(#76)
THE BEAST's Avatar
Car: 2008 E93
Default 06-30-2019, 02:54 PM
All maps.
BIMMIN BIMMIN is offline
Car: 2009 335i AT
Default 07-05-2019, 12:00 PM
My jb4 app is not labeled menu 10 11 or 12. Could you tell me the name of these menus?
Really don't think I need to change anything, just like knowing everything that can be adjusted
2009 E92 335i AT
Engine
Rev9 Hybrid 16t twins, Injen cyborg intake, CP-e charge pipe with HKS SSqv BOV, RB external PCV catch can, BMS catch can, Cobb intercooler, HKS Legamax exhaust, RB inlets, VTT single barrel hpfp, fuel-it! stage 2 lpfp, MOTiV Flex fuel flash only w/ trans tune by Cedar Performance
558rwhp and 523rwtq on e60 110* ambient air
Car: 2009 335i AT
Default 07-05-2019, 12:19 PM
Nevermind, I'm a tard. I just needed to read more over this topic
2009 E92 335i AT
Engine
Lfeliz3 Lfeliz3 is offline
Car: E90 335i xdrive
Default 07-18-2019, 09:16 AM
I don't think you should change values of 10 or 12, unless there is some specific tuning issue you are trying to correct, which you'd see in a datalog. If you want to make the gas pedal more bottom heavy (less linear) then increasing menu 11 to it's maximum is a way to go about that, though.
I lowered menu 10 and menu 12 automatically lowered itsself.. so the way i see it is menu 10 affects menu 12?... i know menu 12 also automatically adjust itself?.. i lowered 10 to 900 because my wastagates are rattling pretty bad and menu 12 lowered automatically to about 1800 RPM
Car: 2003 Forester
Default 07-18-2019, 11:27 AM
Originally Posted by le_roi_leo
for menu 10:
menu 10 --- % open (0% close, 100% open)
0------------0
200--------- 4
400--------- 8
600--------- 12
800--------- 16
1000 --------20
1200 --------24
1400 --------28
1600 --------32
1800 --------36
2000 --------40
2200 --------44
2400 --------48
2600 --------52
2800 --------56
3000 --------60
3200 --------64
3400 --------68
3600 --------72
3800 --------76
4000 --------80
4200 --------84
4400 --------88
4600 --------92
4800 --------96
5000 --------100
but how to choose the good setting ?
So 0% closed and 100% open are the same thing......
cebrailbakan's Avatar
Car: BMW E90 335XI
Default 07-19-2019, 03:33 PM
Setting menu 10 to larger values closes the waste gates -- with 100 (5k rpm) being the most closed position possible without them being engaged. Since "closing" the waste gates is also how you engage them, maximizing this number means you are getting the maximum response from the turbos when the DME requests boost. In other words, the more open they are the farther they have to move to engage and the longer it takes (10ths of a second) to start getting boost when the DME asks for it.
Basically, this delay in engaging the turbos causes 'lag', which is why this used to be called lagfix. On the other hand, if the waste gates get worn, you have to open them more and more to keep them from rattling.
For menu 12, you are adjusting (roughly speaking) the proportion of exhaust energy that you are using for turbo boost at low throttle. When you set the value too high, you are running the turbos when you don't need them, which is why you get the overboost. You could say that the overboost (5 psi at low throttle) means super rapid response at low throttle, but the control system of the engine clearly doesn't like it and you get oscillation if you do this. In bad cases, you'll notice that boost stays on even when you lift the pedal a bit and the car feels like it might not slow down for a brief period.
Menu 11 is a simple mid-boost gas pedal sensitivity, as Terry explained in #10th post. Hope this helps.
Do more with less !
