Default 135i BMS FFTEC Single Turbo Dyno Testing - 01-30-2014, 02:59 PM
Been racking up miles on the 135i and fixing little things. And finally had a chance to get to the dyno today for some baseline testing. As I've mentioned in the other thread I've been VERY pleased with the FFTEC twin scroll top mount 5862 kit. On road performance and spool is much better than any other combinations I've driven.
Testing details:
2008 135i Steptronic (original trans, for now)
JB4 single turbo firmware & supporting flash
FFTEC 5862 top mount single turbo
BigTom intercooler, BMS OCC, BMS stat, etc
Walbro 255 inline fuel pump mod
Factory exhaust system (did not bother to open cutout)
~E30 mix for for 17psi runs. For 20psi+ runs enabled meth kit for fueling using a single CM10 nozzle.
Notes:
1) Was not going after any power records so left the tuning very conservative all around. At the same boost levels there is easily another 15hp in this setup with more advance. And no reason this turbo can't be cranked up to 28psi when the trans is ready.
2) It made a lot more power than I was expecting. It's basically on pace with the 6466 at these lower boost levels only with much better spool.
3) If the trans would shift this car would be seriously quick. I'll get to work on that ASAP.
Video of one of the 23psi runs:
torres335i torres335i is offline
Default 01-30-2014, 03:09 PM
Great job terry
SaferTransport's Avatar
SaferTransport SaferTransport is offline
Car: e92 335i Coupe
Default 01-30-2014, 03:10 PM
Called it
JB+RB=
iuhutch's Avatar
iuhutch iuhutch is offline
Car: 2011 e92 335xi
Default 01-30-2014, 04:28 PM
Absolutely brilliant! That car is a monster now!
Oh, and a...video!? Lol so proud of you T
Iloveboost Iloveboost is offline
Default 01-30-2014, 04:35 PM
Such Wonderful. Much want. Wow.
I priced out the original FFTEC single kit, and it + supporting mods was 12 grand. Are the top mount kits any more reasonable?
gogunbaba gogunbaba is offline
Car: 08 E90 335i
Default 01-30-2014, 04:36 PM
awesome job Terry,
Spec2+ Clutch, SS SMFW, BMS backend flash, VRSF ***, ETS 5" FMIC, ER CP - Tial BOV, N20 3.5 Bar map sensor, BMS OCC, Walbro 255, Markert Motorworks clutch type LSD, Defiv Diff. lockdown kit, UUC EVO3 and DSSR, AFE DCI, H&R Coilovers, M3 Front control arms, rear arms, rear subframe bushings, 335is engine mounts, Rogue Engineering transmission mounts, Michelin PSS 265/35/18 - 235/40/18, Apex ARC-8.
boostedMPLS's Avatar
boostedMPLS boostedMPLS is offline
Car: E92 335xi M
Default 01-30-2014, 04:59 PM
Sick!! Awesome Terry. Love seeing these kind of updates!
Default 01-30-2014, 05:09 PM
I'd have to defer to them for pricing. I didn't really keep track. This sort of performance and bolt in convenience is relatively expensive though. Add in a long block rebuild and a trans rebuild and you could easily double the value of your car in mods. On the other hand, it's a lot of fun.
BTMFR's Avatar
BTMFR BTMFR is offline
Default 01-30-2014, 06:00 PM
it looks like this setup reaches 20psi around 200-300rpm sooner than the 6466 setup, and makes less peak torque per hp at the same rpm as the 6466 you tested?
area under the curve pre 4000rpm though looks much nicer...
damo's Avatar
damo damo is offline
Car: 2008 e92 335i
Default 01-30-2014, 06:24 PM
wow! 15psi at 2k rpm and 21psi at 3k rpm! that's insane!
JB4 G5 ISO, MHD Back end flash, e50 & Meth, AR **'s, VTT inlets, AFE DCI, AMS FMIC, ER CP, Forge DV, KW's, BMW PE
mikew2069 mikew2069 is offline
Car: F30 335
Default 01-30-2014, 06:31 PM
Curious what kind of cutout you have?
BTMFR's Avatar
Default 01-30-2014, 06:32 PM
More like 15psi at 3000 and 20 at 4000
Default 01-30-2014, 06:41 PM
Car: F30 335
Default 01-30-2014, 06:49 PM
Nice, do you have an electronic valve on it? If so, which one?
damo's Avatar
Car: 2008 e92 335i
Default 01-30-2014, 06:55 PM
yep my mistake - still great numbers...
Default 01-30-2014, 07:19 PM
FWIW runs were done on a AT in 4th gear. Spool under real world load is maybe 200-300rpm quicker.
BTMFR's Avatar
Default 01-30-2014, 07:21 PM
thats about what it looked like in the logs. Seems like it takes 2 more psi to make 6466 power with this turbo. with area under the curve before around 4250 being better
Default 01-30-2014, 07:30 PM
It's not apples to apples as the 6466 was tested in 5th gear so under a lot more load. But this is close enough to get a feeling for what is going on at 21psi with each turbo. Blue is 6466 and red is 5862.
want2race's Avatar
want2race want2race is offline
Car: 07 335I [JB4 G5ISO][BMS DCI][BMS DP`s][OCC][BMS RACE FLASH]
Default 01-30-2014, 08:18 PM
AWESOME!!!!!!! You are the man Terry....
About how long does it take FFTEC to do the install on the top mount??
BTMFR's Avatar
Default 01-30-2014, 08:24 PM
what happens to the 5862 above 7000rpm?
Bullitt1841's Avatar
Default 01-30-2014, 08:25 PM
Wow. Big step for the N54
2018 Audi RS3
Default 01-30-2014, 08:29 PM
Who knows. Auto trans upshifts at ~6700rpm.
I think it's just a normal ~$1500 labor charge. Check with them for addl details on that though.
BTMFR's Avatar
Default 01-30-2014, 08:39 PM
i like the super linear band of the 5862 but i still think the 6466 is better suited to my goals. Maybe ill keep a 5862 handy on the side lol
dx1541 dx1541 is offline
Car: 335i DCT
Terry
What's max boost this motor can run without pushing it? 25psi? This is a stock block I'm assuming.
But really great work so far.
