-03-2017, 06:03 AM
Is there a time frame when the JB4 will come out for the 550I?
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2021 M550i xDrive
Default 03-03-2017, 08:03 AM
Where exactly are those solenoids? If the "hardcore guys" are anything like me, they'd rather do some disassembly for access than use posi taps.
Mike Levy
Default 03-03-2017, 09:18 AM
We'll post more info on adding a BCM to the n63tu once we're further along in development.
Car: 2010 535
Default 03-03-2017, 03:33 PM
NICE GAINS! your N63 and N63tu baselines are very close 408/407hp and 456/466tq...
Once you added the JB4, Do you think your prototype intake played a major role in the huge power and tq spread vs the N63's dyno?
kokoN63TU kokoN63TU is offline
Car: 2013 bmw 750i
Default 03-03-2017, 05:52 PM
great news !!!!!
i have 2013 bmw 750i
stage 1 flash tune
8.0 sec 100-200 kmh (62-124 mile) race logic
cant wait to add jb4 to gain some power
Default 03-03-2017, 05:58 PM
We're not yet sure to what degree the intake has added performance. We're waiting for the next revision and then will dyno it vs. stock. Unfortunately, it's the height of our busy season, and with so many projects under development, there is little time to go around. We'll get it done though.
Car: 2013 bmw 750i
Default 03-03-2017, 06:05 PM
Can wait
Good luck
Interesting what we can do with back and flash + jb4 on n63tu engine
Now I'm producing
499 whp on dyno mustang
And 78 kgm
Meth injections
30% e85
And some logs and tune with the jb4
I thing it will be a huge difference
Frikiton's Avatar
Default 03-03-2017, 06:35 PM
Originally Posted by kokoN63TU
Can wait
Good luck
Now I'm producing
And 78 kgm
Meth injections
30% e85
Got a picture or graph?
Car: 2013 bmw 750i
Default 03-03-2017, 06:38 PM
Yes but it's on my phone not on my pc
And sorry but I don't know how to upload pics from my phone here/:
Mike_L's Avatar
Anti-Social
Default 03-04-2017, 07:17 PM
Hum..... gotta do some research on the 550/750 xDrive system. A 700hp+ 750LiX would be awesome. B7, S8 Plus and S65 killer.
EDIT: That was easy. All BMW cars, from the 1 series to the F02 B7, use the same ATC35 transfer case. The X5/X6 use the ATC45 (or ATC700 for the M's). So its the 8HP70Z, ATC35 combo. Should be pretty safe, up to the driveshaft at least.
BTW Terry, Did you ever find out about that 550 that was losing power with the DP? Its been a while, but I think it was cutting boost or something above 4000rpm? I'm going to assume this fixes that?
Mike Levy
jandraos jandraos is offline
Car: 135 and M3
Default 03-06-2017, 01:04 AM
Terry,
Will the BMS prototype intake system fit on the Straight N63 or non TU, if so when do you expect release date?
