bandook bandook is offline
Car: 2013 335i
Default Avg_Ign resets when I restart the car - 10-22-2020, 07:24 PM
Is it normal for it to have to relearn every time I start the car? I just noticed this. I've been seeing how much e85 I can safely run and so I'll go do some runs and it will steadily drop from 5 down to 3.5 or lower. Seen it down to 2. Then next day I start the car and it's back up at 5.
This was a used board and I had to fix one of the traces on the circuit board that was blown out so I'm wondering if maybe one of the chips that retains the memory is messed up? My other settings seem to stay. If I end the day at 3, shouldn't it be at 3 when I restart the next day?
Default 10-23-2020, 09:19 AM
JB4 log so I can see the firmware version and details? It should only reset when changing maps.
Car: 2013 335i
Default 10-25-2020, 11:00 AM
Here's one on the 24th where I drove for awhile after putting e35 in. It was feeling really good towards the end. Ign got down to 3 and stayed there for multiple runs. May have went lower but i only did about 5-6 pulls. Then I took a log of today and first pull its reset to 5. I need to lower the e85 till i get some more fueling, but it's done this reset thing for awhile. Car always feels good after I drive for awhile then next day it's like it starts learning all over. BTW, these pulls aren't the cleanest i was hoping that it shows enough for just what ign is doing.
2013 pwg 335i
catle$s dp and chargepipe and stage 2 lpfp
new coils and plugs gapped to .020
Car: 2013 335i
Default 10-31-2020, 10:10 AM
I think I've captured the issue. So I flashed e85 bef. Running 35%, I've tested the local E85 and it's e85. I also reflashed the latest firmware on the chance that some blocks didn't get written properly. This bef feels better than ever. And my adv ign quickly dropped from 4.5 to 1.9. But my app froze, which it's done multiple times. The gauges stop responding but it says it's still connected. Just figured it's an android bug. I disconnect/reconnect and my avg Ign is right back to 4.5. only reason I noticed it was because I only today stuck avg Ign in a gauge.
Here are two logs. One clean pull and then a cruising log right after the app had to be reconnected. These logs are minutes from each other.
Is something flakey with the board? My power and ground are solid.
Edit: I cut off the spade connectors from the obd wire and soldered them together. Figured it's a possibility it's a bad connection but does that explain the ign resetting?
Default 10-31-2020, 03:04 PM
Maybe the JB4 itself is resetting before iavg is saved. Tried options bit7 for slower speed CANbus? I also just posted an update in the app under BETA v15_t2 firmware with another change that may help. So load that too to test out.
Car: 2013 335i
Default 11-05-2020, 05:44 PM
Terry the new firmware worked, thanks! Aign now stays after a restart. However I'm having a different issue. I just bought and installed your wmi kit. Can you look at my log and tell me why Meth isn't logging? I am able to prime it with the app and have default settings set right in wmi tab, I believe. Looking at my iats it seems like its spraying? Orange wire #3 Blue #16. Anything I'm missing?
Car: 2013 335i
Default 11-05-2020, 06:56 PM
Car: 2013 335i
Default 11-06-2020, 01:55 PM
Talked to BMS and I'm just going to buy a replacement board. I'll update if it all works out.
Edit: actually avgIgn is still resetting. At least on Map 5 it is. It wasn't doing it on map 3 when I was testing the WMI kit. Hopefully the new board will fix these issues. Also wondering if it's causing the overboost issues.
Default 11-07-2020, 06:52 PM
If it's an old V1 board worth upgrade. If it's already a V2 board just need the 2580 chip for it to replace it's memory.
Car: 2013 335i
Default 11-07-2020, 09:56 PM
Yeah it's a V1 board. What makes it worth the upgrade besides hopefully fixing my issues? Please tell me it's 100 more hp
Edit: woke up this morning and had one of those "ah ha!" moments. I wired the pump to activate using a relay. Just figured it was a better way to do it. So the fsb is not seeing pump current. I didn't even think about how the wmi system sees meth flow until now. Duh.
Also confirmed that the avgIgn still resets on map 3 as well as 5.
