(#626)
Default 10-12-2020, 02:30 PM
The ECU is load based so will vary it's target boost based on intake temp, barometric pressure, and other factors. The JB4 target is added on top of that.
Dan Villa Dan Villa is offline
Car: Accord Sport 2.0t 10AT
Default 10-13-2020, 05:45 PM
Thanks. I wish there was a way to get some more consistency...
Default 10-14-2020, 02:22 PM
The load based systems are designed for consistency of power output. For other platforms we have the JB4 implement an absolute boost target approach. But we're not there yet with the Honda in terms of development as it's a more advanced thing that also requires EWG control.
Wink 10-14-2020, 06:00 PM
Any idea on how long something like that would take? I know you guys have lots of other projects/platforms in the works. Maybe a rough guesstimate 6 months to a year ? Hopefully less?
Default 10-20-2020, 04:03 PM
It's not so much a time issue as it is a data issue. I don't currently have a method to log flash boost target which is a necessary competent to add that functionality.
Shane060 Shane060 is offline
Car: 2020 Civic Si
Default Knock reading - 10-29-2020, 08:56 AM
Hey Terry could you help me on Avg Ign and Ign break down?
Car was reading today Ign 2 at 7.9 and AVG ign at 4.1, 4.2
Is there anything going on?
Car is on map 1 running shell 93 octane and I have an Injen short ram but its showing AFR is spot on.
Default 10-29-2020, 09:36 AM
Post the JB4 log for any tuning advice.
Car: 2020 Civic Si
Default jb4 log - 10-29-2020, 09:52 AM
Here is the attached log. Just a short drive to work but definitely need some feedback if can, Thanks Terry!
Default 10-29-2020, 10:33 AM
Some learned knock feedback here, but that isn't completely uncommon. You'll want to see if it learns back down over time, how it adjusts during longer WOT pulls, etc.
Car: 2020 Civic Si
Default knock reading - 10-29-2020, 10:58 AM
Alright thanks Terry! So Ill just keep an eye on it. The other day the car hit limp mode WOT in 4th. Not sure if this is related to the higher knock... For some reason I don't think the car is liking map 3 paired with the Injen SRI as ive been told on other forums the Injen intake is known for having bad fuel trim issues and being really crappy although I constantly monitor it via the JB4 app and its always on point? Running Map 1 now so hoping it readjust and the car doesent limp mode again. I have no stored codes on the JB4 reader either idk if the ECU is clearing them or what. Will continue to play around with it and might pull the intake off Monday and go back to the stock box and see how the Jb4 runs on stock setup.
Default 10-29-2020, 03:29 PM
If you get a fault code should be able to read that later and see what it is.. Strange it wasn't there when you went to read it.
Sebastian15 Sebastian15 is offline
Car: Civic 1.5 turbo
Exclamation Problem - 11-12-2020, 08:22 AM
hi Terry, I need help. My jb4 does not read any vehicle parameters in the mobile app. it is also impossible to read codes and remove them. Do you know why this is? or have they already released a new update? It is not the first Honda with jb4 that I see that this happens
Default 11-12-2020, 03:42 PM
If you're only getting boost and map in the app then the issue is with your OBDII cable install.
Exclamation Problem - 11-16-2020, 04:40 PM
hi Terry, I have a problem with jb4 Mobile. I have an iPhone 11 and I cannot update the firmware. It does not look for the firmware nor does it appear to select my platform in the jb4 app, do you know what the problem is? Thanks Terry
Default 11-16-2020, 05:20 PM
I don't know off hand. Try restarting app. If that doesn't help then email in to support@jb4connectkit.com for app support!
Aplav1982 Aplav1982 is offline
Car: 2020 Honda Accord 2.0t
Default 01-13-2021, 08:51 AM
Can i run my jb4 and ktuner?
Default 01-13-2021, 12:51 PM
Sure the better the flash tune the better the JB4 tune. But log map0 first so we can evaluate how far to push things with your Ktuner map.
fkhothatchi fkhothatchi is offline
Car: civic type R
Default 01-26-2021, 05:31 PM
Hi! I'm new to jb4 just got it few days ago for my type R any other jb4 type r owners in here?
Default 02-07-2021, 11:55 AM
Just posted up a TypeR firmware update we could use some feedback on. Increased the sensor sampling speed which should improve performance a bit.
Coldpizza Coldpizza is offline
Car: Civic
Default 02-07-2021, 12:12 PM
Hi Terry, Iíll give this a try. What differences should I be looking out for?
Andy-J-Knight Andy-J-Knight is offline
Car: Fk2 Civic Type R
Default 02-07-2021, 04:23 PM
I've pulled it down and will update when I get the chance.
Honda Fk2 Civic Type R | JB4 | Injen Air Intake | Scorpion Exhaust | Shadow Chrome Rota PWR's
Default 02-09-2021, 01:41 PM
Just ensuring there are no issues. We don't expect any.
Car: civic type R
Default 02-14-2021, 12:35 PM
any chance we have charge air Temps pre/post IC? including in data logging
Default 02-15-2021, 05:48 AM
I believe IAT is after the IC and TransTemp actually shows the temp at MAF sensor.
