Go Back   N54Tech.com - International Turbo Racing Discussion > General > Off-Topic Discussions
Reload this Page Doomsday Machine Plan
View Poll Results: Will you help with the plan?
Yes!!! 2 66.67%
No, I'm LAME! 1 33.33%
Voters: 3. You may not vote on this poll
coolbho3k's Avatar
coolbho3k coolbho3k is offline
Bravest N54 Owner Award
Car: BMW 335xi
Default Doomsday Machine Plan - 12-11-2013, 12:50 PM
You know how cars run faster and more efficiently when there's more air pressure? Like, at or below sea level. How about we gang together and build a N54tech.com ULTIMATE JB4 DOOMSDAY MACHINE that increases the concentration of oxygen in the atmosphere to increase the air pressure on the surface of the Earth by separating the O2 from the hydrogen in the oceans, eventually destroying all life, but making our cars a lot faster?
Good or bad plan?
2007 E90 335xi 6AT Premium Pkg | JB4 G5 ISO | Cheap custom exhaust: OBX ********* ***, Secondary *** Delete w/ Magnaflow Xpipe | WedgePerformance Backend Flash ("PUMP") | DCI | BMS Cowl Filters | Alpina TCU Software | M3 flappy paddles retrofit | NGK "one step colder" Soon: custom oil cooler retrofit, VRSF 7" FMIC
Wedge1967's Avatar
Wedge1967 Wedge1967 is offline
Car: '07 335i e92
Default 12-11-2013, 03:22 PM
http://en.wikipedia.org/wiki/H2o
Everything you need to know is on Wiki... WikiFTW
coolbho3k's Avatar
Car: BMW 335xi
Default 12-12-2013, 12:11 PM
We basically do this to all the water in the oceans: https://en.wikipedia.org/wiki/Water_splitting
Basic stoichiometry says there will be two moles of H2 produced per mole O2 (33% oxygen). Atmospheric O2 concentration at sea level is around 21% so it would raise O2 concentration, making combustion more efficient.
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 12-12-2013, 01:07 PM
I wonder how much liquid oxygen in a tank you would need per gallon of gasoline and if you could just inject the oxygen directly like the fuel and combust it? The energy needed to make and contain the oxygen probably wouldn't be efficient enough for anyone to do that though. At that point you might as well use other fuels. Or just strap a solid fuel rocket to your roof.
A single fuel component used for drive is the most efficient of course, if it can be contained efficiently (see electric cars).
coolbho3k's Avatar
Car: BMW 335xi
Default 12-12-2013, 01:31 PM
Nitrous works in the same way. And rocket engines carry LOx because there is no oxygen in space.
