fryj00's Avatar
fryj00 fryj00 is offline
Car: 2011 e92 n55 xDrive 6MT
Default Summary of N55 backend flash options - 03-24-2015, 11:13 AM
Hi, Terry, I am a little cloudy on what possibilities are available for flashes that you have developed for the N55 platform. The only one that I can repeatedly find is the "big turbo" flash but I think I recall reading posts about E85 flashes or flashes for auto trans, etc. Would you mind summarizing briefly what flashes are available? Maybe a sticky on the subject?
Thanks for your time and I love what you do for this community. You guys rock!
-Bryan
2011 E92 N55 xDrive 6MT
VTT Stage 1 | DV+ | Pure inlet | MHD/JB4
BostonBeemah's Avatar
Car: AW 135i
Default 03-24-2015, 12:03 PM
Pretty sure the n55 backend is obsolete for stock turbo cars regardless if e85 is used or not because of the minimal to no gains.
RIP 2008 AW/BL 135i
fryj00's Avatar
Default 03-24-2015, 12:15 PM
Yeah, I think I knew that (generally) but I was kinda hoping that there might be some drivability improvements to be had. For instance, with ~E40 my car idles rough or even dies when cold. My throttle response on decel (rev matching) is total **** for some reason. I was hoping that a flash could help improve response in general...not just looking for peak power. I am also researching a move to stage 2.
Was just hoping to see a collection of relevant info on the subject in one place.
Nugs Nugs is offline
Car: 2011 135i
Default 03-24-2015, 06:32 PM
The standard flashes in this thread
http://www.n54tech.com/forums/showthread.php?t=24788
should be fine for stock turbo as well.
It may not add much performance but I found drivability much improved and gearbox shifts much better than JB4 only.
durty sexn55 durty sexn55 is offline
Car: n55
Default 03-24-2015, 07:05 PM
I'm fbo on my n55 and I'm going to install the stage 2 fuel pump and my meth kit this weekend and do my bef after that
fryj00's Avatar
Default 03-24-2015, 07:20 PM
Now that's what I'm talking about. I'd love it if my xdrive had the response of an M4...naaaaaasty.
Car: n55
Default 03-24-2015, 08:41 PM
Any body know if wedge have a bef for the n55
loesch's Avatar
loesch loesch is offline
Car: 2011 BMW 135i M Sport
Default 03-25-2015, 01:16 PM
I like the idea of this thread. BMS did create a basic BEF for when he was testing the VTT Stage 2 turbo but there haven't been any public variants or updates since then. I'm sure some people have been working on tweaking this to increase throttle response or maybe even improve exhaust note. Would be great to hear from some of these people, if they exist.
tboudre's Avatar
tboudre tboudre is offline
Car: 2011 BMW 335xi E90 N55
Default 03-25-2015, 02:10 PM
I'm not planning a turbo upgrade, but I always read that there is no benefit to the backend flash for stock N55 turbos. I'm curious as to some of the details. I am also wondering if anyone has had any problems or if there are potential problems with running high E% without a backend flash. I have run up to E70 in mine with no apparent problems. I guess the biggest issue would be not getting enough fuel and running lean? How can we tell if we have a problem if the N55 JB4 does not log LT & ST trims?
2011 335i xDrive ///M-Sport LeMans Blue Navigation iDrive 15% Tint N55 E90 - BMS Intake, Le Mans Blue Grilles, Le Mans Blue Rear Diffuser, Alpina B3 TCU Flash, Misc Coding, Matte Black Badge, Gloss Black Exhaust Tips, Blue Calipers*, VRSF Charge Pipe*, Cyba Scoops*, JB4 ISO 5.5, Sport Oil Cooler Valve, FlexFuel (Fuel Rail Pressure) Wires, Wheel Lock Set, Ethanol Content Sensor - No problems up to E70 fuel mix
* Painted 7251 Cobalt Blue Metallic - Matches LeMans Blue
Car: 2011 135i
Default 03-25-2015, 05:57 PM
Terry has done a few different revisions for people but not released publicly as the ones in the thread should be good for the majority.
I asked PTF if they would do one for me and Dzenno said he wouldn't because you can't monitor timing on all cylinders with the JB4. If that changed then he would.
Default 03-25-2015, 07:37 PM
-Bryan
We make one for larger than OEM turbos. There is no reason for a back end flash for OEM turbos. See previous testing.
http://www.n54tech.com/forums/showthread.php?t=22563
fryj00's Avatar
Default 03-25-2015, 08:09 PM
Well nevermind then. I guess I had the impression that there was more to be said but it looks like it's already been said.
Still rock.
fryj00's Avatar
Default 04-02-2015, 11:43 AM
Has anyone built their own N55 map and would like to share fueling settings? High-load AFR, scalar, etc...?
E40, FBO, stock turbo.
