(#11476)
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 06-20-2019, 01:21 PM
Originally Posted by beetle6986
Any feedback on my post?
I don't like any maps on the backend flash and the most up to date firmware on the JB4. I think I will remove the backend pump flash. The only issue with that is the JB4 with firmware 32_14 seems to be too aggressive for me to run ethanol like I used to on map 5(trimming issues). I don't know that it is normal for it to target 19 LBs and 10+ degrees of timing like it did.
Is there anyway I can go back to the old 28_02 firmware for JB4? The car ran great for about 5 years on this with map 5 and e30 to e40 before I got the great idea to update.
Run lower boost map, maybe map 1,
Map 5 it auto adjust based on your fuel and mood, so if you hitting 17 psi means you have what it needs to boost 17, if you want less aggressive map go to map 1 should be less than map 5
JB4-M4 JB4-M4 is offline
Car: M4
Default 06-21-2019, 09:35 PM
Can I update the JB4 only when connect to OBD and over USB cable to Software, without connecting other cables?
Joe_135i Joe_135i is offline
Default 06-24-2019, 04:49 PM
I am noticing a slight rattle when accelerating in the lower rpms. What is suggested as far as changes to the JB4?
DamnDatsun's Avatar
DamnDatsun DamnDatsun is offline
Car: 2010 135i msport
Default 06-25-2019, 06:26 AM
Try lowering menu 10 a few hundred rpm.
suni_335's Avatar
suni_335 suni_335 is offline
Car: BMW 335i N54 2007
Default 06-26-2019, 06:22 AM
So I flashed the DME with JB4 BEF via MHD yesterday. Everything went well, I've set the menu 4 to option 2 and running map 1 currently (Boost is hitting 15psi which is the target) . Can't say if there's any difference in the car.. even I can feel it's more sluggish or IDK.. Something to mention is I'm with OEM cats and at the end of the week dawnpipes will be installed but yesterday when I was flashing in the MHD additional options as burble and etc I didn't select that I'm using OEM cats but instead I left it unchecked which means it thinks I'm with dawnpipes. Could that be a problem, make the car sluggish or something else? I also have rattle and in order to prevent it JB4 menu 10 is set to 800, menu 11 to 3000 and menu 12 to 1600. That I think are the best settings which I could achieve cruising yesterday. Any opinions will be appreciated , thank you!
BMW 335i 2007 - N54
MODS: JB4 with BEF, xHP Stage 3, DCI, ChargePipe with BOV
THE BEAST's Avatar
Car: 2008 E93
Default 06-26-2019, 08:28 AM
No log ? I would GUESS car is sluggish because of menu 10 being set so low.
suni_335's Avatar
Default 06-26-2019, 08:33 AM
No logs..but yeah I tried with menu 10 set to 3000 and menu 12 set to 2800: it was one idea better but.. again didn't feel any smoothness but a sluggish car. It was better than the current settings set to 800/1600 for menus 10/12 but I'm pretty sure there's something wrong. The boost target is achieved on map 1 (15psi)
BMW 335i 2007 - N54
THE BEAST's Avatar
Car: 2008 E93
Default 06-26-2019, 01:36 PM
Everyone would just be guessing, without a proper log.
Default 06-28-2019, 10:14 AM
Log is always key for any tuning advice.
iturbo's Avatar
iturbo iturbo is offline
Car: 2009 335i e92
Default 06-30-2019, 11:22 PM
Anybody get misfire codes from the 2 step? My coils and plugs are new...
2009 335i e92 n54 | FBO | JB4 | e85 flash |
THE BEAST's Avatar
Car: 2008 E93
Default 07-02-2019, 08:20 PM
Funny you mention trimming issue. When I updated to 32/14 my trims crashed to 0 on WOT. BTW, I had updated from 32/12/2, this firmware had given me no issues with trims or gauge sweep as 32/14 FWIW.
TimboBlackkers TimboBlackkers is offline
Car: '08 135i MT
Default 07-08-2019, 05:43 PM
I'm using an N20 TMAP sensor and I'm using the option in the JB4 to support it.
If I run MAP0 (JB4 off), will the car be reporting incorrect boost values?
Amgkiller54 Amgkiller54 is offline
Car: N54 335i , E71 X6M
Default 07-09-2019, 12:54 PM
2019-06-26 02_11_21_Map-6.csv
Greetings broís , since iím new to this forums iím in the process of reading and learning how to make my N54 335i faster. My current mods are : Jb4 (on map 5 and 6 ) , RB turbo inlets , Rb turbo outlets , vrsf intercooler , Ar cattles ********* , Vrsf chargepip with hks blow off. For these upgrades ,i am not happy with my 1/4mile times. Since iím from south america and we dont have tuners here, iím trying to learn and upgrade my car myself. So i came on the forums with a lot of hope. Iíve attached my log on pumpgas . I hope that someokne can help me look into it and give me advice of what iím doing wrong.
My best 1/4mile time is 12.98 @108Mph 60Ft is 2.05seconds (Dragybox).
Default 07-09-2019, 01:27 PM
THE BEAST's Avatar
Car: 2008 E93
Default 07-10-2019, 02:10 AM
Originally Posted by Amgkiller54
Do you have a log of this run ?
Csv file ?
Rule77's Avatar
Rule77 Rule77 is online now
Car: 08 E90 335i
Default 07-10-2019, 05:44 AM
Csv file ?
Itís at the top of his first post
08 E90 335i - MONTEGO BLUE - JB4/MHD E85 BEF
BMS DCI - BMS OCC - BMS COWL FILTERS
MMP CHARGEPIPE - TIAL BOV - VRSF 7.5Ē RACE FMIC
VRSF DPís - VRSF INLETS - VRSF OUTLETS
BMS PEDAL TUNER - RB PCV VALVE - 3.5 BAR TMAP
NGK 97506 @.022 - STAGE 2 LPFP - H&R SPRINGS
SPOOL PERFORMANCE ETHANOL ANALYZER
BMS SPORT OIL COOLER VALVE - NRW V1 PADDLES
19Ē 666m WHEELS - HANKOOK VENTUS V12 EVO 2ís
THE BEAST's Avatar
Car: 2008 E93
Default 07-10-2019, 09:10 AM
Yep, missed that.
IATs go way too high. But before they even climb, its already pulling timing. I would say fuel is an issue. Needs higher octane. Enable 6cyl to see full timing.
LOWER BOOST
I would try map 1 and go from there. Lpfp is running a little low. Avg ign value of 7 and IATs going high = low timing curve and loss of power.
Any O2 codes by chance ? Trims are also maxed a good part of the run and looks like it goes to open loop for a bit.
Default 07-10-2019, 09:15 AM
Map0 does the 3.5bar sensor conversion as well.
Sorry for the late reply, but for tuning help post your JB4 log and details to the N54 support forum!
RomaN54 RomaN54 is offline
Car: Bmw e92 335i Manuel
Default 07-10-2019, 07:26 PM
Hey guys
Need some help jb4 is working I can see it wit my app at the phone all settings is work I got no codes no boost leak turbos are healthy no rattle n54 335i I cheak menu 4 is 4.3 safety boost on 18 last firmware update all dome. I have no idea where is problem would u suggest me something? Its impossible to have same boost 8.5 on each map 1.2.5*
Default 07-16-2019, 01:03 PM
Yep, missed that.
LOWER BOOST
Thanks for the reaction bro. You have a point about the octane of the gasoline , our octane of fuel here is lower than in the states. I will be logging again with a a higher octane race fuel ( Vp racing unleaded extreme 110octane) in mixture with pumpgas.
To mention that the previous log was made without a back end flash. Maybe that could play a role too.
The car does not throw any O2 codes bro,not yet until now.
I will test with higher octane fuel and post the log then.
Appreciate all sort of advice
Jineric Jineric is offline
Default 07-21-2019, 10:16 AM
Originally Posted by Jineric
Ok sure, looks like I need to find some space to do that later today. thanks for the reply.
Hi Terry,
managed to get some logs, was wondering is it time for an upgrade of firmware? Please do advise. Thank you.
Default 08-07-2019, 07:43 AM
Hi Terry, able to advise on the above? Should I upgrade my firmware?
GotPwned GotPwned is offline
Car: 2007 BMW 335i
Default 08-10-2019, 11:39 AM
I noticed that my JB4 mobile is detecting an E85 level in my car. It does say that my car is around 53% e85 and fluctuates around +-2% e85 when driving. From what I know I dont think I have a flex fuel sensor in my car. Is this normal?
Rule77's Avatar
Car: 08 E90 335i
Default 08-10-2019, 12:06 PM
Hi Terry,
I would say you should update your firmware.
