(#6601)
elsabor67's Avatar
Enjoys Retirement
Car: 09 135i with M-sport Pkg
Default 05-16-2013, 12:25 AM
Originally Posted by Marv85
it works for everyone. it is also intended to try and fix a partial throttle rattle issue some people were having
Thanks. Appreciate it.
nelsonmg nelsonmg is offline
Default 05-16-2013, 06:54 AM
Originally Posted by Oshusttoley
iso 20 made my car rattle A LOT worse under low throttle. i sent my logs to terry, lets see what he says
same. went back to 19. 19 works the best for me. ~80 lagfix.
2009 335i e90 n54; sport; premium; logic7
maxwell600 maxwell600 is offline
Car: 07 BMW 335i
Default 05-16-2013, 08:28 AM
Just so I understand correctly, it is better to run the ISO firmware. I currently have the G4 board which means I buy the G5 and request that it be ISO, meaning the prongs will be cut before shipped. Correct?
Default 05-16-2013, 08:32 AM
That's what most people do. It seems to pull more steady and evenly and to have more power down low. Also notice all the new firmware updates for ISO. Tells you something about where the focus is.
XLG1@HBE's Avatar
XLG1@HBE XLG1@HBE is offline
Default 05-16-2013, 09:13 AM
Originally Posted by wreckz
+1 I miss the way jb4 g5 intergraded felt
does the sudden boost on the old g5 inter harm our bmw's in anyway
I think g5 iso is great but to me it's more for heavily modified cars with raw power
I'm aware the g5 iso has updated features vs intergraded
is there any way I can get some of that over boost back with the iso ?
+2 Iwish we could get that overboost back
Car: 07 BMW 335i
Default 05-16-2013, 11:11 AM
Off topic, Ocean, what's yours RWHP? What you have done is eventually what I will have done.
Default 05-16-2013, 11:43 AM
Should be in the high 400s somewhere. Haven't done a dyno. Terry gets 500 with his 135, same mods. I hear 5 series are not quite that strong, not really sure.
I sort of follow the Rolls Royce tech sheet, where it says Engine HP: Adequate
Also I care more about usable power and smoothness of delivery than any peak output along a curve. If I did dyno it, I'd actually be just as interested in seeing the torque curve. That's the beauty of TT design. Massive torque on a pancake flat curve through 4k rpms. It's probably a safe assumption that I have 500 RWTQ. :-)
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 05-16-2013, 12:41 PM
Originally Posted by Axing
20%.
The car seems a little bit too smooth for my taste (slow?) ?
Thanks for your answers!
Car is FBO no meth, using map 2
Sometimes smoothness is mistaken for slowness....but if you really want to know for sure...
do a third gear pull from 2500 rpm to 6500 rpm on a level stretch of road.
Then calculate the time between 3500 and 6300 rpm. This will really tell you if any change really makes your car slower or faster.
Why are you not running Map 5?
iDriveSlo iDriveSlo is offline
Car: 325Ci 335i
Default 05-16-2013, 02:25 PM
My god iso 20 is like a miracle, it really is appalling that such horrific rattle went un-rectified so long on the iso boards. FINALLY thank you!
Car: 2009 335i AT
Cool 05-16-2013, 02:50 PM
Originally Posted by robc1976
here ya go
Thanks. The FF curve fits your turbo needs like a glove.
Car is really fast..... 3.1 seconds from 3.5k to 6.3k rpm.
Must be a blast to drive.
robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Default 05-16-2013, 02:57 PM
it gets there quick, I love it. I will post a 20B log...probably about the same.
Axing Axing is offline
Car: 3dirty5
Default 05-16-2013, 04:07 PM
Yeah I will go try that during the weekend.
Map 5 gives me more rattle I don't know why lol it's the main reason why I'm not running it.
BEAR-AvHistory's Avatar
BEAR-AvHistory BEAR-AvHistory is offline
335is 7DCT/JB4
Car: BMW 335IS 7DCT/JB4
Default 05-16-2013, 05:21 PM
Had to drop back to 19.hex. Car really freeked out on 20.hex. 1/2 engine light, surging, sputtering, a lot of warning lights including brakes. Was really weird.
Shut the car down, restarted & the problems cleared but was not confidant enough to leave 20 in so I turned around went back home & reloaded 19. No chance to run a log because it went down about a block from the house. Map 5 fuel 50/50% 93/100.
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
2013 135is 6MT/JB4/ISO
2011 335is 7DCT/JB4/ISO/BMS Flash(sold)
FF Cobra Mk-IV COYOTE BOSS + TKO-600
robc1976's Avatar
Car: 2007 335i
Default 05-16-2013, 05:36 PM
That is crazy, my car love's ISO 20.
robc1976's Avatar
Car: 2007 335i
Default 05-16-2013, 05:37 PM
do you get this info from the time stamp?
ashmostro's Avatar
ashmostro ashmostro is offline
Car: 2013 335is DCT
Default 05-16-2013, 05:44 PM
Finally loaded 20B. Skipped 19. This hex is amazing!! My car is boosting much earlier... apparently i had a ton of lag. Rattle seems gone too but the driveability is far more prevalent.
Love it!
Dirty Dog's Avatar
Default 05-16-2013, 05:53 PM
Terry post 20B already!!!
135i - JB4 15ohm l Mr 5 Intake l AA C@tless ********* l ETS Intercooler l BMS Methanol Injection l Berk Tech Mids l Berk Tech Axleback l BMS OCC l ER CP l Turbosmart BOV's. SOLD
335i DCT - JB4 G5 ISO l AA C@tless ********* l ETS Intercooler l Custom Intake l Meth l BMS E85 Flash l BMS OCC l ER CP l Walbro 255 l Turbosmart BOV's. CURRENT
ashmostro's Avatar
Car: 2013 335is DCT
Default 05-16-2013, 05:55 PM
It is!
Dirty Dog's Avatar
Default 05-16-2013, 05:57 PM
Originally Posted by ashmostro
It is!
Ahhh ok. I already have the 20. Just thought there was a newer 20B going around under the radar.
ashmostro's Avatar
Car: 2013 335is DCT
Default 05-16-2013, 06:00 PM
20 and 20b are different, i think
ashmostro's Avatar
Car: 2013 335is DCT
Default 05-16-2013, 06:10 PM
Nope. I just pulled the hex off the usual first post as an attachment to it. Thought it was released to the public? Has it been pulled back?
sfvalley335i sfvalley335i is offline
Car: 335
Default 05-16-2013, 06:15 PM
To download 20B visit this post....
http://www.n54tech.com/forums/showpo...&postcount=100
ashmostro's Avatar
Car: 2013 335is DCT
Default 05-16-2013, 06:17 PM
There ya go
Default 05-16-2013, 06:20 PM
Any and all rattle discussion is in the support section. I even have 20D to post there shortly.
ashmostro's Avatar
Car: 2013 335is DCT
Default 05-16-2013, 06:21 PM
Woohoo! You rock Terry.
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests)
