04-15-2017, 12:38 AM
With as long as the JB4 has been around, revisions, etc etc I'd have thought that this would be standard. It'd suck to have such a small tank, but I can see now why some opt to use the factory washer fluid reservoir since it's got a level warning sensor. The biggest reason it popped into my head is because I was looking at a tank that's $70 less than the biggest tank that BMS offers and has over 2x the capacity at 5 gal tank, which includes a level sensor.
http://www.ebay.com/itm/AEM-V2-Water...RYf9pd&vxp=mtr
Car: 08 335i
04-24-2017, 01:52 PM
Dear N54tech friends i wanted to know if some one can inform me about setting the jb4 to use my water meth kit what numbers to put on the
meth flow scaling:
meth boost additive.
i want to use all my mods to its max potential
i have a 2008 335i Automatic, and have the following mods installed:
VTT turbo GC
VTT inlets
VRSF dual cone intakes
VTT outlets
VRSF 7 inch intercooler
VRSF ******* *********
VRSF charge pipe with hks bov
BMS methanol injection single cm 10 nozzle, 50/50 mix
Fuel- it stage 1 LPFP
upgraded PCV valve
JB4
MHD software
4 bar map sensor
Methanol and MHD -
04-26-2017, 04:38 PM
So i just got a met kit from bms. Currently running a custom flash on map 4 . How do i control meth flow while retaining the flash tune??
Forge fmic,VRSF DP, Charge pipe with HKS BOV, BMS intakes, BMS jb4 G5, backend pump flash, 19" MV4s, Golf T mod
04-26-2017, 04:53 PM
You could post a log of what you have in the support area and based on that we could offer advice.
04-27-2017, 02:35 AM
Hi Terry, no i mean I don't understand how the jb4 should be set so that I get meth control while using a flash. I've had to set the jb4 in menu 4 to follow flash target boost and run in map4. This as I know ignores most of the tuning from the jb4 and allows wastegate control only, so does that mean it will not be able to control meth?? I always thought map 3 was for meth control but will that not then ignore my flash tune? I'm confused and can't find solid information. This is all new to me
Car: 2010 E60/535i AT — FBO+WMI
04-27-2017, 07:29 AM
I am probably the LAST PERSON to be offering any advice around here, BUT
It sounds like you might be confusing Map 0/3 the meth driving map, with map 4/2 the backend flash setting "map".
I have meth and BEF, using 4/2 to use BEF and drive with 0/3 for meth flow while driving.
Not sure if that's the case but it sounded like it. This stuff is VERY confusing until you start recognizing the terms used and so-on. Good luck.
Edit: here is a link to the steering wheel controls.
http://www.n54tech.com/forums/showpo...20&postcount=3
2010 535i M-Sport w/Sport AT/6-spd xHP Stage3, Alpine White w/Natural Leather, type-135 wheels w/spacers & Coilovers --- JB4 G5 ISO Trebila (Map-6/BEF) Custom Tune, Custom Meth Setup (link) 25/75%, VRSF 3" free-flow D/Ps, MMPe DCIs, Wagner 1060 Stepped FMIC, VRSF Chargepipe/Tial BOV, BMS Oil Cooler Valve
04-27-2017, 07:47 AM
Don't ask BMS about meth and PI, you'll be waiting awhile for an answer.
Car: 2007 E90 335i
06-13-2017, 10:19 PM
BEF's are the only flash tunes that work in conjunction with the JB4.
As you are currently running a full flash with the JB4 in menu 4/4, it is disabled except for gauges and data logging. To run map 3 progressive meth, menu 0/3 you would need to be in menu 4/2 or 4/3.
Someone correct me if I'm wrong.
07 335i; JB4, Anti Lag, MHD BEF, BMS DCI, Phoenix CP, Tial BOV, MAP OC, BMS OCC, 1320 Down *****, MMP Inlets, RB Ext PCV, Mishimoto OCC, BMS Meth, N20 TMAP, VTT stock+billet comp wheels, Blk124 Wheels (5series take offs staggered), 275/35/18
Car: M235i '15
07-28-2017, 12:25 AM
Hey guys, my BMS methkit is installed  I'm just wondering, i'm running 96% ethanol in the methkit, does it matter? Or is it better to run meth/water? It seems the only major difference between the two is price?
2015 F22 M235i N55 EWG | M Performance | 18" VMR710 | Pure Stage 2 Turbo | Pure High Flow Inlet | XDI-35 HPFP | Fuel-It LPFP Stage 2 | Bootmod3 Cary Jordan Custom Tune | XHP Stage 1 Tune | GFB DV+ T9356 | N20 TMAP | NGK SILZKBR8D8S 0,5mm | Wagner DownP | Wagner EVO2 Performance Intercooler | VRSF Chargepipe | M Performance Exhaust | OS Giken Superlock
Car: 335i MSport DCT
07-28-2017, 07:21 AM
Bottom line, it shouldn't really make any difference.
Meth has better cooling properties than ethanol, and water better cooling properties than methanol.
Methanol is higher octane than ethanol. The AFR on methanol is 3 to 4.5:1 vs ethanol 8.5:1 so you can burn more methanol and make more power. It wont matter much to the car as it's targeting a lambda value, aka oxygen to fuel ratio. Probably 0.8, based on what's in the back end flash.
Whether you use high concentration ethanol or methanol it doesn't make too much difference I suspect. You are providing more than enough octane.
This is despite the fact that a 70:30 water meth mix absorbs a serious amount of heat from the engine.
UK FBO 335i, ̶V̶T̶T̶ ̶G̶C̶s̶ China 19T, JB4, PI meth, BMS CP, OCC, Braided brake lines. Diff Lockdown. TMAP sensor, custom bucketless stage2
Car: M235i '15
07-28-2017, 08:36 AM
Thanks for your clear answer!
07-28-2017, 09:35 AM
I'm currently using Boost Juice, aka "49%/51%" m/w ratio. My tuner thought I should go higher meth, but I declined for safety reasons.
You make it sound like maybe higher water mix is preferred?
I don't know much about this stuff...just hanging on by a thread...lol.
Lambda to me is one of the Frats in Animal House...
But I'm always willing to learn and/or hear different opinions.
// Radar //
Car: 07 BMW 335i
07-28-2017, 03:09 PM
// Radar //
50/50 is generally the minimal requirement. If you are octane deficient, than you up the meth content as needed. If you don't need the extra Octane/fueling, adding more is unnecessary and will just accelerate buildup in the filter, nozzle, etc.
07-28-2017, 09:31 PM
Makes sense, thank you.
Btw, what is the "maintenance schedule" for the filter and nozzles, if there is a known formula for one? 50/50 mix on 15k/yr daily driver, activates at 8 pounds...go through about 8 oz a week maybe(?).
Car: 2009 535i X Drive
07-29-2017, 10:11 AM
What language is being spoken in here? I feel like I need google translate lol
Car: 2007 E92 335i
07-23-2019, 07:31 AM
Is it possible to use a 0-5v ethanol sensor with this to have e85/flexfuel capability?
07-24-2019, 09:43 AM
[QUOTE=RadarContact;551066]go through about 8 oz a week maybe(?)./QUOTE]
8 oz a week!? How do you control yourself? lol
I'd think that filter and nozzle maintenance would vary significantly, based on how OCD the individual is that fills the tank.
I use only filtered tap water and a dedicated mixing jug.
Based on very minimal minerals (multi filter setup) I'd expect the nozzle to be clean for a year.
I'll test it after 3 months though.
I got a base line prior to installing so I will know visually when there is alteration in the spray pattern / atomization.
Also, while my tank is spotless inside, my drawing pipe sits 5mm above the bottom of the tank, so it will not be so likely to pickup any possible sediment.
I'll also wash my tank every 6-12 months to ensure it's clean.
Due to being proactive, I expect low reactive based maintenance.
P.S. Hi Radar! Thanks again for all the early guidance when I was setting up my JB4, Bluetooth, etc. Reading about your WMI setup was a motivating factor for me. I'm mounted in a different location, but your build was very fascinating.
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Car: bmw 335i e92 AT
Suggested BEF for meth + pump -
02-12-2020, 02:11 PM
Hello.. I have a 335i ST 6466 runing pump gas + PI meth stage 2 lpfp + fbo
I wonder which would be the best BEF for the car.
I am msd80 ST TS PI but I don't have e85. Just pump and meth. Does anybody know if I can run a e85 flash with pump + pi meth.
As all PI maps said E85 and there aren't PI + pump.
Thank you
335i AT 2008
DOC RACE 6466 SINGLE TURBO
JB4 G5ISO + MHD TUNING
FUEL IT PI kit BMS controlled
FUEL IT STAGE 4 LPFP
XHP flash stage 3
VRSF RACE EXHAUST
VRSF 7.5 FMIC
NGK SPARKS TWO STEPS COLDER
02-12-2020, 03:27 PM
[QUOTE=codesx;641141]
I’m sorry I didn’t see this post sooner. I don’t really get useful notifications for some reason.
You are so very welcome!
That’s really cool to hear, and makes me feel less guilty for being such a pain-in-the-a@@ with all my questions to all the N54 gurus around here! Lol
Love to see what you ended up with. PM me a phone video if you want to show it off.
Car: Bmw n54 335i 2009
Configure -
03-05-2020, 10:10 AM
Hi Terry, I'm in trouble, I hope you can help me buy a new methanol bms kit but I haven't been able to configure everything about methanol I hope you can help me I'll thank you
03-05-2020, 11:03 AM
Did you input 8.4 into everything. Got any logs?
Meth solenoid not triggering -
08-18-2020, 03:35 PM
*** Resolved, FSB Version-1 is ground triggered.. /o\ lol
Hey all, just finished BMS WMI kit installation but am not getting solenoid activation. I can purge the pump but the solenoid does not open during purging, i checked the solenoid and wiring itself and it tests fine and activates with 12v+. wondering if the fsb is bad or if i missed something? attached is the wiring diagram i made during installation and it seems to be correct from what i pulled out of the installation manual. few changes from the manual to the fsb in my older kit but all seemed logical. any thoughts or ideas I would think if the pump activates while purging that the solenoid would activate as well?
thanks in advance!
Chris
Car: Bmw e92 335i
08-18-2020, 10:51 PM
thanks in advance!
Chris
If the pump is working then take a live off that and connect to the solenoid. The other wire just needs to be ground?
VTT Stage 2+ turbos, BMS JB4, EOS PI with BMS controller, RB Inlets and Outlets, VRSF CP and Intercooler. Tial bov, miltek exhaust. Tuned by Trebila. Bimmer Life coils, step 2 colder plugs, Full M3 rear end conversion.
11.04@129.55
09-07-2020, 01:40 AM
Have been using map 5 and running 80/20 meth/water.
Are there any benefits to running the dedicated meth map ?
