erwan35's Avatar
erwan35 erwan35 is offline
Car: bmw 335i e92
Icon1 Help 2acc and 2acb and 3100 codes! - 01-05-2016, 02:09 AM
Was on the way home from a drag race and was driving 20kmh and all of a sudden all warnings were up and car starts to act funny, rpm up and down. Cleared the codes and got 2acc and 3100 code. Then i had to tow the car to a workshop nearby. So the next day the mechanic changed the lpfp. Now rpm is normal but throttle not working. And current code now is 2acc and 2acb and 3100. Please help me. Mods are per signature. Thanks!
_______________________________________\\\
BMW 335I E92 2007 RHD 6AT,FULL M3 BODYKIT,HYBRID TURBOS,BMS ADAPTER W/ 3.5BAR TMAP,VTT INLETS,JB4 G5ISO W/ MHD TREBILA FLASH,BMS ANTI-LAG,AEM METH KIT W/ FSB,BMS DCI,VRSF CHARGEPIPE & TIAL BOV,VRSF C@TLESS ***,FMIC,BMS OCC,BMS CABIN FILTER,MUFFLER CUSTOM BULLET,97RON PUMP GAS
Default 01-05-2016, 02:16 AM
2ABC is the TMAP in the CP. 3100 is a result of that.
erwan35's Avatar
Car: bmw 335i e92
Default 01-05-2016, 02:17 AM
Its 2acb
Default 01-05-2016, 02:25 AM
whoops, a bit of lexiadys there.
2ACB DME digital motor electronics main relay, input signal
2ACC DME digital motor electronics main relay, switch delay
I'd image both of those would put you in to limp mode (3100)
erwan35's Avatar
Car: bmw 335i e92
Default 01-05-2016, 02:27 AM
Yes limp mode.. How do i solve this? I'm blur
erwan35's Avatar
Car: bmw 335i e92
Default 01-05-2016, 06:28 AM
Please?
erwan35's Avatar
Car: bmw 335i e92
Default 01-05-2016, 07:37 AM
Is it the mosfets?
Default 01-05-2016, 08:34 AM
I'm not sure what the issue is. I'd have your mechanic look in to it.
Mosfets usually throw a 30BB code.
erwan35's Avatar
Car: bmw 335i e92
Default 01-05-2016, 07:17 PM
U think its electrical or mechanical?
Default 01-06-2016, 06:29 AM
Based on the description it sounds electrical...
Bad fuse, connection, or relay???
erwan35's Avatar
Car: bmw 335i e92
Default 01-07-2016, 12:47 AM
Yeah was the fused 30a at dme keeps blowing.. Why is it? Never happened like this before. Changed 3 times now then blown again. Please help
erwan35's Avatar
Car: bmw 335i e92
Icon1 No 2 30a fuse constant blown - 01-07-2016, 02:02 AM
Its the number 2 30a fuse that keeps blowing. Please help me
Default 01-07-2016, 10:37 AM
Fuses blow for a reason, you need to track down the root of the issue.
erwan35's Avatar
Car: bmw 335i e92
Default 01-07-2016, 10:39 AM
Yeah thats what i don't know what to do now.. Where to check since so many wires. If i change ecu, will it solve it?
Default 01-07-2016, 11:01 AM
We won't be able to tell you. Best to have your Indy investigate and diagnose the issue.
erwan35's Avatar
Car: bmw 335i e92
Default 01-08-2016, 06:31 AM
Will update
erwan35's Avatar
Car: bmw 335i e92
Default 01-09-2016, 12:44 AM
It was the dme relay!!
trebila's Avatar
trebila trebila is offline
Default 01-09-2016, 06:13 AM
Default 01-09-2016, 01:39 PM
Awesome...I'll send you a Paypal invoice.
erwan35's Avatar
Car: bmw 335i e92
Default 01-09-2016, 09:07 PM
Haha... The car died again when driving!! I think ill just repair the dme an see how it goes from there.
erwan35's Avatar
Car: bmw 335i e92
Default 01-09-2016, 09:32 PM
logle logle is offline
Default 01-12-2016, 07:11 PM
Hey, Ive got the same codes on my DME - 2ACC and 2ACB and the Car will not turn over. Not sure the DME would cause this but appears the DME also needs work. Can you describe how you fixed this? my car is a build date 11/06, DME number is 07611397
A little background, the lead to my water pump rubbed against the exhaust manifold and melted frying parts of the wiring harness, several sensors and the water pump. I've replaced the wiring harness, CAM sensors and Vanos solenoids. Also new water pump and thermostat. I open the door and the red steering wheel lock illuminates and the steering wheel is locked. Inserting the key does nothing to unlock the steering wheel. All other electronics seem fine but the steering will not unlock and the car will not start. Any ideas?
erwan35's Avatar
Car: bmw 335i e92
Default 01-15-2016, 09:38 PM
I still have not found the cause yet. My car is still dead. I'm getting frustrated now.. I don't know what else to do.. Please anyone help me.. I would pay if u solve this for me!! Dme relay new and ecu is not fried... What else tp check!???
BeeMuh's Avatar
BeeMuh BeeMuh is offline
Car: '07 335i
Default 01-16-2016, 08:22 AM
did you try removing the jb4 g5? let's start isolating the problem.
erwan35's Avatar
Car: bmw 335i e92
Default 01-16-2016, 08:31 AM
Do u think fry jb4 will cause this also? I on n20 tmap. If i took jb4 out it will have problems. and i have chucked the stock tmap away .. (I know i'm not supposed to do that )
And i have put jb4 out in the first place but that time we din't know that the relay was not working. So we put back jb4 and figured that the dme 30a fuse was blown. So we took a dme relay from someones car and replaced with mine then hit on start, the car starts fine and idle perfectly normal. So we left itfor 30mins, and still fine. So we started to drove the car and like after 1km, car died again. And the 30a fuse blown again. And i'm sure the dme relay is also blown. So i just ordered the dme relay which is quite costy here in Malaysia rm110. And i took out the ecu and gave it to a friend of mine whos experienced with blown dme. So he checked and dme is fine, not blown. So now i'm stuck with what to do. Been 2weeks now
