Nicky92's Avatar
Nicky92 Nicky92 is offline
Car: 2008 335i
Default Car won't communicated for inspection, NY. - 06-03-2016, 11:40 AM
Went for an inspection the other day.
Turned off Jb4. Everything was ready. Showed that way in my MHD.
It connected to the inspection machine but then it would not communicate with the required information.
Does MHD have anything to do with it? I was told by a few friends theirs worked fine.
Could this be a DME problem? Reason I am saying that cause my water pump runs when I unlock the car, even when its cold.
335- stock
Nicky92's Avatar
Car: 2008 335i
Default 06-03-2016, 11:42 AM
meant communicate for inspection..
in title lol
335- stock
dreyo27 dreyo27 is offline
Car: 2007 335i 6mt
Default 06-06-2016, 06:27 PM
Its because you have a flash as well. MHD or Jb4 backend.
flash back to stock.
Nicky92's Avatar
Car: 2008 335i
Default 06-06-2016, 07:12 PM
hmmm...it worked last year tho
335- stock
pajuis's Avatar
pajuis pajuis is offline
Default 06-07-2016, 07:49 AM
I just passed a California smog check only by flashing back to stock and installing the VRSF ** fix. Car communicates fine but must be flashed to stock.
2007 E90 Jet Black/ VRSF 7" FMIC/ VRSF CP/ VRSF lower CP/ HKS BOV/ VRSF **'s/ AFE Stage 2 CAI/ AFE Catback/ Dual Oil Coolers/ Fuel-it Stage 2 LPFP/ MMP inlets/ MMP outlets/ MMP Stage 3 Turbos/ MMP Port Injection/ BMS Catch Can/ RB PCV/ NGK's 5992 @ .018/ Alpina Flash/ MHD/ Split Second AIC6/ Wedge E50 Tuned/ 19" Niche M116 Wheels/ Toyo R888's & Toyo T1R's/ H&R Springs/ CSL Trunk/ M3 Rep front bumper with M3 ducts/ Cyba Scoops/ Custom headlights, Custom Tail Lights/ JVC HU with backup camera/ amp
Zombie1 Zombie1 is offline
Car: 2010 135i
Default 06-07-2016, 07:59 AM
I'm on Long Island never have an issue passing with my stage 2+ Cobb maps
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 06-07-2016, 09:54 AM
Originally Posted by carrbone
I have passed inspection for two years now flashed via mhd, no dpipe fix.
Whats with this forum and their assumtptions. Post with facts. E90lemmings.
Well it's a lot more complicated than that. If you understood what was actually going on you wouldn't be so condescending.
OP most likely your O2 sensors were saying not ready...what mods do you have?
09 335 - 6266
07 335i - 6870, E85 - SOLD
Milan's Avatar
Car: 08 335xi
Default 06-07-2016, 10:31 AM
Well through deductive reasoning if you can communicate with the DME via MHD, most likely the issues isn't on your car's end. If they were having problems I don't see the need for the post?
Being a dick is a good way to have people not chime in on your thread lol
09 335 - 6266
Car: 2007 335i 6mt
Default 06-07-2016, 02:40 PM
yes it wasn't able to connect because you had the JB4 on. TURN OFF THE JB4
