Engelhorn Engelhorn is offline
Car: 2013 BMW 750i
Question JB4 Not Connecting After Handshake??? - 08-03-2020, 04:02 AM
I just installed my JB4 on a 2013 BMW 750i, very easy installation, no ground wire.
After starting the engine I try to connect....it gets to the "HandShake" then an error message? Anyone ever have this problem?
Also, I'm using a new iPhone, the JB4 is not listed on the Bluetooth list?
Ron
Car: 2013 BMW 750i
Default 08-03-2020, 04:26 AM
Message after handshake:
ERROR
Error connecting to JB4. Please check your hardware connection.
jwalkingjon jwalkingjon is offline
Car: Genesis g70 3.3T
Default 08-05-2020, 08:10 PM
Same issue here but mine doesn't say anything about the hardware just that it can't complete the connection, I see the JB4 in my bluetooth on my phone and using a bluetooth scanning app so not sure what it is. Tried it on 3 phones.
jemp1975 jemp1975 is offline
Car: 2014 328i xdrive
Default 09-27-2020, 10:31 AM
Same here. Happened after attempts to update firmware to N20_OBDII_EWG_8_T2.hex
Shane.Thiis Shane.Thiis is offline
Car: Bmw m140i
Default 10-04-2020, 11:14 AM
I also have this issue once I tried to update firmware, then my car wouldn’t run with the Jb4 connected. I’ve been advised that at worst I’ll have to buy a new chip. I need to learn a bit more about the Jb4 before I try and use it again. Hopefully someone finds an easy fix
theshanestation theshanestation is offline
Car: 2020 Kia Forte5 GT
Default 10-07-2020, 06:53 AM
Originally Posted by Shane.Thiis
I also have this issue once I tried to update firmware, then my car wouldnít run with the Jb4 connected. Iíve been advised that at worst Iíll have to buy a new chip. I need to learn a bit more about the Jb4 before I try and use it again. Hopefully someone finds an easy fix
Same here. New JB4, after updating firmware, car is in limp mode.
Can no longer connect v to the JB4.
I basically have a $1000 ($CAD) electronic brick sitting in my garage.
So frustrating.
Why would you have to buy a new chip? isn't it on warranty?
2020 Forte5 GT
CAI
JB4
Car: Bmw m140i
Default 10-07-2020, 09:39 AM
I bought mine second hand. The Bluetooth was working great till I uploaded the new firmware now I can’t connect at all, was advised I can get a new chip with the correct firmware they cost$25 so not to bad if it works. Cheers
Car: Bmw m140i
Default 10-11-2020, 10:54 AM
Has anyone had any luck resolving this? I’m going to bite the bullet and order a new chip
Default 10-11-2020, 12:04 PM
Has anyone had any luck resolving this? Iím going to bite the bullet and order a new chip
I contacted Burger, they are sending me a new chip.
I will provide an update once I receive it
2020 Forte5 GT
CAI
JB4
Default 10-13-2020, 02:51 PM
Just received a new chip today. 1 day overnight service to Canada!
Plugged it in and everything works perfectly.
2020 Forte5 GT
CAI
JB4
Car: Bmw m140i
Default 10-14-2020, 10:55 AM
New chip installed car feels good again, however gauges on my phone aren’t working. Only got the Jb4 3.7 connected and not the obd cable connected as I took everything of. Will fitting the obd cable allow the gauges to work on the phone again. I can swap maps via the phone ��
Default 10-14-2020, 04:09 PM
New chip installed car feels good again, however gauges on my phone arenít working. Only got the Jb4 3.7 connected and not the obd cable connected as I took everything of. Will fitting the obd cable allow the gauges to work on the phone again. I can swap maps via the phone ��
Yes, you need the OBD cable for the gauges to function.
2020 Forte5 GT
CAI
JB4
CastleBravo's Avatar
CastleBravo CastleBravo is offline
Car: M135i
Default 10-18-2020, 06:44 PM
really? Oh that's disappointing, I thought the main point of the bluetooth interface was for logging and stuff without the cable
VipinLJ VipinLJ is offline
Default 10-18-2020, 07:03 PM
Nope. The OBD cable from the JB4 has to be connected too. The Bluetooth adapter is to show the values got from the OBD port in the app.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
2016 BMW X3 xDrive28i
Car: M135i
Default 10-18-2020, 08:37 PM
What can you do without it connected, just bluetooth alone?
Default 10-18-2020, 09:54 PM
Basically change maps
2020 Forte5 GT
CAI
JB4
Car: Bmw m140i
Default 10-18-2020, 11:07 PM
Before I reconnected the OBD connection, the car map didn’t feel as smooth although this could of been a placebo effect.
To be honest I thought the Bluetooth got rid of the need for putting cables into the car, however the cables back in and I can just forget about it.
Default Yesterday, 07:42 PM
I donít think you can change maps either since, without the OBD cable, it basically only runs on map 1? Thatís what I read somewhere. But I could be very wrong.
Current:
