Default Revised MOTIV 750 Dyno Results - 06-02-2015, 01:14 PM
Was finally able to get our 135i strapped down to test the latest tuning changes.
Since last go around:
1) Changed WG spring from 10# to 15# which allowed us to hold more boost to redline than before. With smaller turbos like this I'd say the control range is more like 2.5x WG spring rather than the 3-4x we've previously been able to hit with larger turbos.
2) Corrected some issues with bank to bank variance on the fueling as well as issues with negative fuel trims.
3) Reverted back to the basic Cobb VANOS maps. Previously was running some changes suggested by MOTIV but for whatever reason the basic Cobb stuff seems to run better than what Jake suggested as well as anything I came up with during testing.
4) Reduced false knock and retuned for MBT which wound up being a bit higher than where timing was set last go around. The false timing drops were causing us to under time it a bit.
Current issues:
1) The lvl10 would on occasion slip during runs.
2) Above 30psi several runs had misfire faults, in random cylinders. The car has NGK 5992s @ .018 currently. It's time to start experimenting with alternative plugs for those of us running > 30psi.
3) Still get some timing drops from time to time. Especially in 5. Need to sort out if they are false.
Overall still very pleased with the MOTIV kit. It's doing exactly what I wanted it to do. If I can get this 700whp down the 1/4 mile without misfires or trans problems this is an easy 140mph car.
dane5331's Avatar
dane5331 dane5331 is offline
Default 06-02-2015, 01:32 PM
Awesome!
Daily: 335is, JB4, BMS E85 Flash, BMS Charge Pipe w/Tial Bov, VRSF **, VRSF FMIC, Fuel-it Stg. 1, BMS OCC.
Default 06-02-2015, 01:34 PM
Originally Posted by dane5331
Awesome!
+1
baja2700 baja2700 is offline
Default 06-02-2015, 01:35 PM
cant wait to see the 1/4 time slip!
NICE! Glad to see this kit come to life!
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
CHECKERED's Avatar
CHECKERED CHECKERED is offline
ex deus machina
Car: E92 N54 335i
Default 06-02-2015, 01:43 PM
NICE!
is this on strait E85?
Garage Queen: Audi S4 4.2L V8, Vortech Supercharger, Bilstein PSS9 Coilovers, Sway-bars, RS4 brakes and rear BBK, Fast Intentions - Full Exhaust, 505AWTQ 0-60: 3.8s
Daily Driver: E92 335i N54: complete part out - let me know of any parts you need:
https://www.n54tech.com/forums/showthread.php?t=55650
Newguy123's Avatar
Car: 12' 135i
Default 06-02-2015, 01:48 PM
AWESOME. that dyno saves a lot of he said she said drama great numbers
18 Glacier white RS3
#PURETURBOS
#FUELIT
Default 06-02-2015, 01:53 PM
Originally Posted by CHECKERED
NICE!
Yes straight E85 & BMS port injection.
Peter @ Pure's Avatar
Car: F20 M135i
Default 06-02-2015, 02:06 PM
nice result!
F21 M140i - currently stock
Audi TTRS - 100-200: 5.1, 60-130: 6.0
F80 M3 - 100-200: 4.6, 60-130: 5.3
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Race8877's Avatar
Race8877 Race8877 is offline
Car: BMW 135I
Default 06-02-2015, 02:14 PM
Nice job. Interested in seeing that level 10 tranny if it can hold that 700 hp without having any issues.
135pats 135pats is offline
Default 06-02-2015, 02:26 PM
Nope. At least not whatever LVL10 is currently selling people.
swat's Avatar
swat swat is offline
Car: 07 335i
Default 06-02-2015, 02:28 PM
He actually said he was having slip already on the dyno.
Stacked BMS Flash & JB4, Dinan CAI, ER Chargepipe, 7" VRSF Intercooler, VRSF **'s, ER Sport Oil Cooler w/Steel lines, Gunmetal 19" VMR V710's, 335is clutch, Wavetrac LSD, M3 FSB, M3 Front & Rear Control arms, M3 RSB, M3 rear subframe bushings, M3 guide rods
Race8877's Avatar
Car: BMW 135I
Default 06-02-2015, 02:38 PM
I think with time people is going to see that level 10 is more like level 0.
Default 06-02-2015, 02:43 PM
The lvl10 is better than stock and at least on our very light weight 135i it works "OK". But it's far from bulletproof at least in what I have. I'd say it's good for around 550lb/ft. But what we need is one that is setup for 700lb/ft.
Default 06-02-2015, 02:51 PM
I feel like that's not that substantial an upgrade over a "stock" HP21
Are you considering a 6MT swap? Or just calling it a day at these types of power levels and hoping for the best? Can certainly understand if you are out of patience with this.
Default 06-02-2015, 02:54 PM
The stock one burnt out around 500wtq on mine. On the 135i I don't race it that often, so I'm just going to ignore the problem for awhile. Next race is in early Sept. After that I'll decide what to do with it. Don't really want an MT. We already have that with our E92 FFTEC setup. But don't want to continually swap the trans around testing things either. It's going to need an engine one of these days so hopefully by then there is some proven auto trans solution out. Whether it's lvl10 or someone else.
Race8877's Avatar
Car: BMW 135I
Default 06-02-2015, 03:06 PM
I'm definitely not going to spend $5,000 to see just a minor improvement .Thanks for the info Terry.
lcvette's Avatar
lcvette lcvette is offline
Default 06-02-2015, 07:02 PM
Congrats, great numbers and nice graph! Looks like it was still climbing, any reason for sitting it down before it flatened out?
The Leopard's Avatar
Car: E92
Default 06-02-2015, 07:08 PM
It stopped because the autos have a lower rev limit (for now).
TS N54
bnk bnk is offline
Default 06-02-2015, 07:21 PM
Since MT is slower, there would be more to do in the manual front for a tuner now that new tables will be revealed. More MT cars would be beneficial for the development. Or is it a longer process for Jyamona to do the ground work and no chance yet to make 6MT quicker than AT?
Torgus Torgus is offline
Default 06-03-2015, 08:41 AM
DCT swap it! Runs 10s, take the record from Shiv.
Got Boost?
MOTIV's Avatar
MOTIV MOTIV is offline
Car: N54/N55/S55
Default 06-03-2015, 10:35 AM
Excellent results Terry.
Our Goal Is To Provide the HIGHEST QUALITY Products For Your Turbocharged BMW. True Passion Is What Drives Us To Ensure Quality And Reliability
http://www.motivmotorsport.com/
Contact Us Directly: sales@motivmotorsport.com
HeavyMetalRocker's Avatar
HeavyMetalRocker HeavyMetalRocker is offline
Car: BMW 335i e90
Default 07-30-2015, 08:08 AM
Terry. what turbo housing size did you run with this kit? 1.03 or .82?
Default 07-30-2015, 10:50 AM
No idea, you'd have to ask Jake @ MOTIV on the hardware specs.
Patrick4588's Avatar
Patrick4588 Patrick4588 is offline
Car: 2010 335i and 2006 M3
Default 12-29-2015, 10:46 AM
Looking to get one this spring. Your dyno looks much better than what is on motivs site. Would this be about the limit for the stock engine? And the motiv900 only for built motors?
