Default Just another 700whp N54 - 09-26-2014, 12:28 PM
Was able to get Ando's car back on the dyno to test out the new 1.00 AR exhaust housing. Mods are a JB4, VM top mount turbo kit, E40, meth, and all the bolt ons.
The result was an impressive ~30whp gain from his .84 AR housing with improved spool. Looks like the COMP 6465 1.00 twin scroll is good for a nice spooling 700whp. Even on automatics.
I also plotted it out against Payam's manual trans 335i running basically the same turbo kit, tuning, and mods, and you can see what an improvement the longer MT gearing makes on spool and power under the curve -- on the dyno. In the real world though advantage automatic. We'll find out for sure when the two of them race at Shift Sector in a month.
Newguy123's Avatar
Car: 12' 135i
Default 09-26-2014, 12:34 PM
wow bada$$
18 Glacier white RS3
#PURETURBOS
#FUELIT
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 09-26-2014, 12:36 PM
Peter @ Pure's Avatar
Car: F20 M135i
Default 09-26-2014, 12:45 PM
Very nice!
F21 M140i - 100-200: 6.95
Audi TTRS - 100-200: 4.47 60-130: 5.16
F80 M3 - 100-200: 4.45, 60-130: 5.1
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
natedog7700's Avatar
Car: 2007 bmw 335i e90 auto
Default 09-26-2014, 01:46 PM
Originally Posted by Ando @ BMS
Is this a huge difference between the RBs?
BMW 335i
RB's 550whp
2000 Camry
2000 LS1 T56 Camaro
Koenigsegg Agera R - SOLD
Lamborghini Huracan - SOLD
2014 Bugatti Veyron - SOLD
Ando @ BMS's Avatar
Car: bmw 335i
Default 09-26-2014, 02:44 PM
No RB's were fun too. Can't take anything away from it,
but this is almost 200whp more and pretty fun and cool to drive.
iuhutch's Avatar
iuhutch iuhutch is offline
Car: 2011 e92 335xi
Default 09-26-2014, 02:45 PM
Looks like a seriously fun ride! Don't forget to take videos at SS!!
katsooba's Avatar
katsooba katsooba is offline
Car: 135i N55 DCT
Default 09-26-2014, 04:57 PM
looks like a beast!
i wonder how DD this setup can be?
maybe in low boost setting like 15 or 20 psi for spirited driving?
you dont want to get full 700 hp kick while on the corner edge
135i N55 / KW V3 / CP-E charge pipe / CP-E 5" ** / CP-E 7" FMIC / JB4 S2 / MHD / K&N inbox / Custom made 3.25" catback / Tons of other mods
VegasJD's Avatar
VegasJD VegasJD is offline
Car: 2012 bmw 135i
Default 09-26-2014, 05:30 PM
nice
<-- Click for the build thread, also 2018 Individual Tanzanite Blue Competition M4
Default 09-26-2014, 06:36 PM
Awesome results!
Down4it's Avatar
Down4it Down4it is offline
Default 09-26-2014, 09:30 PM
That's awesome work T! I saw that car last week over at Supercar Sunday
Singapore Grey M6 GC
Default 09-26-2014, 11:32 PM
What size tires are you running and why do they look so skinny on the rear?
BMW 335i
RB's 550whp
2000 Camry
2000 LS1 T56 Camaro
VegasJD's Avatar
Car: 2012 bmw 135i
Default 09-27-2014, 01:27 AM
when are we going to see the dyno for the 1.15 ar?
Track Master's Avatar
Track Master Track Master is offline
Car: 135i, 2010, N55, DCT
Default 09-27-2014, 08:38 AM
Will this setup work on a RHD vehicle?
N55 DCT, 135i, 12.00@116.2, W/O Meth
,12.01@119.3, With Meth
,11.91@119.025 added BMS Intake
,12.10@115 e85 + ISO
390whp@497 - 0.60 in 3.75sec
Default 09-27-2014, 09:27 AM
245/45/17 Nitto 555R. I run them on the 135i as well. The 275 version is too wide for the K1 rim IMHO.
Default 09-27-2014, 10:30 AM
With the VM RS1 wheel we have in stock. 17x8.5 front 17x10 rear, I use 275/40/17 with the same power level.
Got some info regarding back pressure on bimmerboost forum. Looks like it reaches 2:1 BP near 27Psi+ toward redline. So were deciding weather to up the AR again, or we should test out a bigger wheel in the exhaust turbine.
Either 1.15 AR with the 6465
Or 1.00 AR with 6467. We'll see how it goes.
We have had a few customers request pictures etc. It seems like the steering column is in the way of the ******** and possibly wastegate. It will need customizing for that end.
Default 09-28-2014, 09:57 AM
Some back pressure data on the 6465 1.00 AR from Ando's car. At WG spring, 23psi, and 28psi. Exhaust pressure is pinned to "low fuel pressure" in the logs.
Default 09-28-2014, 10:05 AM
Not liking the 2:1 back pressure ratio up top at higher boost levels. Hopefully the bigger turbine wheel will help that.
Is this cutout open or closed?
Default 09-28-2014, 10:28 AM
Cutout closed. Opening it may help a bit. It's under 2:1 still but getting there. Turbo is probably maxed out for the current setup. Still 700rw isn't a bad place to be.
phv628's Avatar
phv628 phv628 is offline
Car: BMW 2009 335i xdrive
Default JB4 for boost control and Cobb backend flash - 11-30-2014, 10:22 AM
Hello guys,
I was hoping to get some help regarding tuning a single turbo kit on my N54 with a Cobb backend flash while using JB4 for boost control. The protuner recommended that I use JB4 for boost control and they would tune my set up with a Cobb backend flash.
Do I need to upload a single turbo map for the Cobb and flash my car and then just install the JB4 for now and then do some data logging and have a custom map made? Since I have the Cobb Ap and was protuned on stock turbos, I was getting custom maps made.
Viorage Viorage is offline
Car: 2007 BMW 335i
Default 11-30-2014, 10:28 AM
crazy! thats awesome
PR3CI5N335i's Avatar
Need4Speed
Car: 2010 E90 335i M-sport
Default 11-30-2014, 05:22 PM
What about Ando's transmission? He was having problems with less power so how's it going to hold up now..
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 11-30-2014, 06:10 PM
I thought he said he blew it...
http://instagram.com/p/uopKYLMt0r/?modal=true
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
2014 E84 X1 35i 12.85 @ 107MPH / 0-60 4.72 / 293 AWHP 305 AWTQ When stock
VRSF Chargepipe | BMS Intake | JB4 ISO | N20 TMAP | VRSF 7" Intercooler | ER Turbo Outlet |
Default 11-30-2014, 06:28 PM
It's toast, lol. For any single turbo running an auto you'll need to keep boost at 23psi or less for it to have a chance at living. Maybe under 20psi in some cases.
phv628's Avatar
Default 11-30-2014, 09:39 PM
I have the xdrive and you think I still need to keep it under 23 psi?
