Default F Chassis N55 JB4 - 02-06-2013, 07:11 PM
Use subject to terms and conditions posted at https://www.burgertuning.com/pages/terms
When working with live wires ALWAYS disconnect the negative battery terminal in the trunk first. Do not attempt to install the tuner, connect the tuner box to the harness, or otherwise work on the vehicles electrical system with the battery connected. Doing this may result in a damaging voltage spike being sent to the DME.
Also be very careful when working with the BMS USB cable as it sits close to the battery rail which is a live +12v connection. Allowing the USB cable to touch the +12v connection WILL damage the JB4 and MAY damage the TMAP sensor wiring requiring the ground bypass at the bottom of the guide to be performed. Wrapping a piece of cloth tape over the battery rail connection and/or USB connection will help prevent accidental damage.
Current F Series JB4 Install Guide
This thread will be used to centralize all F series JB4 information. Anything important is in the first post. The rest is 100 pages of discussion, much of which may no longer be relevant. If its not in the first post then its probably not very important.
Note: We sell two systems for the F series N55. The Stage1 and the JB4. There is no such thing as a JB4 Stage1 and no such thing as a JB4 Stage2. The Stage1 DOES NOT have updatable firmware, CANbus, or changeable maps. If you have a Stage1 system then none of the information in this post is relevant to you.
To order a new F series JB4 kit: https://www.burgertuning.com/products/f-series-n55-jb4
To avoid cluttering up the thread any support requests will be deleted from this thread without being read. If you require assistance email tech support at support@burgertuning.com.
JB4 Mobile Smart Phone wireless connection directions Click here.
BMS data cable hard wired software & directions Click here.
Map Info (selected via menu 0 in dash or using JB4 Mobile/laptop interface. Map1 is the default map)
Map 0: JB4 disabled
Map 1: Additive target, around 4psi over stock.
Map 2: Additive target, around 6psi over stock. Suggested for those with 93 octane and bolt on modifications. Also good for small E85 mixtures.
Map 3: Progressive WMI mapping.
Map 4: Stock performance with JB4 active for logging only.
Map 5: Autotuning map, absolute target of 11-17psi based on octane and conditions.
Map 6: User definable absolute target map. Suggested for troubleshooting by professionals only.
Map 7: Race gas map. Absolute target of 18.5psi. Requires straight unleaded race gas.
E85 Use
Up to 30% E85 mixtures can be used in most situations.
M2 Specific Map Settings
The M2 runs much higher boost from the factory than a normal N55 motor and thus often requires special settings. Ensure you have v13 firmware or higher, Set FutureUseD bit6 on (as if you had a back end flash map), and then we suggest starting with map2.
Firmware
Both the F10 and F30 N55 motors share the same firmware. Note models using the pneumatic wastegate, primarily 2013-early 2014 models where the JB4 harness blue patch is connected, need to use PWG firmware. Those equipped with an electronic wastegate, primarily 2014+ models where the JB4 blue batch is NOT used, need to use EWG firmware. Note for older systems POSITAP firmware (the old wire taps for brown/green wires) has been discontinued and no new updates will be done. So upgrade to the OBDII CANbus connector & firmware if you wish to run the latest firmware & features.
F10/535 in dash control
To enable the BC button menu changes on F10/535 models you must connect to the JB4 using a BMS DATA cable or BlueTooth kit and change FutureUseD bit #1 on (resulting value of 2) press save. Then turn off ignition and lock doors for 5 min to allow the JB4 to reset.
*Special Settings For F Series JB4 EWG v14+
Note these change by firmware version and the list below applies only to v14+ firmware. There may be some features not active in PWG integrated firmware yet.
Future Use D:
bit0 - Disable in dash BC button controls
bit1 - Alternative in dash BC F10 compatibility mode
bit2 - Disable oil temp warmup protection -- full boost target even when oil temps < 160F
bit3 - Disable wastegate/FF adaption learning for diagnostic purposes
bit4 - Disable startup gauge sweep
bit5 - Test Duty Bias Learning Algorithm
bit6 - Vehicle is equipped with a back end flash map
bit7 - Slow down CANbus sample rate - required for some vehicles with older software
FutureUseA: Negative offset to dutycycle via EWG connector to correct for over boost conditions when PWM is low
Map6: Values of less than 10psi under boost 1500rpm will cause map6 to act as an additive rather than absolute map
Firmware Updates:
Download using the new JB4 Mobile firmware database or externally by clicking this link.
EWG Control
For those with 2014+ models with the new electronic wastegate this thread has addl information on optional EWG control for higher boost maps.
OBDII Firmware Wheel Controls and Map Switching In Dash:
In dash options
Note CANflap and menu system for changing maps, enabling the boost gauge, etc, now use exclusively the BC button. These commands are active for F series dash types, but not yet supported for G series fully digital dashes.
Exhaust Valve Mode:
Toggle between flap open, flap closed, and OEM operation, by pressing the button for 2 seconds and letting go. The left blinker will flash for valve open, right blinker for valve closed, and both blinkers for OEM operation. The valve setting is persistent and will remain in effect until you change it. If you hold the button too long you'll jump in to the in dash menu system below.
'OBDII In Dash Menu
'0 map menu, map shown on tach (tach shows Map)
'1 Active Sound MUTE. (tach = 0 OFF, tach = 1000 ON)
'2 Boost gauge on fuel, scaling in dash is 0 to boost safety setting, turns on when gas pedal is pressed 60% or more and turns itself off when you resume low throttle use. (tach = 0 OFF; tach = 1 Boost Only; tach = 2000 Boost on fuel, Meth on speedo ring; tach = 3000 Boost on fuel, Timing on speedo ring; tach = 4000 Boost on fuel, AFR on speedo ring)
'3 LED MAX brightness mode. For those with factory LED headlights this option brightens HALO during nighttime operation. (tach = 0 OFF, tach = 1000 ON)
'4 Delete Fault Codes.
'5 Dash Mode. tach = 1000, SAE; tach = 2000 Metric
'6 1st gear boost limiter. (Tach = boost cap / 3)
'7 2nd gear boost limiter. (Tach = boost cap / 3)
'8 3rd gear boost limiter. (Tach = boost cap / 3)
F Series N55 Default Settings:
Copyright Notice:
JB4 Software is Copyright 2006-2016 by Burger Motorsports Incorporated. All rights are reserved. De-compilation, disassembly, reverse-engineering, alteration, and redistribution in any form without the prior written consent of Burger Motorsports Inc. is prohibited.
Default 02-07-2013, 09:46 AM
For those adding in the DATA Cable or REV3 Blue Tooth to the new enclosure here are some install directions.
How to update firmware via JB4 Mobile:
Default 02-07-2013, 09:47 AM
Old firmware notes for posterity
N55_F_PWG_INT_13:
1) Adjusted wastegate learning, FF will now remain fixed, and duty bias by RPM will automatically learn.
2) Adjusted base FF algorithm to allow a wider range of learning.
JB4_F_EWG_18:
1) Revised boost control system for absolute maps equipped with an EWG connector. New default settings are as follows: Duty bias 50 across the board, pid gain to 20, FF to 60, auto shift reduction to 60.
2) Added speed logging parameter
3) Increased analog sensor sample rate for smoother performance.
4) Various other minor undocumented changes.
JB4_F_EWG_17:
1) Revised logic for absolute boost targeting maps resulting in smoother part throttle operation and the ability to set boost by gear values lower than the flash target.
2) Adjusted map4 to a low boost / VALET / safety map with a target of 8psi.
3) Adjusted in dash to prevent gauge bouncing on newer model years
stom_m3 stom_m3 is offline
Car: '13 335i MSport
Default 02-07-2013, 10:32 AM
We made an update for Stage1 modules running a firmware date that ends in //3. So if your firmware ends in that number then email in for the update.
Terry, the Stage 1 is working out great. Lots of power. Thanks!
A couple of questions;
1. If I just got my harness 2/2, would I have the latest fw? What would be the difference in fw?
2. Am I supposed to disconnect the battery when installing or removing the harness?
3. Will the stage 2 offer any power advantages over stage 1 with a stock engine and no DP? Or will the stage 2 just offer the functionality of the CAN interface?
4. Is there only 1 catalytic converter on the 335? I thought most cars had 2 these days.
335R1 335R1 is offline
Car: F30 335i
Default 02-07-2013, 11:07 AM
Now we're talking Terry. I have almost 20k miles on my F30 already and no tune yet. Just waiting for that Stage 2.
Default 02-07-2013, 12:05 PM
1) I don't know. Maybe. Check the firmware date and email it in and we can check.
2) Yes, per the install guide.
3) More power, less lag, better features.
4) Yes. One big one.
NateDog07V NateDog07V is offline
Car: F30 335i M Sport
Default 02-07-2013, 12:20 PM
Does Map0 on the Stage 2 represent having the tune completely off, or is it like a mini Stage 1 tune which is actually available as Map0 on the Stage 2? either way, thanks for getting the ball rolling on this! Definitely looking fwd to the added power come spring time
Buildbright Buildbright is offline
Car: 2013 335i 8AT
Default 02-07-2013, 12:22 PM
I am guessing Stage 2 will have CAN code delete built in and Meth Support will come later?
BTW. You are the F30 Hero!
Default 02-07-2013, 12:25 PM
How do you check the fw date?
Default 02-07-2013, 12:26 PM
Correct on both, as well as E85 support.
Car: F30 335i
Default 02-07-2013, 07:01 PM
The only upgrades I allow on my car has to come directly from Burger Motorsports. I haven't even put aftermarket wheels on. I want them to ask what's underneath that stock F30. I'll tell them BMS. It was like that on my E92 and it'll be like that in the F30.
135idct 135idct is offline
Default 02-08-2013, 12:43 AM
Terry do u think the transmission can handle that huge torque, i think with meth
the car will hit 480 rwtq and smash the tranny
Default 02-08-2013, 09:09 AM
No idea. I'll let you know if I run in to problems with it.
v8bait's Avatar
v8bait v8bait is offline
Car: E92 335i 6MT
Default 02-08-2013, 09:45 AM
Holy Torque Batman! I don't like the scaling differences on your Y axis, it kinda hides the massive torque increase you got, but anyway that thing looks ready to roast some tires on map 2! Nice to see the platform moving along.
justohigh justohigh is offline
Car: 2007 335i coupe
Default 02-08-2013, 11:19 AM
Wow, that is a lot of torque. What's the explanation for that? It beats the E9x n54 and n55 in torque when going mod for mod.
Default 02-08-2013, 11:35 AM
The peak torque numbers are a bit of a spike at the start of the run. It's on par with any other N55 in terms of torque production per mod.
J-boogey J-boogey is offline
Car: 2010 E92 335 xdrive M-Sport
Default 02-08-2013, 06:27 PM
terry, how do you find out what firmware date you have? I got the tune in January
Default 02-08-2013, 06:33 PM
It's under the user adjustment tab.
pnosker pnosker is offline
Default 02-09-2013, 11:38 PM
Happy to test if you need someone!
ridin135 ridin135 is offline
Default 02-10-2013, 09:31 AM
Terry by chance will you be releasing a meth kit for the f30?
Default 02-10-2013, 10:17 AM
We will some day.
Default 02-12-2013, 11:37 AM
Here is a video of how the map switching will work on the F30 JB4 until we're able to get full dash control.
NICKTENN's Avatar
NICKTENN NICKTENN is offline
Car: F30 335i Sportline on order
Default 02-12-2013, 03:47 PM
Any hints on where the CAN connection is made?
2016 F30 340i M Sport Alpine White, JB4
RIP 2012 F30 335i Sport Line Mineral Gray, JB3/Stage 1
Stock 335i 1/4 mile time
BMW335N55's Avatar
BMW335N55 BMW335N55 is offline
Car: BMW F30 335i
Default 02-12-2013, 08:26 PM
Awsome Terry thank you for keeping up on the F10 F30 upgrades, cant wait to have full dash control
spideypm spideypm is offline
Car: 2013 F30 335i M Sport
Default 02-15-2013, 01:09 PM
Hi Terry, any ETA for this?
