HansWurst HansWurst is offline
Car: BMW
Default Flash theBMW Performance Power Kit for N55 Exx for FREE with Winkfp - 07-06-2015, 06:15 AM
Hello Guys,
for all of you wanting some extra HP and sound attached you will find all the Zusubs for PPK (European cars).
With this Zusubs you can easily do like the ALPINA Flash using Winkfp on your own!!!
After flashing there is an encoding error code. You just have to code an empty FSW_PSW.MAN to 62BMO or 63BMO using NCS Expert and the error is gone.
If it does not work, just send me PM. i Will try to help you!
Take a look at the list because every car has its own Zusub. Also take care of using the correct controlling unit (MVED17/MVED26).
* Dont ask me for Downloadlinks
* Dont ask me how you can use Winkfp
* Dont ask me how you can use NCXExpert
* Read the Thread
Edit 27.07.2015
Hey Guys,
finally I found the time to create a new Table .
I should point out that this Table can be shared by evrey one. I've picked out all the N55 PPK Zusubs because some Usurer in my Country rip off the Pepole at in the Forums there.It's a great pity!
The PPK can be flashed by evrey One can Use Winfkp and NCSExpert.
Sry for the Watermarks, but someone used my table and says it is his Work
What U need:
- Windows 7 Notebook
- Battery-Charger With 10 Ampere or higher.
- OBD DCan or K + DCan for BMW Made after 03/2007
- BMW Standard Tools
- SP Data V53 or higher
*Soundcheck: Video on Post 78
Warning:
- Dont Flash without a Batteriecharger!
- Dont open or close Dor when Flashing. Better when the Dor is Closed!
- When You have Keyless Go, Its better to Plug in the Key in the Ignition!
- Dont flash if your car is after 2013 or got Update by Dealer after 07/2012!
FAQ:
Q: Can i make this Flash when i have a JB4?
A: Yes, just change to Map0 before start flashing.
Q: Can i make this Flash when i Use the Cobb?
A: No, u have do Uninstall the Cobb before flashing
Q: Can i use the Cobb after Flashing?
A: Yes, maybe you have to save ROM and send to Cobb to Unlock it.
***If You need help by Procurement, Installation and flashing do not hesitate to ask me. the whole procedure lasts 1 hour. after finishing you can send Tip if you want.***
What U Need:
- Internet in ur Garage or where u want to flash.
- an Hour of your Time
If you have any Quetions, just send PM
Have FUN
torr's Avatar
torr torr is offline
Car: 2011 335i
Default 07-06-2015, 06:57 AM
Thanks for sharing, gonna check it out.
Cheers
2011 335i E92 AT, JB4, FMIC, **, CP. Pure stg2 w/high flow intake & DV+. Fuel-It! E85 BEF Flash, stg2 LPFP & PI.
Car: BMW
Default 07-06-2015, 07:47 AM
Update
E88 135i DKG MEVD17 8647148
E88 135i DKG MEVD126 8651826
the E8x havn't an AT!
fryj00's Avatar
fryj00 fryj00 is offline
Car: 2011 e92 n55 xDrive 6MT
Default 07-06-2015, 10:12 AM
Would you happen to have or know how to get the same info for US models?
-Bryan
2011 E92 N55 xDrive 6MT
VTT Stage 1 | DV+ | Pure inlet | MHD/JB4
Car: BMW
Default 07-06-2015, 10:27 AM
-Bryan
Yes!
335xi N55 US
8639128 MEVD17
8615936 MEVD1726
durty sexn55 durty sexn55 is offline
Car: n55
Default 07-06-2015, 04:14 PM
Nice
2011 E82,n55 ,6mt
Stage 3+ Clutch and alumni fly wheel
Vrsf down pipe
Vrsf charge pipe
Vrsf fmic "5 inch
Jb4 , fuel flex wire and Bluetooth connection
New water pump and thermostat
Bms air intake
Meth kit cm10 60/40
E85 50/50
Stage 2 fuel pump
Pure stage 2
Ecs Lightweight Front and rear Brake Rotors brake pads
New o2 sensor
New transmission oil MTL red line
Motor oil MoTul 8100
torr's Avatar
Car: 2011 335i
Default 07-06-2015, 04:31 PM
So,
U.S. E92 335i AT MEVD1726 = 8651808???????
BananaJoe BananaJoe is offline
Car: e82 135i N55
Default 07-07-2015, 02:30 AM
what about zusb for 135i DKG E82? (EU model)
Car: e82 135i N55
Default 07-07-2015, 02:31 AM
Car: BMW
Default 07-07-2015, 04:26 AM
Update:
Originally Posted by torr
So,
335i US AT + MT
8639174 MVED17
8651818 MEVD17126
8651808 is 135i US MT MEVD1726
135i DKG EU
8651832 MEVD1726
8647154 MEVD17
Bmg4 Bmg4 is offline
Car: 2011 335i
Default 07-07-2015, 06:25 AM
Can anyone confirm this works?
Car: 2011 335i
Default 07-07-2015, 08:18 AM
Never mind, it does.
Car: 2011 N55 135DCT
Default 07-07-2015, 12:11 PM
i have a 2011 n55 135 dct and its in SA what should i use
houtan houtan is offline
Default 07-07-2015, 01:35 PM
This is going to sound like I am completely clueless, but how do I know what ecu I have? Car is 2011 n55 dct
mdma666 mdma666 is offline
Car: 135i / N54
Default 07-07-2015, 01:43 PM
sure this will work, not that I donīt want it to?
on the n54īs the car wonīt start till you enter the correct FSC (activation code) when just flashing the pp-kit zusb ...
also there is an error in your chart as there are no 135 (E8x) with N55 and AT - all E8x should be with DKG or manual gearbox ...
there a just a very few E9x with N54 and DKG, but no N55 with AT
Car: BMW
Default 07-07-2015, 02:57 PM
Yes it Work! Try it by ur Self!
i Know that the E8x Dont have AT, i've wrote it in my 2nd Post.
The Encoding Error can be Fixed by Sending a Clear MAN to ECU by NCSExpert.
NJCarGuy's Avatar
NJCarGuy NJCarGuy is offline
Car: 2013 335i E93
Default 07-07-2015, 07:08 PM
How about the X1 35i? I've coded the Alpina flash on a couple of them using Winkfp using E90 Daten files.
Current garage:
2015 X1 35i E84 - JB4, FBO+Pure Turbo S1 & Meth
2011 X5 50i M-Sport - Dinan Stage 2
2002 M3 6-speed, Euro Cams, RE Exhaust, Intake, Dyno Tuned
2016 i8 - Installed K&N filter. Looking for mods
2011 335Xi - Stock for now but moving JB4, FBO+Pure Turbo S1 & Meth from X1
Default 07-08-2015, 12:56 AM
ho do i do this? The Encoding Error can be Fixed by Sending a Clear MAN to ECU by NCSExpert.
can u explain please
Car: BMW
Default 07-08-2015, 02:14 PM
You have to Send one Clear MAN to 62BMO using NCSExpert.
@LL
i will make a new Chart with all N55 PPK Zusubs at this WE.
Pepole with SA 1A1 cant Use any of this Zusubs, so if You have SA 1A1 Just wait for the new Stuff
A vulture trying to sabotage the whole Share-Action and says it does not work to makes people afraid , because he offered it himself for a high price . So when new People sign up here and try to unsettle you just ignored them.
simply flashing and see for yourself that it works .
M31RK M31RK is offline
Car: 135i N55
Default 07-08-2015, 06:49 PM
Subscribed to see how this all goes down
Grandprix Grandprix is offline
Car: E92 335i N55
Default 07-09-2015, 08:16 AM
I have heard that you need a different ZUSUB when you have Cruise Control.
Is this right?
Car: BMW
Default 07-09-2015, 10:13 AM
Is this right?
where U've Heard about this Bull****? i think i Know from where.
So just Read my last Post!!
I'll explain it briefly for all:
N55 E9x
- US, EU, China or Corea
- SA 1A1 or not
- xDrive or not
- AT, MT or DCT (DKG)
- E82,E88,E90,E91,E92 or E93 (Sometimes E93 and E92 are same same)
- MEVD17 or MEVD1726
nothing more and nothing less
Default 07-09-2015, 11:46 AM
What is SA1a1
Car: 135i N55
Default 07-09-2015, 12:22 PM
Is there possibly a guide to do this or am I just looking in the wrong place?...
subaru335i subaru335i is offline
Quentin Wilson Esquire IV
Default 07-09-2015, 01:41 PM
I'm in the same boat. Need a "for dummies" summary on what to do with this info and if I will benefit.
I have a 2011 US 335i MT N55 and a Cobb Accessport running stage 1 aggressive. What would be the effect of me flashing this PPK rom?
Does it overwrite the Cobb tune? Is it better than Cobb? Can I use it with the Cobb flash on top? Will I gain anything from it?
Also, what cables will I need? INPA? BT?
Sorry for the noob questions.
Copyright Đ 2007 - 2018, N54tech.com
