KingDavidsCourt KingDavidsCourt is offline
Car: 2009 535i X Drive
Default Mysterious check engine light... - 09-13-2016, 12:09 PM
I started a post in N54, and was advised to check here. I have an 09535xi... I did the jb4 code read and it came back with just 2 digits. My understanding is there should be at least 4. I did speedo 1, then tach 1... and it blinked twice and went to 20, back to zero... then to 85 and blinked 4 times. Any ideas?
Jsr1256 Jsr1256 is offline
Car: 08 335i Sport Package
Default 09-13-2016, 12:20 PM
Invest in jb4 app and data cable
08 E92 335i AT 20k Miles | Wedge E60 Flash| E85 | VRSF FMIC | VRSF Lower Charge Pipe | ER Charge Pipe|Tial Bov| Vrsf *** | DCI | IC Sprayer | Scoops | NGK 1 Range Colder Plugs | Fuel It LPFP | E60 | [12.2 @ 118with e85 flash] [ My E60 flash 1/4 = 11.8 @ 120
Default 09-13-2016, 02:50 PM
Hindsight... in the mean time.. am I doing the diagnostic right?
Default 09-13-2016, 03:15 PM
I wished I could help you man. I've never used the tach to read codes. I've always had jb4 mobile when I had my jb4. I'm sure someone will help u though. Good luck
Default 09-14-2016, 08:35 AM
Get the BMS cable or JB4 mobile connect kit to read the actual codes.
Default 09-14-2016, 04:15 PM
Well I was hoping to fix this asap, as opposed to waiting on a cable, and then time to install it... the error the dealer had said 'low boost pressure'... not sure if that helps.
Default 09-14-2016, 05:25 PM
Change every vaccum line it's cheap and easy, check all your i/c piping chargepipe etc. I had holes in my vaccum lines with 29k miles and they looked perfect until tested under water.
Default 09-15-2016, 12:39 PM
I changed the two easy ones up top... the one that runs along the block doesnt seem to easy to change... but I guess it's time to roll up my sleeves and dig in.
08 335Ci's Avatar
08 335Ci 08 335Ci is offline
Car: 08 335Ci
Default 09-15-2016, 02:37 PM
Reset your gauges. You should get only numbers in steps of ten; 70, 80, 90 ...
Also if you have 2 numbers the same, say 30ff, the spedo will stay on 150 a little longer. It takes a bit to get used to.
Sometimes you have to do the process a few times to get all the numbers right.
Totaled by a careless driver:
'08 E92 335, M sport option
Default 09-15-2016, 09:15 PM
https://youtu.be/BjAhyIXm-uQ
The miracle of cell phone technology lol... can anyone read that?
