Originally Posted by KingDavidsCourt
I started a post in N54, and was advised to check here. I have an 09535xi... I did the jb4 code read and it came back with just 2 digits. My understanding is there should be at least 4. I did speedo 1, then tach 1... and it blinked twice and went to 20, back to zero... then to 85 and blinked 4 times. Any ideas?
Reset your gauges. You should get only numbers in steps of ten; 70, 80, 90 ...
Also if you have 2 numbers the same, say 30ff, the spedo will stay on 150 a little longer. It takes a bit to get used to.
Sometimes you have to do the process a few times to get all the numbers right.
'10 E92 335 M Sport, JB-4 G5 ISO, 3" CPE Charge pipe, WMI w/dual CM 5 nozzles, 3.5 Tmap, ARM Relocated Inlets (don't do it), VSRF Outlet, BEF, Front Strut Brace, SS brake lines, Drilled and Slotted Rotors, Anti-lag, OCC. Escort Max 360
Totaled by a careless driver:
'08 E92 335, M sport option
